Maiden report. WOW. that was a lot of fun. It was finless. I tried an 1800 mah first because I already had one on hand. it was 147 grams. So this put my AUW at 27.30 OZ.!! I was really pleased with that number.
It's cut down to 50", drilled motor mount and radiused to fit motor with no extra to reduce weight 20%. I used 1" extreme tape for the spar covers. 1.25" for the cross tape of formica plate. And I omitted the upper formica plate for now. I used 2 nylon .25" screws, with nuts and large washers to distribute pinch force for motor mount. I did not use fins for my 2 flights this evening. I will be trying various methods as the yaw is significant with any deceleration or basically anytime the elevons go from significant travel, to straight. Not that it makes it fall out of the sky or anything, its just not "clean and controlled" looking. Of course Lee has already stated this so no surprise here. The acceleration was very unexpected, when cruising at 3/8ths throttle then hit 100% it launches. Verticle was impressive, I did not go verticle too high altitude as i'm trying out a small size rx that I did not do any long range tests on yet. Roll rate was really surprising, even though I still have the elevon travel set a little too high, I will probably try moving links down to middle on the horns. But the roll rate was scary fast for the span that it has.! It loops in what looks like a 8-10ft diameter circle, Glide is exactly as others have described. REALLY LONG. Remember, I am used to high angle dropping my assassin down like a carrier landing.! It took 3 tries to keep it within walking distance, I had some big puddles to deal with so it did really needed to be pretty close to me.! The 2200mah batts that I picked up on my way home are a little over 1 oz heavier than the 1800 I first tried. So this should make my AUW around 28.4 oz. Still pretty good. Thanks again Lee, can't wait to make some contact. Pat |
Wondering how the CG turned out with the 1800mah batteries? I measured the CG on mine 10-1/2" back from from the point on the nose of the plane and I'm still tail heavy? I'm using the HK 3530-1700 Kv motor & 7x6 prop and HK Zippy 2200mah battery with the edge of the battery corners almost touching the front spars. I have not flown it yet as I still waiting for a couple of items. Wondering what others are seeing on CG with similar set-up's.
USA, FL, Gainesville
Joined Aug 2010
Wheelspinner20- Congrats on such a light frame. 28.4oz is impressive. I am at 61.2oz but plan on loosing some weight at SEFF with a lighter motor. Currently at little over 100mph but will fix that problem soon.
Tailwind1- 10-1/2" back is acceptable and what most are at now. From 9-1/2" to 10-1/2" I found acceptable. |
Tailwind, the 1800 was a temporary get it in the air thing. I taped it on, and yes to get the cg to my best measure was 10 3/8" the 1800 was way up there. The 2200 zippy flightmax that I installed ended up about a .25 to .375 behind the fiberglass spars. with the cg in about the same area. this is probably at or near the aft limit. It is very responsive.!
Video coming soon... has an awesome day in 20+ mph winds, which, even though I tried, I could not really safely fly anything else in this wind today.! Still grinning like a child.! Pat |
Like Kid Rock says... it aint braggin if you back it up.!
Submitted for you approval with pride. Lee love the product. Thanks Mike for the video, appreciate it. I have on-board vid too, just didnt get it edited into this one.
One of the best things about the Grim is we will fly them on days that we wouldn't even think of flying our other planes. We have been known to fly combat on days where we can all just park our planes in one spot and almost hover until we hit each other. The Grims are flyable in a 30mph wind and I would guess even more. They have really helped us get a lot more stick time. Looks like you are having fun! I love to see the Grims take abuse
Glad to see your technique for launching and catching the plane. Not bad for this size of a plane but you are making it look easy. If you want to make it a little easier stand so the plane is coming directly at you through the goal with the nose of the plane heading into the wind. (the wind is at your back.) Don't stand to the side. You had the wind right but it is easier if you change the place you are standing. Adding a little low throttle helps to keep the speed up for more control and it won't drift as much. Do a landing approach and bring her through. Last Uncivil war I gave away a plane to the first person who flew through inverted. The limbo wire was about 2 feet off the ground. Lee . |
Looking back at it, I didnt really try the limbo too much again, so I'm gonna chalk that one up to dumb luck. ! Although if I can do that one a few times, a soccer goal is going to seem huge and easy. For sure if I had the rescources, I would definately get out there to utah for the un-civil war. Just out of curiousity, do most that come bring spares? At a big event like that, what is the average carnage? It must be handfuls of props and saver rings. Horns, rx's?? A guy asked me the other day, how do you keep score with something like that?? is it honor system for hits, or is it the last one flying or what? |
After the war there are always a few planes that will never be the same. A few prop stabs and broken props are the rule but I personally have never had a plane that never flew again. I usually take about 6 planes to the war. If something breaks I switch planes so I don't loose flying time.
I made the mistake the last couple of years of not spending enough time with the camera in hand. We used to have a photographer who shot some great video from unusual angles. I talked to him this week and he is stuck in Texas. The cameras have to be running to catch the best stuff. |
| Thread Tools | |
| Sold Reaper GR60 | Stagger_Wing | Aircraft - Electric - Power Systems (FS/W) | 0 | Jan 13, 2010 01:43 AM |
| Sold Reaper GR 60 | wrpsr1911 | Aircraft - Electric - Power Systems (FS/W) | 0 | Jan 06, 2010 09:28 PM |
| Build Log House of Balsa "Grim Reaper" P51 Mustang | Gun Jam | Electric Warbirds | 28 | Dec 20, 2009 03:25 PM |
| Discussion Body count... Grim but it's really gotta be done. | Bilbobaker | Life, The Universe, and Politics | 15 | Nov 15, 2009 01:09 PM |
| Gallery Grim reaper | Wickett | R/C Pumpkin Contest | 1 | Oct 31, 2005 04:37 PM |
