Old May 16, 2011, 10:00 PM
wheelspinner20 is offline
Find More Posts by wheelspinner20
wheelspinner20's Avatar
S.E.Michigan
Joined Jul 2010
I might have the opportunity to do some actual slope soaring this summer. Does the suggested CG change if one removes motor and bracket, and uses a smaller 2s battery to power just the elevons and rx?
For clarity, I know the actual CG will change physically, what I mean is, the one that I have now for powered flying, is where I want to end up after removing motor?? Or is a slope soar set-up best more nose heavy or tail heavy for best performance.??
I figure the motor/bracket will be 80 to 100 grams or so, and changing from 2200 3s to a 850 2s will loose about 80 to 90 grams.... but the weight loss from the back is closer to the fulcrum than the same weight from the front. Any thoughts anyone??
Pat
wheelspinner20 is offline Find More Posts by wheelspinner20
Old May 16, 2011, 11:26 PM
Lee is offline
Lee
Find More Posts by Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
Pat
Keep your CG the same place as it is if you decide to pull the motor off. Lately I just launch the plane, motor and all and not use the motor unless I need too. I know it is lazy but I have launched when no one else would with both light winds and near hurricane winds. The Reaper is different than some gliders. It wants to keep moving. Some planes just hang there...the Reaper will fly best if it is running the ridges.
Lee is offline Find More Posts by Lee
Old May 17, 2011, 10:42 AM
Lee is offline
Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
oops
Old May 19, 2011, 04:33 AM
imdone is offline
Find More Posts by imdone
imdone's Avatar
United States, WA, Seattle
Joined May 2011
how good of a fpv plane is the reaper? Im going either with the reaper or a zypher. im inclline to pick this becuse of the price. but can in carry the same load as a zypher? to 4s3300 gopro, osd,etc?
imdone is offline Find More Posts by imdone
Old May 19, 2011, 07:46 AM
Lee is offline
Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
The Reaper can carry a fair amount of weight. The price is good. The Reaper is very efficient and can glide well. You can get great performance out of a smaller motor so you can get away with a smaller battery all of which may cost less money and are lighter which improves the flying more.
Old May 19, 2011, 08:57 AM
Plane Insane RC is offline
Find More Posts by Plane Insane RC
BUZZ KILL
Plane Insane RC's Avatar
Utah
Joined Aug 2010
I have a gopro and 2200mah 11.1v on mine that I fly during combat. I don’t have an osd or video TX on it right now. In the past I have flown it FPV but that was with a board cam and 2200mah 11.1v and it flew great. I’m sure you could get away with adding more weight but how much I don’t know. Maybe when my new Dragon OSD gets here I’ll throw it on but then I only have 1 combat wing. Sounds like I need another Reaper!
Plane Insane RC is offline Find More Posts by Plane Insane RC
Old May 19, 2011, 01:52 PM
Lee is offline
Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
I just found the older model of the GOPRO at Bestbuy for $150 but after buying it found it has a fisheye lens and returned it.
http://www.bestbuy.com/site/GoPro+-+...era&cp=1&lp=11.
So I went back and got the 1080. It is on sale for $239.
Here is the 1080 version to compare.
http://www.bestbuy.com/site/GoPro+-+...-1289-1727-0-2
Lee
Old May 19, 2011, 02:08 PM
BUZZ KILL
Utah
Joined Aug 2010
I personally dont like to use 960. It makes everything too fisheyed. All the stuff I do is in 1080.
Old May 19, 2011, 04:14 PM
imdone is offline
imdone's Avatar
Joined May 2011
what power system would you recommend for fpv?
Old May 19, 2011, 10:11 PM
Lee is offline
Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
I returned the 960 and got the 1080. Ryan is right!!!! The 960 has a serious fish eye lens that I didn't like.
The 1080 is also on sale for $239 which is still the best deal on that camera I have seen from a major retailer.
I would use the 3530-1700. It is a good motor on this plane. Batteries depend on the range you want to have and the camera gear you want to carry.
Lee
Old May 20, 2011, 08:28 AM
Lee is offline
Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
Has anyone tried these motors from Hobbypartz?
http://www.hobbypartz.com/86ma15-2220-1880kv.html
360 W 1880 kv may be a little hotter with the 7x6 prop
Her are a couple more. Look at the 75M35 and 75M55 both with 1800 kv.
http://www.hobbypartz.com/75m55-opti...-1800kv-2.html
Old May 20, 2011, 02:14 PM
doggit is offline
Find More Posts by doggit
doggit's Avatar
northenden, manchester, england
Joined May 2009
well i just recieved one of those RC Timer A-3530/8 motors and i am assuming i have to push the shaft the opposite way, is that right ?, and also just got word from the delivery company that my parcel is to be delivered on tuesday , so want to get the motor ready, so if the shaft need moving then i will do it tonight
carl
ps i just done the shaft and it was a doddle, so now my motor is all ready for its new home on my reaper, here are a couple of pics of the finished motor
doggit is offline Find More Posts by doggit
Old May 20, 2011, 06:42 PM
S.E.Michigan
Joined Jul 2010
If this was covered already, I missed it... Doggit, is there an extra groove cut near the end of the shaft to replace the clip once moved?
And what is the Yank translation for Doddle?? Simple or difficult?
Pat
Old May 21, 2011, 01:14 AM
doggit is offline
doggit's Avatar
Joined May 2009
hi pat, yeah doddle means easy , and the shaft has the groove on the end so once you push it down you just attach the clip onto the groove, and i might grind a small flat spot onto the shaft so the prop saver screw has a good flat surface to grip onto instead of a round shaft
carl
Old May 21, 2011, 06:29 PM
S.E.Michigan
Joined Jul 2010
Thanks doggit.
You guys are not gonna believe this... combat with my brother a few hours ago, hard head on impact. Lost control, I cut throttle, then realized that I was still high enough to try and dig it out... Punched the throttle, HIT THE GROUND bounced up still on the throttle, and continued the flight! I wish I had the hat cam, but the cam was ON THE PLANE!! video to follow, it takes a while to edit, and upload and convert. But here is a screen cap just before impact.
Then, moments later, decided to set it down quick to congradulate and check for damage, on approach to turn into the wind, we hit again, and my GR hits the ground with the camera pointing at the spot where his Titan hits the ground a second later... Its really cool.
Had a blast today, really nice weather compared to the constant rain we have had. A little windy, but no problem for the big wings.!
Pat
Sold Reaper GR60 Stagger_Wing Aircraft - Electric - Power Systems (FS/W) 0 Jan 13, 2010 01:43 AM
Sold Reaper GR 60 wrpsr1911 Aircraft - Electric - Power Systems (FS/W) 0 Jan 06, 2010 09:28 PM
Build Log House of Balsa "Grim Reaper" P51 Mustang Gun Jam Electric Warbirds 28 Dec 20, 2009 03:25 PM
Discussion Body count... Grim but it's really gotta be done. Bilbobaker Life, The Universe, and Politics 15 Nov 15, 2009 01:09 PM
Gallery Grim reaper Wickett R/C Pumpkin Contest 1 Oct 31, 2005 04:37 PM
