Old Jan 06, 2013, 09:40 PM
elCapitan is offline
Find More Posts by elCapitan
wheeeeee!
elCapitan's Avatar
United States, UT, Provo
Joined Oct 2011
Originally Posted by ashdec87 View Post
The windmilling prop does cause a huge amount of drag
...says you
elCapitan is offline Find More Posts by elCapitan
Old Jan 06, 2013, 09:52 PM
ashdec87 is offline
Find More Posts by ashdec87
ashdec87's Avatar
United States, MI, Detroit
Joined Feb 2004
Lol it does. Supposedly the same mount of drag as a solid disk the same size as the prop. Which is why full scale planes must feather a dead engine.
ashdec87 is offline Find More Posts by ashdec87
Old Jan 06, 2013, 11:00 PM
wheeeeee!
elCapitan's Avatar
Joined Oct 2011
See, and to me that makes zero sense. A spinning prop doesn't magically increase in surface area to that of a disc. At any given time, the same amount of prop is confronting air. The only question is with how much resistance it hits the air. A spinning prop at least gives way.
Now, I know that full scale planes do feather dead engines, but from what I've read, there's a point at which the combination of mass/airspeed/surface area of prop create a tipping point, where it's better to windmill than to brake.
Not being a physicist, all I know is this: setting the brake on an ESC is one more step between me and flying, and after a day of trying with/without brake on multiple wings, I noticed absolutely no difference. That's why I say let 'er swing.
Old Jan 06, 2013, 11:08 PM
nightfox7 is offline
Find More Posts by nightfox7
┌∩┐(⋟﹏⋞)┌∩┐ The FAA
nightfox7's Avatar
United States, GA, Cornelia
Joined Jan 2012
Well, i don't mean to feed the fire.. ive seen this discussion before.. but i always think of auto gyros.. maybe it's a whole different can of beans I say if you are that worried about aerodynamics to be concerned about spinning props or not, just get a folding prop and be done with it
nightfox7 is offline Find More Posts by nightfox7
Old Jan 06, 2013, 11:11 PM
ashdec87 is offline
ashdec87's Avatar
Joined Feb 2004
Lol exactly. Short of being in a gliding competion, I don't think there's an advantage for the brake.
Old Jan 07, 2013, 04:54 PM
michaelingp is offline
Find More Posts by michaelingp
United States, MD, Kensington
Joined Dec 2008
I've had the same experience. However, Google does reveal support for ashdec87's statements, no matter how non-intuitive. The studies I found involve twin engine planes when one engine quits. The pilot wants to continue flying on one engine, which means the dead engine's prop is going to want to turn almost the same speed as the engine that's running. To do that requires a LOT of power, hence a lot of drag.
We're not doing that with our planes. Usually the only time we're power off is landing, when more drag slows the plane down, usually what we want. I suspect at the lower speeds, the difference becomes negligible.
michaelingp is offline Find More Posts by michaelingp
Old Jan 07, 2013, 08:22 PM
ashdec87 is offline
ashdec87's Avatar
Joined Feb 2004
That's true, we're flying at 30mph tops, those planes are going 150+
Old Jan 07, 2013, 09:22 PM
E1Allen is offline
Find More Posts by E1Allen
UH60 Pilot
E1Allen's Avatar
United States, KY, Fort Campbell
Joined Jan 2010
And they can probably feather the blades as well, we can not
E1Allen is offline Find More Posts by E1Allen
Old Jan 08, 2013, 12:19 AM
wheeeeee!
elCapitan's Avatar
Joined Oct 2011
Right, but you're talking about a completely different motor, not a brushless. Even if you scaled down in size, the force required to spin a prop on one of those engines, due to friction, is a lot more than one of ours needs. That's the only reason it requires a lot of power in that scenario.
So not only does it make less difference at low speeds, but also at low internal friction in the motor.
Old Jan 08, 2013, 02:43 PM
Lee is offline
Lee
Find More Posts by Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
Actually we clock the Reaper at an actual speed of 80+ mph with the 3530-1700 kv and some flyers going 4S are over 100 mph and I have heard of 6S over 120 mph. It's all a power to drag/weight ratio. Just make sure you use big servos and reinforce your linkages if you go this fast.
Lee is offline Find More Posts by Lee
Old Jan 08, 2013, 06:29 PM
minegun2 is offline
Find More Posts by minegun2
United States, FL, Key Largo
Joined Apr 2011
i think mines pushing around 65 at top speed easy, it cruses around 35-40 maby. im still dialing it in, i flew it this morning the adjustments i made, made it fly alot better.
minegun2 is offline Find More Posts by minegun2
Old Jan 08, 2013, 08:20 PM
E1Allen is offline
UH60 Pilot
E1Allen's Avatar
Joined Jan 2010
Ok, need some collective input here, I have the 3536-1800kv motor. I went ahead and got a 80a esc since they claim the motor pulls max 60 whatever amps. I do have intentions on flying at a higher cruise speed and I am wondering if I can partially embed the esc into the wing and leave the top heat sink portion exposed? I just want to bury the bottom and the sides. Last time I flew the motor was warm but the esc was not. What do you guys think?
Eric
Old Jan 08, 2013, 08:24 PM
wheeeeee!
elCapitan's Avatar
Joined Oct 2011
That's exactly how my DRXL is set up, with the same motor and same size esc. No problems yet.
Old Jan 08, 2013, 08:26 PM
┌∩┐(⋟﹏⋞)┌∩┐ The FAA
nightfox7's Avatar
Joined Jan 2012
Eric
"Not", or "Hot"? i wouldn't see any reason to mount that way if the ESC wasn't even warm..
Old Jan 08, 2013, 08:45 PM
wheeeeee!
elCapitan's Avatar
Joined Oct 2011
That's how I mount all my esc's, either glued in that way, or with lam over the top. Only trouble I've had with an esc was the one I dunked in a lake
Sold Reaper GR60 Stagger_Wing Aircraft - Electric - Power Systems (FS/W) 0 Jan 13, 2010 02:43 AM
Sold Reaper GR 60 wrpsr1911 Aircraft - Electric - Power Systems (FS/W) 0 Jan 06, 2010 10:28 PM
Build Log House of Balsa "Grim Reaper" P51 Mustang Gun Jam Electric Warbirds 28 Dec 20, 2009 04:25 PM
Discussion Body count... Grim but it's really gotta be done. Bilbobaker Life, The Universe, and Politics 15 Nov 15, 2009 02:09 PM
Gallery Grim reaper Wickett R/C Pumpkin Contest 1 Oct 31, 2005 05:37 PM
