Old Jan 22, 2013, 04:06 PM
Lee is online now
Lee
Find More Posts by Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
The 3536-1800 is the motor we are using on similar planes with 3S batteries. Once it is airborne we are usually only be running part throttle anyway. Which prop are you using?
Lee is online now Find More Posts by Lee
Old Jan 22, 2013, 08:40 PM
E1Allen is offline
Find More Posts by E1Allen
UH60 Pilot
E1Allen's Avatar
United States, KY, Fort Campbell
Joined Jan 2010
9x6 apc e
E1Allen is offline Find More Posts by E1Allen
Old Jan 22, 2013, 09:04 PM
E1Allen is offline
UH60 Pilot
E1Allen's Avatar
Joined Jan 2010
I really want to do a 6s setup, trying to find the right combo
Old Jan 22, 2013, 11:07 PM
Lee is online now
Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
You should be fast. I would definitely do a bench test for amps and heat but you should be able to get a combination that will work.
Old Jan 22, 2013, 11:28 PM
minegun2 is offline
Find More Posts by minegun2
United States, FL, Key Largo
Joined Apr 2011
good lord i couldnt imagin this thing on a highspeed 6s setup. things already fast, any faster is just being a giant wing of death, for anything it hits, be good for zombies with that speed thoe lmao
minegun2 is offline Find More Posts by minegun2
Old Jan 23, 2013, 01:43 AM
omelette is offline
Find More Posts by omelette
I didn't think it'd do that
omelette's Avatar
Australia, TAS
Joined Nov 2011
Hi Lee, what speeds are you guys achieving? , I'm running 3s 2x3000mah, 3536-1400 and a HKing 9x6 folding prop, carries a gopro, vtx, board camera, and a fy31ap flight stabiliser. 50mph straight and level at full throttle is best she'll do. Is this reasonable for the combo?
omelette is offline Find More Posts by omelette
Old Jan 23, 2013, 06:14 PM
E1Allen is offline
UH60 Pilot
E1Allen's Avatar
Joined Jan 2010
Well, I think I found the right motor. 700kv 6s swinging a 11x7 prop. Supposed 7lb of thrust on my 6.5lb reaper.
http://www.headsuprc.com/servlet/the...trunner/Detail
This is the motor.
Old Jan 24, 2013, 07:19 AM
brettskermetzger is offline
Find More Posts by brettskermetzger
United States, KY, Cold Spring
Joined Jul 2012
Nice looking motor there...Look forward to seeing the difference!
At what size does the the props start to become a little to large for the deep reaper? Or is there even such a thing?
brettskermetzger is offline Find More Posts by brettskermetzger
Old Jan 24, 2013, 05:38 PM
elCapitan is offline
Find More Posts by elCapitan
wheeeeee!
elCapitan's Avatar
United States, UT, Provo
Joined Oct 2011
As long as you cut away the foam on the trailing edge (before installing the shock cord!) so that the prop has enough clearance, you'd probably run into problems with high watts before running into problems with the fit of the prop.
elCapitan is offline Find More Posts by elCapitan
Old Jan 24, 2013, 06:34 PM
E1Allen is offline
UH60 Pilot
E1Allen's Avatar
Joined Jan 2010
Ah yes, I will have to redo the shock cord, probably try to keep it intact or retie it to fit the larger prop
Old Jan 27, 2013, 06:46 PM
KD0ZEQ is offline
Find More Posts by KD0ZEQ
Aviation Enthusiast
KD0ZEQ's Avatar
United States, CO
Joined Nov 2012
Reaper XL
I have my reaper almost ready to go . I am using it for my FPV platform. My delay is this .. i really do not want to maiden with FPV gear cause you never no. I have 2 4000 3s Zippy. Am getting ready to cut in wing for placement but what about when am ready to put fpv gear on?That will change the cg and have to recut and move batteries. Does this sound right.? Any suggestions?
KD0ZEQ is offline Find More Posts by KD0ZEQ
Old Jan 27, 2013, 07:11 PM
E1Allen is offline
UH60 Pilot
E1Allen's Avatar
Joined Jan 2010
No, even if you don't have fpv gear or a Gopro like I didn't during the build I still took pennies on my scale and made weights roughly the same as the fpv gear. I balanced that with the batteries in the right location so no issues with cg. Should only cut battery holes once. If your cg is real close like that it should be almost identical with FPV gear.
Old Jan 27, 2013, 07:17 PM
E1Allen is offline
UH60 Pilot
E1Allen's Avatar
Joined Jan 2010
You can see the pennies I used in this picture
Old Jan 27, 2013, 07:36 PM
KD0ZEQ is offline
Aviation Enthusiast
KD0ZEQ's Avatar
United States, CO
Joined Nov 2012
Yup . Sounds good just need to get myself a little scale. Was thinking that was probably a option. Nice not to be in the dark about it.
Thanks for reply and pic
Old Jan 27, 2013, 07:43 PM
KD0ZEQ is offline
Aviation Enthusiast
KD0ZEQ's Avatar
United States, CO
Joined Nov 2012
Post #7
O.k what a great idea and am definitely makeing one. The battery parallel soldered up useing deans without wire. I bought a castle parallel harness and weighs a lot and also to much wire. I saw pics of details Thread post #7. very cool
Sold Reaper GR60 Stagger_Wing Aircraft - Electric - Power Systems (FS/W) 0 Jan 13, 2010 01:43 AM
Sold Reaper GR 60 wrpsr1911 Aircraft - Electric - Power Systems (FS/W) 0 Jan 06, 2010 09:28 PM
Build Log House of Balsa "Grim Reaper" P51 Mustang Gun Jam Electric Warbirds 28 Dec 20, 2009 03:25 PM
Discussion Body count... Grim but it's really gotta be done. Bilbobaker Life, The Universe, and Politics 15 Nov 15, 2009 01:09 PM
Gallery Grim reaper Wickett R/C Pumpkin Contest 1 Oct 31, 2005 04:37 PM
