Old Sep 11, 2011, 06:34 PM
DonQ8401 is offline
Find More Posts by DonQ8401
Why am I addicted!!!
DonQ8401's Avatar
United States, IL, Columbia
Originally Posted by cmd View Post
Lots of torque and small wing area on the AMX. I found on stock power I had no roll problem. With a Wemo mini-fan and Don's motor, lots of torque and left roll.
I gave up hand launch and went to a bungee launch.
CMD,
You aint lying... I gotta get the bungee cat. Now I need a new cone. Cheers
DonQ
DonQ8401 is offline Find More Posts by DonQ8401
Old Sep 12, 2011, 09:17 AM
gooniac33 is offline
Find More Posts by gooniac33
gooniac33's Avatar
Sunnyvale
Joined Feb 2009
The AMX needs a pretty good toss to get going. But you also need to have it set up correctly. Yes it has a lot of torque roll at low speeds but if you get it flying with a good toss to begin with there will be no issues. You also need to either pin the ailerons or set them to barely move at all. The Elevator should be doing 98% of the work. With these wings being so small spoilerons actually kill too much lift making it hard to fly especially on launch. Once I tuned out the aileron movement all of the launching/torquing problems went away. Also with the hopped up motors you need no more than 60% throttle to launch. I use 4s on a stock set up now and have used a high power set up as well. Nothing more than 60% throttle to get it flying. I will take a video of mine flying so that you can see what I mean...
gooniac33 is offline Find More Posts by gooniac33
Old Sep 12, 2011, 01:09 PM
DonQ8401 is offline
DonQ8401's Avatar
Goon,
My ailerons are fixed so no movement. I have flown this with stock and a hand launch was perfect.
With the Don's setup gives it a bunch of torque... I am looking for a new body...
Old Sep 12, 2011, 02:45 PM
gooniac33's Avatar
Sunnyvale
Joined Feb 2009
Originally Posted by DonQ8401 View Post
Goon,
Then lower your throttle when you throw it. That could be all it is.
Old Sep 12, 2011, 03:50 PM
The Don is online now
Find More Posts by The Don
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
I launch all my EDF models full throttle with a very firm push and I never have issues on launch. All videos I see with launch issues are from not throwing the model hard enough and or twisting the wrist at the end of the launch.
The Don is online now Find More Posts by The Don
Old Sep 12, 2011, 03:55 PM
gooniac33's Avatar
Sunnyvale
Joined Feb 2009
I agree. Most problems are in the throw.
Old Sep 12, 2011, 09:28 PM
KTMRacr is offline
Find More Posts by KTMRacr
When in doubt, gas it!
KTMRacr's Avatar
United States, KS, Spring Hill
Joined Dec 2010
FWIW, I upgraded my AMX to the Don's Wicked/Wemo combo and mine has hand launched perfectly every time. A solid push at about 10 degrees up at WOT is how I launch. My ailerons are solid... Only the tail is hooked up to servos.
KTMRacr is offline Find More Posts by KTMRacr
Old Sep 13, 2011, 06:41 PM
DonQ8401 is offline
DonQ8401's Avatar
Anyone got an extra one to get rid of... I am looking for just the body... Cheers
DonQ
Old Aug 17, 2012, 04:26 AM
frogforce is offline
Find More Posts by frogforce
Australia, QLD, Rubyanna
Joined Aug 2012
anahedril
G'day, having stripped out one of Don's wicked 4800kv weomo's from my f18 run on 1000mh 4s nano 65c 40A hawk esc, now installed in New amx fuselage. The f18 flys nicely and will again, these jpower 50mm are great I have a jpower 64mm amx done 30ish flights in 2years all banged up and carbon reinforced now with stock stinger64 running gear, stinger has gws typhoon 4s setup. Building a 70mm hk viper with wemo and 1w40 on 6s too.
Question, does anyone have anahedril set on the wings, I have on the 64mm amx about 3 degrees, at first there was none nice and flat, but after a palm tree attack at full noise pylon racing myself in the backyard, I used Stickabond to repair. It's a honey looking stuff that expands like foam over 6hrs and sets like areldite resin, good stuff, try filling a carbon rod groove with rod in and sand smooth. The difference in flight is noticeable it will hold alt longer when banked and banks over (rolls) further before dropping its nose.
I will setup with elevons only after flying f18 with both. Does a carbon rod really interfer with air speed if its in the inlet ducting, stiffen the wing.
frogforce is offline Find More Posts by frogforce
Old Aug 17, 2012, 04:54 PM
DonQ8401 is offline
DonQ8401's Avatar
Frog,
I added small rods in mine, but it didn't go into the inlet. I have extra AMX parts if you are interested. Cheers
DonQ
Old Aug 17, 2012, 09:55 PM
Joined Aug 2012
thanks Don
Cheers for replying mate, this wicked wemo is delish, sounds super sweet when wound up past 350watts, peaks at 33a 430w settles at 29a 403w on 1000mh 4s 65c nano. Yee-ha! Fast.
Do you think it wise to put anahedril or leave the underside flat, level. I have 2 complete kits from hk to play with whilst my shoulder reconstruction surgery heals. Hangglideing say no more.
Ordered a t45 kit too, expect another wemo combo order shortly. Might try one with and one without, I'll post results/findings. Happy landings all, cheers Kane.
Old Aug 18, 2012, 03:52 AM
Joined Aug 2012
more toys
When holding these wings against the fuse it seems there is already some anahedril built in, I'll go with it I think. Here's more pics.
Old Aug 18, 2012, 04:08 AM
Joined Aug 2012
more toys
When holding these wings against the fuse it seems there is already some anahedril built in, I'll go with it I think. Here's more pics. ANHEDRAL, correction spelling, my bad.
Old Aug 25, 2012, 05:54 AM
Joined Aug 2012
auw 424g
Auw with 1000mh batt is 424g, when I throw in the 1800mh its 529g, have to chuck this hard, only ever fudged one hand launch on the 64mm amx. Hs55 servos, more pics. Thanks Don for answer on stinger 64 thread about power options, cheers Kane.
Discussion JPower P-38 (Sold By Banana Hobby) fred_n Electric Warbirds 6574 May 01, 2015 05:28 PM
Build Log Wicked Powered Jpower F5-E The Don Don's RC 57 Nov 23, 2014 08:42 AM
Article Hobby Lobby JPower AMX Light Attack Jet ARF Review Bajora Foamy EDFs 394 Jul 12, 2013 02:49 PM
Video Hobby Lobby's JPower AMX EDF with a Hoffman Magnetics Mightey Mite 60mm Motor Bajora Electric Plane Talk 2 Jan 06, 2009 06:48 PM
