Looking good.... Shoot some good video for us to see....
You don't have to add a lot of weight to get some color on the plane. I like the thinner economy thickness of the colored packing tape. It works well with clear lights to create colors for night flying. If you use colored lights the tape will block some of the light spectrum. The actual weight of the tape is very low and as long as you don't use too much will make your plane easier to stay oriented to. http://www.findtape.com/product343/J...Packaging+Tape |
I have had a couple of questions on E-mail about wing thickness and which plane is best for certain set ups.
The two planes I want to compare are the Deep Reaper and the Hercules. Both of these are low drag, high lift designs that are relatively easy to launch and will glide at low speed without instability. Neither of these designs has a snap roll tendency if they are build well and if they are not flown tail heavy. The Deep Reaper has a 61 inch span and the Herc Pusher has a 63" span. They aren't that much different in wing span but the Herc is deeper. They can fly with the same motors and servos but the Herc can handle bigger motors and heavier batteries. Both planes can fit in my Corolla with the passenger seat laid back so they are easy to transport. I designed both with thinner airfoils to decrease drag and to make them as efficient and stable for their size as I could. The Herc is 2.25" thick and the Deep Reaper is 1.6" thick. This is a significant difference and needs to be considered when you are looking at which batteries and cameras you want to carry. It is easier to mount the GoPro in the Herc but some of our best FPV videos on our web site were taken with a Gopro on the Deep Reaper. http://crashtesthobby.com/video-gallery |
United States, FL, Key Largo
Joined Apr 2011
do u think my 480 1024 kv motor would be able to swing a 9x4 i guess u could say, anygood? i got a 60amp esc and from what i have read i could easly drop down to a 30 amp or even a 20, and i got wo 20 amp escs, im currently useing a 10x7 but i thought id be quiter, its just as loud as any of my 2200 6x4 setup pusher planes. and id get more flight time if i prop down another size, so what u guys think?
Ok. just got done with my first FPV flight with the Deep Reaper XL, what a blast. I flew for about 40 minutes and went out according to google earth about 1.75 miles with the stock omni antennas. I'm going to charge the batteries to see how much MAH was used but they were still showing 3.8v left and I was probably flying most of the time at 50%throttle or higher. I don't have osd or current sensor so not sure how many amps I was pulling or what have you but I did have a good time.
Eric |
Eric, I have to agree with ^, but congrats!!!!!
Latest blog entry: SS FPV Maiden
Ferndale WA
Joined Dec 2006
Reaper
Hi Le e,
I am considering buying a Grim Reaper kit and am having problems on the Crash Test Hobby site finding the page of recommended parts. When I click that button I get a link to the shopping list and that page has lots of links but seems to be for other planes. How do I find the recommended parts for the only the Grim Reaper? Thanks for the help. When I went to your site my computer never did stop trying to load. I know you have lots of videos but maybe the loading problem is why it hasn't loaded the page of recommended parts?? Thanks again. David |
I'm thinking once visual sight is lost at a couple hundred feet or whatever beyond that wouldn't make much difference would it? Still had great video feed, plan on getting cp antenna and osd in the near future. Also upgrading to 6s, this 6.4lb wing needs to cruise faster at a lower throttle setting.
The small planes are at the top of the list and the bigger planes at the bottom. We used to have a list for each plane but it was always out of date and links were not working so we made a single list for all the planes. The pictures below are all of the same plane. . |
My first FPV flight. Deep Reaper XL with 16,000 mah gave me 40 minutes of flight at more than half throttle buzzing around. Went out 1.75 miles and back. Dragonlink V2 and 1.3g video. Thanks flohio177 for coming out and helping. |
| Thread Tools | |
| Sold Reaper GR60 | Stagger_Wing | Aircraft - Electric - Power Systems (FS/W) | 0 | Jan 13, 2010 01:43 AM |
| Sold Reaper GR 60 | wrpsr1911 | Aircraft - Electric - Power Systems (FS/W) | 0 | Jan 06, 2010 09:28 PM |
| Build Log House of Balsa "Grim Reaper" P51 Mustang | Gun Jam | Electric Warbirds | 28 | Dec 20, 2009 03:25 PM |
| Discussion Body count... Grim but it's really gotta be done. | Bilbobaker | Life, The Universe, and Politics | 15 | Nov 15, 2009 01:09 PM |
| Gallery Grim reaper | Wickett | R/C Pumpkin Contest | 1 | Oct 31, 2005 04:37 PM |
