Old Feb 13, 2010, 04:02 PM
captaintomo is offline
Find More Posts by captaintomo
UK, Midlothian, Edinburgh
Joined Jan 2010
Parkzone T-28 Flaps Mods Question
I would like to add flaps to my Trojan, But i only have all stock setup.
So my question is, Would i be able to add flaps to the fifth channel on the stock receiver. And, Would i need to get a better speed crontroller for the added two servos.
I am new to modding.
Thanks , Thomas
age 14
captaintomo is offline Find More Posts by captaintomo
Old Feb 13, 2010, 04:18 PM
Xpress.. is offline
Find More Posts by Xpress..
Team Hitec, Customer Support
Xpress..'s Avatar
United States, CA, Poway
Joined Oct 2007
Test the switch to see if it will operate a servo or flaps.
And 2 servos is overkill- one servo would be sufficient, like a Hitec HS65 or similar
Xpress.. is offline Find More Posts by Xpress..
Old Feb 13, 2010, 06:04 PM
Joined Jan 2010
Thanks if used 1 servo, where would it be placed in the wing?
Old Feb 13, 2010, 11:19 PM
IEATSRT is offline
Find More Posts by IEATSRT
Thumbflyer
IEATSRT's Avatar
Manning, AB, Canada
Joined Nov 2009
If you are new to modding you will find two servos are much easier than one... in my opinion. unless you can figure out exactly how to do one on your own it can be tricky. i have added flaps on both of my corsairs, my t28D, and my messerscmitt (which comes from the factory set up for two flap servos). I've used hitec hs85bb but a bit overkill... hs65mg's would be a good size servo for the flaps. You don't have to add a new ESC but I would look at putting in an external or UBEC if you go with two servos for flaps. here is a link to the eflite 30 amp speed controller if that is the one you have (some of the older models only came with 25 amp).
http://www.e-fliterc.com/Products/De...rodID=EFLA1030
says if you go to 5 analog or 4 digital sub-micor servos you should use ubec. This is something that I questioned as with the messerschmitt it is not recommended to have a ubec but I didn't bother with taking any chances as a ubec is cheap. I personally use castle creations not the pro one but the smaller one capable of handling 6s batteries
http://www.castlecreations.com/products/ccbec.html
as for it working on the 5th channel yes it will... and without any changes this will be your gear channel. what transmitter are you using. with the ar500 I was able to get a full flap setting on the gear switch and mix in a half flap setting on the flap switch. that was a long time ago but if you want... I will try and figure out what those settings were before I moved up to the ar6200. I will pm you a link that might help you with your flaps build. it was for the corsair which is harder than the t28. I also have some pictures of the t28 build that i can send to you. cheers...
Brandon
IEATSRT is offline Find More Posts by IEATSRT
Old Feb 13, 2010, 11:45 PM
Xpress.. is offline
Xpress..'s Avatar
Joined Oct 2007
It's easy to use one servo- mount it in the middle of the plane, then use a simple bellcrank- which is essentially a wire with an L bend at each end. You can look up to see how others have done bellcranks- they're just as light as 2 servos, but will be easier on your ESC
Old Feb 14, 2010, 12:01 AM
IEATSRT is offline
Thumbflyer
IEATSRT's Avatar
Manning, AB, Canada
Joined Nov 2009
your probably right it could be easier and i would have gone that route but I never could find a good link on how to do this.... so i just went at it my own way and with my limited modding skills used the two servo approach. here are some links that will help out.
