Old Dec 28, 2012, 11:14 AM
Lee is offline
Lee
Find More Posts by Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
Originally Posted by michaelingp View Post
Not sure I understand this one:
"Do my servos stall when I test the radio while holding the flight surface?"
Can you be more specific about how you test this and what the outcome should be?
Does this make more sense:
Can you stop the servo from turning by holding the elevon?
Tell me a better way to say it and I'll change the words.
Lee is offline Find More Posts by Lee
Old Dec 30, 2012, 12:45 AM
minegun2 is offline
Find More Posts by minegun2
United States, FL, Key Largo
Joined Apr 2011
my grim reaper came home today theres one thing im confused about is attacing the elevons to the wing? do i halft to tape them on first and then put the layer over them or do i layer them first and layer the wing body, and then apply tape? and then i add another later of monocote on top of the tape and part of the elevons again?
minegun2 is offline Find More Posts by minegun2
Old Dec 30, 2012, 01:48 AM
E1Allen is offline
Find More Posts by E1Allen
UH60 Pilot
E1Allen's Avatar
United States, KY, Fort Campbell
Joined Jan 2010
You should have laminated the wing and elevons first, then e tape the two pieces together then laminate over the tape.
E1Allen is offline Find More Posts by E1Allen
Old Dec 30, 2012, 04:15 AM
minegun2 is offline
Joined Apr 2011
thats what i though u were supose to do, just when i keep reading instructions it keept confuseing me.
Old Dec 30, 2012, 09:18 AM
elCapitan is offline
Find More Posts by elCapitan
wheeeeee!
elCapitan's Avatar
United States, UT, Provo
Joined Oct 2011
Laminate wing. Double-laminate both elevons. Hinge the elevons to the wing, top and bottom, with the 1" wide strip of tape. Finally, laminate over the tape (again, top and bottom) with a 2" wide strip of laminate.
Done.
elCapitan is offline Find More Posts by elCapitan
Old Dec 30, 2012, 11:45 AM
E1Allen is offline
UH60 Pilot
E1Allen's Avatar
Joined Jan 2010
Done.
Sounds good
Old Dec 30, 2012, 03:59 PM
minegun2 is offline
Joined Apr 2011
Done.
i have a standard ironer, and not a monocote ironer, what should i keep it on when i go to cover the plane? should it be below steam or cotton like 3 or 4?
Old Dec 30, 2012, 05:31 PM
E1Allen is offline
UH60 Pilot
E1Allen's Avatar
Joined Jan 2010
Well, you don't want to shrink it so I think the method was watch to see at what setting water boils off and right about there supposedly is good
Old Dec 30, 2012, 06:08 PM
minegun2 is offline
Joined Apr 2011
so ive started building im doing a slow build, cause i have no more hot clue and i need to go get another cheap soldering iron for the foam, but so far ive gorillaglused the two halfts of the wings together and i put the string around the airframe, that about it so far.
Old Dec 30, 2012, 09:11 PM
Lee is offline
Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
Take some scraps of laminate and iron them to the your box to get the feel and temperature right.
The laminate can take more heat than the foam. If you see the foam is changing shape your ironing too hot. Stop immediately and cool the iron.
I have a water spray bottle my my bench to rapidly cool the iron if needed.
Old Dec 30, 2012, 10:46 PM
E1Allen is offline
UH60 Pilot
E1Allen's Avatar
Joined Jan 2010
I have an iron cover, it gives me a good safety margin on the heat of the iron. I find it extremely helpful for the$2 or whatever it costs. Glides smooth over the laminate as well.
Old Dec 31, 2012, 03:26 PM
ppridday is online now
Find More Posts by ppridday
Breaker of Things
ppridday's Avatar
United States, MN, Detroit Lakes
Joined Mar 2005
Hey all, how does this look for an ESC for the Deep Reaper XL?
http://www.hobbyking.com/hobbyking/s...C_4A_UBEC.html
With a 4A BEC built in will I need a separate? I would be running this with the 35/36 1400W 550 Turnigy motor. Going to also pick up the BMS 620MG servo's. That should get me off to a good start....
Paul
ppridday is online now Find More Posts by ppridday
Old Dec 31, 2012, 04:02 PM
E1Allen is offline
UH60 Pilot
E1Allen's Avatar
Joined Jan 2010
For the price of an external becomes it never hurts to grab one and use it.
Old Dec 31, 2012, 04:12 PM
Breaker of Things
ppridday's Avatar
Joined Mar 2005
Wise words. I will grab one as well. The ESC would be suitable though?
Cheers,
Paul
Old Dec 31, 2012, 04:37 PM
E1Allen is offline
UH60 Pilot
E1Allen's Avatar
Joined Jan 2010
Looks suitable to me. I picked up an 80a one but I got the 3536 1800kv 70a is plenty. Your external bec can run your fpv gear as well
Sold Reaper GR60 Stagger_Wing Aircraft - Electric - Power Systems (FS/W) 0 Jan 13, 2010 01:43 AM
Sold Reaper GR 60 wrpsr1911 Aircraft - Electric - Power Systems (FS/W) 0 Jan 06, 2010 09:28 PM
Build Log House of Balsa "Grim Reaper" P51 Mustang Gun Jam Electric Warbirds 28 Dec 20, 2009 03:25 PM
Discussion Body count... Grim but it's really gotta be done. Bilbobaker Life, The Universe, and Politics 15 Nov 15, 2009 01:09 PM
Gallery Grim reaper Wickett R/C Pumpkin Contest 1 Oct 31, 2005 04:37 PM
