Old Feb 12, 2010, 08:05 PM
The Don is offline
Find More Posts by The Don
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Build Log
Wicked Powered Banana Hobby Jpower 50mm AMX
Just received my 50 mm Jpower AMX from Banana Hobby, they sellit under the Blitz RC brand on their website. First appearances is that these are nice littel EDF models and I pleased with the quality of the foam and painting on the AMX. The stock power system comes with a 50 mm EDF fan unit (5 blade) and a 20 amp ESC. I am going to do a few tests on the stock power system then my plan is to install a Wicked EDF motor with a WemoTec Micro Fan to speed this baby up. I would like to get it into the 90 mph range which should not be an issue. I will post photos in a litle bit.
Here is a link to the BH website for the model I bought:
http://www.bananahobby.com/1990.html
Don
The Don is offline Find More Posts by The Don
Old Feb 12, 2010, 08:07 PM
typhoonmaster is offline
Find More Posts by typhoonmaster
Rain or shine, wind or calm
Palatine
Joined Jul 2007
hurry up.
typhoonmaster is offline Find More Posts by typhoonmaster
Old Feb 12, 2010, 11:22 PM
The Don is offline
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
A few more photos.
The Wemo micro fan sweep are:
D=49.8mm
d= 26.8 mm
Deq= (49.8^2-26.8^2)^.5 = 41.97mm
80% FSA diameter = 41.97 * .8^.5 = 37.54mm
Measured exit diameter = 39.4mm
So exit is (39.4/41.97)^2= 88% FSA which is a good value for most power settings. If you want to go for more speed instead of thrust then 80% is a good mix of thrust and speed
Sounds like a "nip and tuck" is in order for more speed.
Don
Last edited by The Don; Mar 17, 2010 at 12:29 AM. Reason: Corrected FSA calculation.
Old Feb 13, 2010, 09:20 AM
Gary Hoorn is offline
Find More Posts by Gary Hoorn
Chesapeake Bay RC Club
Gary Hoorn's Avatar
USA, MD, Annapolis
Joined Feb 2005
Don,
I know from personal experience what a "Beast" that motor is! That little plane is going to rock!!!
Gary
Gary Hoorn is offline Find More Posts by Gary Hoorn
Old Feb 13, 2010, 09:49 AM
pdawg is offline
Find More Posts by pdawg
Need 4 Speed!
pdawg's Avatar
United States, OH, Dayton
Joined Apr 2004
Cool conversion Don! How do the weights of the power systems differ? Looks like your going to get some serious performance boost. I wouldn't be surprised if you got a 100mph out of this setup!
pdawg is offline Find More Posts by pdawg
Latest blog entry: Visiting Edwards AFB
Old Feb 13, 2010, 11:42 AM
Smokescreen38 is offline
Find More Posts by Smokescreen38
Checking CG is for NERDS!
Smokescreen38's Avatar
Joined Jun 2005
subscribed!
I suspect the version I got (the F-86) won't be as aerodynamically slippery as the AMX but more power is always better!!
Smokescreen38 is offline Find More Posts by Smokescreen38
Old Feb 13, 2010, 12:07 PM
cmd is offline
cmd
Find More Posts by cmd
cmd
cmd's Avatar
Niceville, FL
Speed Measurement
Don,
How are you going to measure speed? I would thing a radar gun would have some difficulty getting a decent return from this small aircraft.
cmd is offline Find More Posts by cmd
Old Feb 13, 2010, 01:29 PM
whiskykid is online now
Find More Posts by whiskykid
team sleprock
whiskykid's Avatar
United States, WA, Port Angeles
Joined Dec 2009
hey! Don, you gonna b selling that set-up?(fan-wicked) dynamicaly balanced. if so, bout how much?
whiskykid is online now Find More Posts by whiskykid
Old Feb 13, 2010, 04:27 PM
WRXronald is offline
Find More Posts by WRXronald
Joined Dec 2004
awesome -- i'm curious to on the stock power system overall weight. Or at least the weight of the stock motor.
