Old Jan 08, 2013, 09:26 PM
randkbrown is offline
Find More Posts by randkbrown
United States, UT, Ogden
Joined Feb 2012
Here is myDeep Reaper with 30 hours of flight time. Makes it easy to fly when it is from my backyard that includes a landing strip.
Landing Strip (0 min 44 sec)
randkbrown is offline Find More Posts by randkbrown
Old Jan 08, 2013, 09:48 PM
E1Allen is offline
Find More Posts by E1Allen
UH60 Pilot
E1Allen's Avatar
United States, KY, Fort Campbell
Joined Jan 2010
Esc does not get hot. Sounds like I can swing leaving just the top exposed. Already creating enough drag from fpv gear I plan to use
E1Allen is offline Find More Posts by E1Allen
Old Jan 08, 2013, 10:16 PM
cmaynex is offline
Find More Posts by cmaynex
United States, CT, New Haven
Joined Dec 2011
I need to get a speed gun and see what my Reaper is doing on NTM 3536 1800KV with a 7x6 prop on 4s. Usually I fly on 3s with a 8x4 and 8x6 prop.
cmaynex is offline Find More Posts by cmaynex
Old Jan 08, 2013, 10:47 PM
brosius85 is offline
Find More Posts by brosius85
never mind the boll⁣⁣⁣ocks
brosius85's Avatar
Australia, NSW
Joined Dec 2010
you could try using RCSpeedo APP, works off the audio to get airspeed.
brosius85 is offline Find More Posts by brosius85
Old Jan 09, 2013, 03:27 AM
Austang is offline
Find More Posts by Austang
Been There, Crashed That!
Austang's Avatar
Australia, WA, Geraldton
Joined Jul 2011
Here is a video of the second flight of my Reaper, I didn't video the maiden, also ignore the date code, I haven't changed it.
017 (3 min 45 sec)
Austang is offline Find More Posts by Austang
Old Jan 09, 2013, 06:45 AM
Lee is offline
Lee
Find More Posts by Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
I like the videos from all over the world. Thanks for posting them.
I have the App "RCSPEEDO" It works well if you remember to be low and straight over your phone. A woman's voice will even verbalize the speed so you know if it came through. It's when that voice starts telling you how to fly it gets annoying... just joking.
I will turn the app on and put the phone in my pocket and as long as the plane is close it will get a reading and I can hear the voice telling me the speed. All of the speeds are posted on the screen until you turn the app off which is nice.
To get a speed on Doppler like this you need to fly straight over without a turn or it fouls up the sound and you will not get accurate readings.
Lee is offline Find More Posts by Lee
Old Jan 09, 2013, 08:04 AM
E1Allen is offline
UH60 Pilot
E1Allen's Avatar
Joined Jan 2010
Originally Posted by elCapitan View Post
That's exactly how my DRXL is set up, with the same motor and same size esc. No problems yet.
On 3s do you know the max amps it's going to pull?
Old Jan 09, 2013, 12:48 PM
ashdec87 is offline
Find More Posts by ashdec87
ashdec87's Avatar
United States, MI, Detroit
Joined Feb 2004
Originally Posted by Lee View Post
Actually we clock the Reaper at an actual speed of 80+ mph with the 3530-1700 kv and some flyers going 4S are over 100 mph and I have heard of 6S over 120 mph. It's all a power to drag/weight ratio. Just make sure you use big servos and reinforce your linkages if you go this fast.
Oh I meant at idle/gliding
ashdec87 is offline Find More Posts by ashdec87
Old Jan 09, 2013, 09:49 PM
Lee is offline
Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
Low end speed has to do a lot with weight. The lighter it is the lower the slow speed flight and the slower the stall. If you load up a plane the glide could be in the 20s but the nice thing is this design remains stable to lower speed than most other flying wings of this size.
Old Jan 10, 2013, 07:44 PM
ashdec87 is offline
ashdec87's Avatar
Joined Feb 2004
ya, based on GPS (Just installed a pitot tube), the plane likes to approach at about 20-23 mph, stall is about 15mph. My plane is very heavy, but it flies amazing, even at slower speeds. I once tried to climb, but forgot to increase power (flying FPV). It took me a few seconds to figure out why the plane wouldnt climb, and why the wings were rocking back and forth. But I never lost control. I just gave 3/4 throttle and climbed right out. You made a great plane!
Old Jan 11, 2013, 07:06 PM
E1Allen is offline
UH60 Pilot
E1Allen's Avatar
Joined Jan 2010
I'm all bummed, only flown my reaper once so far. So much going on...
Old Jan 11, 2013, 07:48 PM
ppridday is offline
Find More Posts by ppridday
Breaker of Things
ppridday's Avatar
United States, MN, Detroit Lakes
Joined Mar 2005
You're bummed! Mine is at home waiting to be built and I am still 8 days from being there. Once I get there I only have 5 days at home and then back out for 16 days. In the meantime I'll have about 2-3 days of honey do's.
BTW, what do you think about glueing in the shock cord at the motor mount area and letting it set and then doing the rest so the motor mount area doesn't pull loose when tightening up the cord??
Paul
ppridday is offline Find More Posts by ppridday
Old Jan 11, 2013, 07:58 PM
elCapitan is offline
Find More Posts by elCapitan
wheeeeee!
elCapitan's Avatar
United States, UT, Provo
Joined Oct 2011
Not sure what you mean, here. It won't really matter which you do first, put in the shock cord, or glue on the Formica plates. You shouldn't be tightening the cord so much that the foam distorts in any way.
It may be a bit easier to access the slot for the shock cord without the Formica plates in the way, but structurally, there won't be any difference. Don't the instructions have you putting the shock cord in right after gluing the halves together anyway?
elCapitan is offline Find More Posts by elCapitan
Old Jan 11, 2013, 08:13 PM
ppridday is offline
Breaker of Things
ppridday's Avatar
Joined Mar 2005
Yes, the shock cord does go in right after. I thought the shock cord would have to be snugged up semi tight to be effective. Not enough to distort the foam but enough to put some kind of compressional load on the perimeter. At that point I figured it would be enough to pull the cord out of the cut out area of the motor bay.
I guess I should just wait to build mine and then ask questions... I'm sure there will be lots.
Paul
Old Jan 11, 2013, 08:17 PM
wheeeeee!
elCapitan's Avatar
Joined Oct 2011
You're thinking right. Snug, but not pulling anything out of shape. Once you get it in there, you'll find the friction will keep the cord in just fine. Just follow the instructions.
Sold Reaper GR60 Stagger_Wing Aircraft - Electric - Power Systems (FS/W) 0 Jan 13, 2010 01:43 AM
Sold Reaper GR 60 wrpsr1911 Aircraft - Electric - Power Systems (FS/W) 0 Jan 06, 2010 09:28 PM
Build Log House of Balsa "Grim Reaper" P51 Mustang Gun Jam Electric Warbirds 28 Dec 20, 2009 03:25 PM
Discussion Body count... Grim but it's really gotta be done. Bilbobaker Life, The Universe, and Politics 15 Nov 15, 2009 01:09 PM
Gallery Grim reaper Wickett R/C Pumpkin Contest 1 Oct 31, 2005 04:37 PM
