Joined Jan 2013
Considering a 6 x 5 prop Phoenix Ice lite 100 ESC - http://www3.towerhobbies.com/cgi-bin...P?I=LXXXU0&P=8 MAXHC3514-2900 HIMAX 3514 2900KV 800 WATT BRUShLESS OUTRUNNER MOTOR http://www.gravesrc.com/HIMAX_3514_2...c3514-2900.htm 3300mah 3s 40c Battery http://www.gravesrc.com/BLASTER_RC_3...300x3bla40.htm |
I have never used that motor and ESC and prop set up but the 800 watt and the size of the ESC sounds like it has potential to go fasst. You will have to do some bench testing before launching and check the amps and see if the battery and ESC are running hot.
Have you had this motor on a plane before? How fast did it go? How much did it weigh? With a 6x5 prop on 800 watts put your earplugs in. |
My buddy used to have a CTH Grim Reaper a while back and he flew the heck out if it. He'd try something, ram it into the ground, then toss it back up into the air again. I have wanted to build one for a long time now so I bit the bullet and built two of them. One for myself and one for him. This was my first foam wing build ever. Should be able to maiden them Sunday. They are pics from my phone, sorry for the lack of clarity.
Grim Reaper CG Balance
Well I've been flying my Grim Reaper for a about a year with the it being a little tail heavy. It flew fine but with the quirks of any tail heavy aircraft. I finally got around to putting it on my balancer this afternoon and set the CG spot on at 10.5", then I went out and flew. The correct CG smoothed out the flying and at lower speeds no balloning or tail wag. The funny part was the landing. I'm used to gliding it right to my feet. Well today it kept gliding, and gliding, it almost clobbered me. Now that would have been hard to explain.
USA, FL, Gainesville
Joined Aug 2010
I've seen suggestons to put the electonics in container with uncooked rice to draw the moisture away. Not sure have effective it will be in the end. Here's a link (ton of suggestions out there). http://www.apartmenttherapy.com/how-...fully-s-107945
I've been following your build/flying of the DR XL. Eventually I want to go that way for longer distance. I did talk one of my flying buds into one. Well it was more like, hey, you're always flying my Grim Reaper why don't you get your own. You should get the one that's a little larger I heard it flys better. As soon as he gets it built it will be my turn to fly his aircraft. |
So frustrated now.. I wired up both my batteries in series, plugged it into the esc and it fried both capacitors, and melted some of the wires. The neg wires from the esc to Dragonlink, then Dragonlink to sbec. And also my servo wires. I was powering sbec/servos/dragonlink from one of the batteries balance port.
Australia, QLD, Mountain Creek
Joined May 2012
Getting there, I hope to maiden on the weekend. Lee, that supplier we talked about never bothered to reply, I guess sending out to Australia was too hard. Anyway, found a local substitute, doubtfull about the UV protection but any laminate in a storm.
| Thread Tools | |
| Sold Reaper GR60 | Stagger_Wing | Aircraft - Electric - Power Systems (FS/W) | 0 | Jan 13, 2010 01:43 AM |
| Sold Reaper GR 60 | wrpsr1911 | Aircraft - Electric - Power Systems (FS/W) | 0 | Jan 06, 2010 09:28 PM |
| Build Log House of Balsa "Grim Reaper" P51 Mustang | Gun Jam | Electric Warbirds | 28 | Dec 20, 2009 03:25 PM |
| Discussion Body count... Grim but it's really gotta be done. | Bilbobaker | Life, The Universe, and Politics | 15 | Nov 15, 2009 01:09 PM |
| Gallery Grim reaper | Wickett | R/C Pumpkin Contest | 1 | Oct 31, 2005 04:37 PM |
