Old May 21, 2003, 11:15 AM
Manchild is offline
Find More Posts by Manchild
Manchild's Avatar
Seattle, Washington
Joined Sep 2002
Fast Forward Flight on Hummingbird?
Just wondering if fast forward flights are possible with the Hummingbird. I've seen videos of other micros flying laps in a gymnasium but I've yet to see a video of the Hummingbird performing such flights. There are a few hovering videos of the Hummingbird so I'm wondering if those fast forward flights are possible. Thanks.
Manchild is offline Find More Posts by Manchild
Old May 21, 2003, 11:59 AM
kenru is offline
Find More Posts by kenru
kenru's Avatar
NW WA, USA
Joined Mar 2003
Yes. FF Flight is certainly possible. One change you may want to make before attempting it is to stiffen the head. Check out: Head Stiffening. This helps reduce pitch-up during ff. If you take it outside, make sure it is a calm day! ANY wind and that little heli will be all over the place. A gym would certainly be the preferred place to fly.
kenru is offline Find More Posts by kenru
Old May 21, 2003, 11:03 PM
Manchild is offline
Manchild's Avatar
Seattle, Washington
Joined Sep 2002
anyone have a video of hummingbird in fast flight?
Old May 21, 2003, 11:38 PM
SchylarB is offline
Find More Posts by SchylarB
SchylarB's Avatar
slc utah
Joined Jan 2003
I've just started flying my HB FF and its great. It will really move. My trouble now is making the transition from FF to hover. I can do it but its a little sloppy. I'll try to get some video this weekend.
SchylarB is offline Find More Posts by SchylarB
Old May 22, 2003, 02:53 PM
art4242 is online now
Find More Posts by art4242
art4242's Avatar
Northern CA, USA
Joined Nov 2001
yes, the transition from FF to hover is tough, especially outside. The head stiffener in my opinion is essential for any kind of forward flight or the pitch up is just too severe.
By far the hardest thing I've found flying my HB outside in any kind of wind is trying to descend/land. With fixed pitch you need to slow down the motor, but by doing so you also lose cyclic authority. Sometimes it's nearly impossible to land between balancing enough forward cyclic to fight the wind with less head speed to descend. Hopefully a collective upgrade for the HB will come soon!
-Art
art4242 is online now Find More Posts by art4242
Old May 23, 2003, 07:39 AM
knife'n'slow is offline
Find More Posts by knife'n'slow
Melbourne, Australia
Joined Jul 2002
This was the head stiffening mod I used. Just a couple of M2.5 bolts and a small piece of 1 mm ply with two 2.5 mm holes. Cut the bolts so there's 10mm protruding, slide the ply over the bolts and hold with a couple of drops of CA. it now flies much nicer in forward flight.
The other mod that helped was increasing rotor RPM by reducing blade pitch (only works if you have a hotter than standard motor setup to give the extra revs)
knife'n'slow is offline Find More Posts by knife'n'slow
Old May 23, 2003, 03:10 PM
Manchild is offline
Manchild's Avatar
Seattle, Washington
Joined Sep 2002
so bottom line is FF flight not possible without "head stiffening"?
Old May 23, 2003, 03:36 PM
wayne is offline
Find More Posts by wayne
Millarville,Alberta,Canada
Joined Jun 2000
Hi
I was going to use a ice cream stick, just the right size and should be strong enough. This weekend going to try out. need a ice cream now.
Wayne
wayne is offline Find More Posts by wayne
Old May 24, 2003, 07:01 PM
Steve McBride is offline
Find More Posts by Steve McBride
Steve McBride's Avatar
Agra, Oklahoma
Joined Feb 2000
FF flight on the HB is definately possible without the head stiffiner mod. But it i sprobably a whloe lot more plesant to do with it.
I am using Hornet FP CF blades with a higher headspeed. I think these blades help a bit as they are not so severely undercambered as the stock blades.
At any rate - I have bee flying mine in FF more and more lately. It takes some gettin used to though. As you increase forward speed, it takes less throttle to maintian altitude. One trick I found is keeping the forward speed constant. It's transitioning from fast to moderate, etc speed than tends to cause problems. I start from about 3' and puch the forward cyclic gently forward until I am at a comfortable speed all the while lowering the throttle. Then it is a matter of trying to maintian this forward speed to avoid any pitch up or dropping. Your thumbs eventually get the hang of where the throttle needs to be in relation to your speed and it starts to come naturally after a while.
Good luck with it. I may build a stiffiner tonight and give it a try tomorrow (weather permitting).
Steve M
Steve McBride is offline Find More Posts by Steve McBride
Old May 24, 2003, 07:35 PM
50feet is offline
Find More Posts by 50feet
50feet's Avatar
DELAWARE
Joined Mar 2003
heli-world has promo video of the humming bird doing more than hovering
50feet is offline Find More Posts by 50feet
Old Jun 02, 2003, 02:06 AM
tallflyer is online now
Find More Posts by tallflyer
tallflyer's Avatar
United States, CA, San Diego
Joined Jul 2002
videos
I have videos of my Hummingbird on my site:
http://www.sdparkflyers.com
tallflyer is online now Find More Posts by tallflyer
Latest blog entry: Yunnec Typhoon H Review
What's up with forward Flight on my Hirobo Mini Lama?? QuietRiot Coaxial Helicopters 2 Feb 24, 2005 08:06 PM
Xrb Fast Forward Flight Mod rickyblaze Coaxial Helicopters 15 Jan 21, 2005 03:46 AM
Yippee! Fantastic First Fast Forward Flight! uglyplane Electric Heli Talk 8 Jan 11, 2005 05:28 PM
Problems with first flight on Hummingbird. falcon247 Micro Helis 36 Oct 15, 2004 05:48 AM
