Old Jan 16, 2013, 10:36 AM
fnffishcore is offline
Find More Posts by fnffishcore
fnffishcore's Avatar
United States, MD, Chesapeake Beach
Joined Jan 2011
Originally Posted by ashdec87 View Post
Does anyone use prop savers? I have one on mine, but I dont know how much help it is. Plus I think the rubber bands are cheap because they keep breaking in storage. I currently have two bands on there as I push 500w at WOT.
In my opinion, you get too much vibration when using prop savers on larger props or higher KV motors. I tend to stay away from them.
fnffishcore is offline Find More Posts by fnffishcore
Old Jan 16, 2013, 11:24 AM
elCapitan is offline
Find More Posts by elCapitan
wheeeeee!
elCapitan's Avatar
United States, UT, Provo
Joined Oct 2011
I use prop savers on all my planes, except where i have folding props. I get rubber bands from home depot, and go a little thicker than the ones they come with
elCapitan is offline Find More Posts by elCapitan
Old Jan 16, 2013, 01:02 PM
Lee is offline
Lee
Find More Posts by Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
I use #12 and #15 plumbing O-rings from Home Depot for the pushers but I don't use prop savers on the big motor pullers. The puller props like to come off and go shooting into space.
I have also cut surgical tubing into thicker bands that work but I think the O-rings are easier and stronger.
Lee is offline Find More Posts by Lee
Old Jan 16, 2013, 01:15 PM
ashdec87 is offline
Find More Posts by ashdec87
ashdec87's Avatar
United States, MI, Detroit
Joined Feb 2004
Ok I'll try those. These stupid bands break for no reason....
ashdec87 is offline Find More Posts by ashdec87
Old Jan 16, 2013, 01:44 PM
E1Allen is offline
Find More Posts by E1Allen
UH60 Pilot
E1Allen's Avatar
United States, KY, Fort Campbell
Joined Jan 2010
So I used a prop calculator on the 3536-1800 and supposedly the 9x6 is pulling more amps than recommended. As I don't have any way to measure, does someone know what theirs pulls?
E1Allen is offline Find More Posts by E1Allen
Old Jan 16, 2013, 02:04 PM
Joined Jan 2011
The original motor I had on my Grim Reaper -- one of those C-3530 1700KV motors from PlaneInsaneRC -- used a 7x6 prop, as recommended. That's on 3S. Off the bat, a 9x6 prop on a 3536-1800KV motor seems too large. For reference, I use a 9x6 prop on a 3536-1450KV now, and that draws well under the max recommended amps.
Old Jan 16, 2013, 05:44 PM
kid at 55 is offline
Find More Posts by kid at 55
Where did that tree come from
kid at 55's Avatar
United States, SC, Lancaster
Joined Nov 2010
Originally Posted by kid at 55 View Post
Are the 2200 mAh 3cells battery too small for the Grim Reaper to get the CG right ?
Not necessarily, depends where you place it and the rest of your electronics. Keep the wing tips light and you might be ok
Originally Posted by elCapitan View Post
actually, I think a 2200mAh 3S is probably the most popular battery for the Reaper, but in the end it really is all about CG.
Before you dig in your electronics, what a lot of people do is measure where CG should be, on the bottom of the wing, stick a couple pushpins in, and lay the electronics on the top. Try to balance the wing on the pins, and shift the electronics on top as needed, until you're balanced. Then mark where everything is, and cut the bays.
Thanks guys.
kid at 55 is offline Find More Posts by kid at 55
Old Jan 16, 2013, 06:31 PM
E1Allen is offline
UH60 Pilot
E1Allen's Avatar
Joined Jan 2010
It does seem too large, could I reduce the maximum throttle setting to not exceed the max amps?
Old Jan 16, 2013, 07:03 PM
minegun2 is offline
Find More Posts by minegun2
United States, FL, Key Largo
Joined Apr 2011
what are some good cheap 2200mah batterys? there are so many out there and i need new batterys since my other ones are either A, burnt out (like wont hold charge anymore) or B, look like then are destroyed and very dangerous to fly with) and i dont want to have three diffrent batterys to fly with anymore, and i was also thinking of maby running two 2200mah batterys in paralle, or running two 1500s or 1800s, what do u guys think? should u run the 2200s? or go smaller ones maby?
minegun2 is offline Find More Posts by minegun2
Old Jan 16, 2013, 07:22 PM
ashdec87 is offline
ashdec87's Avatar
Joined Feb 2004
Try the Nanotech from hobbyking. The nanotechs I have are AMAZING and CHEAP
Old Jan 16, 2013, 07:42 PM
E1Allen is offline
UH60 Pilot
E1Allen's Avatar
Joined Jan 2010
Yeah, and order from USA site
Old Jan 16, 2013, 08:23 PM
Joined Jan 2011
That, I do not know. I really only know the basics of my radio, so mayhaps that's possible? Why not just keep it simple and prop down a size or two?
Old Jan 16, 2013, 08:51 PM
E1Allen is offline
UH60 Pilot
E1Allen's Avatar
Joined Jan 2010
I probably will, but until new ones come in I'm going to FPV maiden this thing Friday or Saturday
Old Jan 17, 2013, 12:02 AM
wheeeeee!
elCapitan's Avatar
Joined Oct 2011
Yep, Turnigy nanotech are pretty much all i buy now
Old Jan 17, 2013, 01:47 AM
E1Allen is offline
UH60 Pilot
E1Allen's Avatar
Joined Jan 2010
Just finished my first fpv wing. I opted for less color as it already weighs 6.4lbs.
61" Deep Reaper XL
1.3g 800mw
Dragonlink V2
16,000mah. 3s parallel
Looking forward to FPV maiden flight this weekend.
Sold Reaper GR60 Stagger_Wing Aircraft - Electric - Power Systems (FS/W) 0 Jan 13, 2010 01:43 AM
Sold Reaper GR 60 wrpsr1911 Aircraft - Electric - Power Systems (FS/W) 0 Jan 06, 2010 09:28 PM
Build Log House of Balsa "Grim Reaper" P51 Mustang Gun Jam Electric Warbirds 28 Dec 20, 2009 03:25 PM
Discussion Body count... Grim but it's really gotta be done. Bilbobaker Life, The Universe, and Politics 15 Nov 15, 2009 01:09 PM
Gallery Grim reaper Wickett R/C Pumpkin Contest 1 Oct 31, 2005 04:37 PM