That is going to COOK out at 5400kv --- how much battery are you gonna have to give that??
It will top 100mph EASY i'm sure w/enough lipo. My WEMO Micro just arrived today -- don't even have the jet yet -- or the motor i picked either. I went with 5000kv -- 55grams Exceed EDF motor (26mm can) - for the money you can't go wrong -- peaks 400watts so a good match i hope for the Micro fan. I'm worried Rhino 40C 1050 is going to be barely enough. You're gonna need 1500mah 40C probably...
Can't wait to see this fly - keep at it!!!
WRXronald is offline Find More Posts by WRXronald
Old Feb 13, 2010, 06:55 PM
The Don is offline
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Sorry I have not replied sooner, been gone all day, went to see Monster Jam with my son and my dad. Nothing like monster trucks and loud engines
The stock motor and fan weigh 2.1 ounces
The Wicked Wemo 50mm combo is 2.9 ounces
With ESC added:
stock with stock ESC: 3.1 ounces
Wicked Wemo/ Pentium 40: 4.4 ounces.
Stock lipo: 2.6 onces
3S2100 30C: 6.7 ounces.
I am going to get some amps watts on this setup. But the fuselage will hold a 3S2100 just fine and all parts on the scale was just under 16 ounces which I think is reasonable as this higher power is not intended for newbies anyhow so I am not worried about the higher wing loading. I think a 3S 1500-1800 size may be the best setup but I need to research packs a little more as some of these 1800 weight only 1 ounce less than a 2200 so might as well go 2200.
I will post more as I go.
Old Feb 13, 2010, 06:56 PM
The Don is offline
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Originally Posted by cmd View Post
Don,
Doppler at first, when the weather gets better I will break out the Pro-speed radar gun
Old Feb 13, 2010, 06:57 PM
The Don is offline
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
If this works out well then I will be carrying the Wemotec 50mm fan, as long as the fan is reasonable to balance then I can offer balanced ones.
Old Feb 13, 2010, 08:12 PM
The Don is offline
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Did a runup on the Wicked Wemo combo and the numbers are not what I expected. I was hoping for more but what I got was 310 watts on startup then settled to 280 watts and 24 amps. This means a 3S1300 20C will be plenty and I can use a 30 amp ESC. So that will drop the weight of the lipo and ESC about 3 ounces so I will be about 13 oz at 280 watts which is 344 watt/pound which sounds like a good number. I think I am going to test the Wicked 4000 on 4S and the 4800 on 4S just to see what I get. Maybe a 4S 1300 lipo will be a baby rocket.
Don
Just tested a 4S setup with the Wicked 4000 and got 325 watts at 22 amps so a 4S 1000 30C is also an option.
Old Feb 13, 2010, 10:14 PM
Joined Dec 2004
Don
Don those numbers are a surprise --- i thought the WEMO Micro has been tested to 650 watts (extreme case as i understand), but 400watts should be in the picture.
What do you think is holding back in the setup, lipo or motor? or fan? - on 3s 40C 1050mah.
I was hoping to run near 350 watts peak with a 5000kv Exceed EDF motor in the Micro fan. I've got a couple 4s 30C 1600's that weigh 167grams each -- but on the 5000kv that is likely WAY to hot on the motor.
Did you measure watts with same lipo on stock power system?
Oh yes how was the balance on the WEMO fan out of the package? decent?
Discussion JPower P-38 (Sold By Banana Hobby) fred_n Electric Warbirds 6616 Jun 26, 2015 04:01 PM
Article Hobby Lobby JPower AMX Light Attack Jet ARF Review Bajora Foamy EDFs 395 May 16, 2015 12:57 AM
Build Log Wicked Powered Jpower F5-E The Don Don's RC 57 Nov 23, 2014 08:42 AM
Video Hobby Lobby's JPower AMX EDF with a Hoffman Magnetics Mightey Mite 60mm Motor Bajora Electric Plane Talk 2 Jan 06, 2009 06:48 PM