Flaps
http://www.rcgroups.com/forums/showp...&postcount=285
http://www.rcgroups.com/forums/showp...&postcount=725
http://www.rcgroups.com/forums/showp...postcount=1405
http://www.rcgroups.com/forums/showp...postcount=1786
http://www.rcgroups.com/forums/showp...postcount=3054
http://www.rcgroups.com/forums/showp...postcount=3206
http://www.rcgroups.com/forums/showp...postcount=6190
Old Feb 14, 2010, 12:10 AM
gewiens is offline
Find More Posts by gewiens
Look Up!
gewiens's Avatar
Canada, MB, Niverville
Joined Apr 2008
Cant you just use 2 servos and y connect them?
gewiens is offline Find More Posts by gewiens
Old Feb 14, 2010, 01:12 AM
IEATSRT is offline
Thumbflyer
IEATSRT's Avatar
Manning, AB, Canada
Joined Nov 2009
Yes you can do this... it is what I have always done. The original question pertained to whether it would work on the 5th channel and the answer is yes... the gear channel. if you want the plane to look symmetrical you will need a reverser also for one of the servos. otherwise you will be installing servos differently in order to get the propper direction of travel for both.
Old Feb 14, 2010, 04:08 AM
Joined Jan 2010
Brandon
I dont have the fancy dx6i or the dx5e... I just have the stock radiosystem that cam with my rtf plane
Old Feb 14, 2010, 10:02 AM
fmw is offline
fmw
Find More Posts by fmw
fmw
fmw's Avatar
Joined Jul 2009
I guess I need some grounding in this too. I have a couple of models that use two aileron servos and it is very easy to connect one to the aileron channel and the other into the flap channel and program flaperons into the radio. Then I can dial in as much flap as I want and the ailerons still work normally. Using two aileron servos is just the ticket for setting up flaperons.
I can't see how you would do this with a single servo, however. A single servo is going to move the ailerons in opposite directions mechanically, no? Also, if you have two servos connected with a Y connector into the aileron channel you would get the same thing without reprogramming the transmitter.
Tell me, how does one do flaperons with a single servo?
fmw is offline Find More Posts by fmw
Old Feb 14, 2010, 11:33 AM
Xpress.. is offline
Xpress..'s Avatar
Joined Oct 2007
The exact same way the elevator is setup- with a control horn on one side, and a connecting rod in the middle (in this case, you would put the control horn on the conecting rod, parallel to the control rod ).
Old Feb 14, 2010, 01:24 PM
IEATSRT is offline
Thumbflyer
IEATSRT's Avatar
Manning, AB, Canada
Joined Nov 2009
fmw... what reciever are you using to do this? It is my understanding and personal experience that with the AR500 you can't set up flaperons with the 6i as it only has two mixes... but I think it could be possible with the Dx7 using some extensive mixing. I set them up before with my 6i on an AR6200. Also I don't know how even after reading the above post how you would do it with one servo.. can't get the mental image. lol
Old Feb 14, 2010, 01:26 PM
IEATSRT is offline
Thumbflyer
IEATSRT's Avatar
Manning, AB, Canada
Joined Nov 2009
I think you have the 5e then... no it isn't fancy but if you should still have flaps function on your 5th channel.
Old Feb 14, 2010, 02:39 PM
Joined Jan 2010
nope ... it i the ZX10,it is a fm radio and hoingas a 5th channel.
Next week im doing a boot sale and im planning on getting a dx6i with the money i get. I will use it on my Trojan and my Blade MSR.
Old Feb 14, 2010, 02:42 PM
Joined Jan 2010
i just thought ... if i get theDX6i i could get flapperons by mixing the aileron? Whats your thoughts?
Help! ading flaps to the parkzone t-28 trojan nashiem Electric Plane Talk 4 Feb 27, 2010 02:49 PM
Discussion *~*~Parkzone T-28.....Wish to install flaps! nod Parkflyers 1 Sep 03, 2009 12:05 PM
Discussion My Scale Parkzone T-28 with flaps and retracts hercflyer Parkflyers 8 May 02, 2008 10:27 PM
For Sale T-28 Trojan RTF by ParkZone with Flaps snoshoe62 Aircraft - Electric - Airplanes (FS/W) 10 Apr 28, 2008 05:36 PM
Discussion Parkzone T-28 with Flaps corvettetimmy Parkflyers 1 Jan 26, 2008 03:39 PM
