Old May 12, 2011, 02:27 AM
doggit is offline
Find More Posts by doggit
doggit's Avatar
northenden, manchester, england
Joined May 2009
this is the one i am going to use http://www.giantcod.co.uk/keda-thumr...-p-403686.html i have never used it so no comparisons, not even sure if it is similar specs
carl
doggit is offline Find More Posts by doggit
Old May 12, 2011, 10:49 AM
JIMBAKER is offline
Find More Posts by JIMBAKER
called into work, I'm AIRSICK!
JIMBAKER's Avatar
United States, OR, Klamath Falls
Joined Jan 2009
Originally Posted by Lee View Post
I was making an order this morning and was surprised the Turnigy 35-30A 1700 was not only out of stock but not backordering.
The motor that rctimer has is the only other motor I can find that has the same stats. Not good!!!!!
I like the 1700KV so I can use the same prop as the Assassin and Widowmaker.
We need your help. Please post any motor you have used that has worked well.
Lee
Lee,
I don't have the GR but this is what I am flying on my Titan http://www.graysonhobby.com/catalog/...tor-p-585.html
I am using 2200 mAh 3S batteries and a 6X4 prop so it is a little more prop noise. You could do the same thing with this motor and use a 2 cell battery and a 7X5 or 7X6 prop if you wanted the slower turning prop.
I used this motor http://www.graysonhobby.com/catalog/...jet-p-765.html on my Widow Maker with 1300 mAh 2S battery and using a 7X5 APC prop. Only problem is it doesn't give me much protection for the battery since a 2S had to be moved closer to the front to balance.
jb
JIMBAKER is offline Find More Posts by JIMBAKER
Old May 12, 2011, 11:09 PM
wheelspinner20 is offline
Find More Posts by wheelspinner20
wheelspinner20's Avatar
S.E.Michigan
Joined Jul 2010
I use this on my 29 oz. Polaris seaplane on 3s 1800mAh. Great motor, strong and dependable.... double check solders on bullet connectors before install.
Verticle no prob. but, its my impression that it will not handle a 7x6 prop. 6x5.5 is the highest grayson recommends. (its a generic copy of the suppo 2212-6 i think)
P
wheelspinner20 is offline Find More Posts by wheelspinner20
Old May 13, 2011, 12:04 AM
JIMBAKER is offline
JIMBAKER's Avatar
Joined Jan 2009
P
Your right about it being a 2212-6 but it will spin a 7X5 or 7X6 on a 2 cell without a problem. So if your are wanting to built and fly light a 2 cell will help on the all up weight.
jb
Old May 13, 2011, 01:29 AM
Lee is offline
Lee
Find More Posts by Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
Does anyone else sell Turnigy motors?
Lee is offline Find More Posts by Lee
Old May 13, 2011, 10:57 AM
Lee is offline
Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
I found this motor.
http://www.plus2city.com/plus2store/goods.php?id=6591
What we are looking for is about 350 watts and 1700 kv
Old May 13, 2011, 11:09 AM
JONBOYLEMON is online now
Find More Posts by JONBOYLEMON
Full disclosure, not sponsored
JONBOYLEMON's Avatar
United States, UT, American Fork
Joined May 2002
Lee, Doug @ MRS has a line on 1700 kv 400 watt motors. I will get more info, but they would be local and available for a great deal in qty's of 10.
JONBOYLEMON is online now Find More Posts by JONBOYLEMON
Old May 13, 2011, 10:54 PM
Lee is offline
Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
You didn't let him go home tonight did you?
See what he can do please!!!!
Old May 14, 2011, 07:36 AM
nageotte is offline
Find More Posts by nageotte
I can fix it.
nageotte's Avatar
Cochranton, Pa.
Joined Nov 2005
Motors
We already ordered motors from RC Timer, but for $4.00, OK $5.00 we will buy some more just to have around. Go ahead and get 100 of 'em and test them out for us.
nageotte is offline Find More Posts by nageotte
Old May 14, 2011, 09:30 AM
S.E.Michigan
Joined Jul 2010
Are there any reapers in the cape cod area? I will be vacationing there this year and would like to know some RC friendly sites, hopefully beaches.!
Pat
Old May 14, 2011, 10:28 AM
bamabaxter is offline
Find More Posts by bamabaxter
bamabaxter's Avatar
United States, MS, Clinton
Joined Apr 2010
Is this the same motor as the Turnigy?
http://www.rctimer.com/index.php?gOo...5&productname=
bamabaxter is offline Find More Posts by bamabaxter
Old May 14, 2011, 11:01 AM
Lee is offline
Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
YES!!!!
I added it to the shopping list.
Thanks!!!!
Old May 14, 2011, 01:43 PM
nageotte is offline
I can fix it.
nageotte's Avatar
Cochranton, Pa.
Joined Nov 2005
Lee,
Your response shows a bit of excitement. That is the one we ordered. I see the C-clip groove on the end of the shaft so assume that we can drive the shaft through the motor. We'll find out.
Old May 14, 2011, 01:54 PM
doggit is offline
doggit's Avatar
Joined May 2009
for us in england and euroland i found this one, seems very similar http://www.modelaccessories.co.uk/dy...ess-motor.html
carl
ps, just ordered the RC timer version, it was cheaper with postage to the UK than modelaccessories was, very strange
Old May 14, 2011, 06:01 PM
Lee is offline
Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
The Turnigy 3530 1700 said it had -4 now it says 0. I wonder if some came in?
I'm ordering 4 of the motors from RCTimer and some replacement 4 mm E clips which I lost one of today.
Sold Reaper GR60 Stagger_Wing Aircraft - Electric - Power Systems (FS/W) 0 Jan 13, 2010 01:43 AM
Sold Reaper GR 60 wrpsr1911 Aircraft - Electric - Power Systems (FS/W) 0 Jan 06, 2010 09:28 PM
Build Log House of Balsa "Grim Reaper" P51 Mustang Gun Jam Electric Warbirds 28 Dec 20, 2009 03:25 PM
Discussion Body count... Grim but it's really gotta be done. Bilbobaker Life, The Universe, and Politics 15 Nov 15, 2009 01:09 PM
Gallery Grim reaper Wickett R/C Pumpkin Contest 1 Oct 31, 2005 04:37 PM
