Old Dec 26, 2012, 05:19 AM
E1Allen is offline
Find More Posts by E1Allen
UH60 Pilot
E1Allen's Avatar
United States, KY, Fort Campbell
Joined Jan 2010
Looks like that motor/prop will do just fine if you already have one available.
E1Allen is offline Find More Posts by E1Allen
Old Dec 27, 2012, 12:05 AM
Xmod is offline
Find More Posts by Xmod
Australia, QLD, Mountain Creek
Joined May 2012
Hi all, just an idle question as I start my Reaper build, has anyone tried one of the 3 axis Gyro V2 from HK that will work on wings? I ordered one as part of my larger order because.. well...$17, why not?
I'd love to hear any reviews of the Gyro because if it works it would extend my flying day by hours. The winds get up here a couple of hours after sunrise and stay till sunset . The other trick is the new one has is that it can be switched on/off mid flight.
cheers
Chris
Xmod is offline Find More Posts by Xmod
Old Dec 27, 2012, 10:28 AM
hobie14 is online now
Find More Posts by hobie14
hobie14's Avatar
Western Europe 52.7° N 8.9° W
Joined Jul 2007
cheers
Chris
I've just ordered one and it might be fun to fit it on my Reaper ..... http://www.hobbyking.com/hobbyking/s...dProduct=28456 .....
just to see what it can do ......
I need to find out how to wire it up for the wing ...... that would be a good start! ..... so if anyone has an idea how to do it please post ..... no instructions loaded up yet under the HK files tab for the V2, so far .....
hobie14 is online now Find More Posts by hobie14
Old Dec 27, 2012, 01:14 PM
minegun2 is offline
Find More Posts by minegun2
United States, FL, Key Largo
Joined Apr 2011
i ordered the grim reaper a few ago xD
minegun2 is offline Find More Posts by minegun2
Old Dec 27, 2012, 10:21 PM
bchatch is offline
Find More Posts by bchatch
Bruce
AF, Utah, USA
Joined Nov 2009
I was going to install a pair of HS-82MG servos in a Grim Reaper that I'm finishing but notice that the larger standard size servo is now recommended if using a 35XX size motor. The HS-82 metal servos that I've used in my Titan and Assassin wings have held up great despite repeated abuse. A standard size servo with metal gears seams quite heavy and pricey when compared to the micro servos that I have always used. I'm not sure the non metal gear standard servo would last with the abuse I will give it.
One solution is the mini servo HS-225MG. It has more torque than a standard servo yet weighs only about 31 grams. It is more than twice the price of a standard servo at $26 each but I can live with that if it will hold up well.
Has anyone had experience with the HS-225MG, and is it a good match for a standard Grim Reaper that will see a lot of rough play?
bchatch is offline Find More Posts by bchatch
Old Dec 27, 2012, 10:29 PM
elCapitan is offline
Find More Posts by elCapitan
wheeeeee!
elCapitan's Avatar
United States, UT, Provo
Joined Oct 2011
I dunno, man, I've used the hs82mg's in all my larger planes except a Hercules. They've performed just fine. I fly pretty hard, too, on 3536 motors, and haven't had any stalls. I guess Lee either had enough experience, or enough people commenting to switch his recommendation, but personally, on a reaper-sized plane... I'll stick with the hs82mg
elCapitan is offline Find More Posts by elCapitan
Old Dec 27, 2012, 11:27 PM
minegun2 is offline
Joined Apr 2011
im gona use two mg90s, but i also got some bigger coronas servos too, i for got what size they are thoe, i know the are bigger the the mg90s thoe, and they are metal gear also
Old Dec 27, 2012, 11:40 PM
Lee is offline
Lee
Find More Posts by Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
The MG90s and the HS82MGs work, most of the time. We find people keep building our wings faster and faster and heavier and heavier until the smaller servos are overloaded. Linkage set up is also critical to maximize leverage. I know I harp on it but don't have a wreck for a preventable reason.
I dove someone elses high speed plane into the ground when it wouldn't pull out after a loop. If you think you are having trouble cut the throttle and get the plane on the ground at low speed, then check the linkages and servo strength before flying again.
Lee is offline Find More Posts by Lee
Old Dec 28, 2012, 04:27 AM
Austang is offline
Find More Posts by Austang
Been There, Crashed That!
Austang's Avatar
Australia, WA, Geraldton
Joined Jul 2011
I ordered these for the Grim Reapers we are getting, hopefully they will be strong enough, BMS-620MG High Torque Servo (Metal Gear) 9.1kg / .15sec / 50g, nice price too and we have had a good run with these servo's before.
http://www.hobbyking.com/hobbyking/s...idProduct=8776
Austang is offline Find More Posts by Austang
Old Dec 28, 2012, 05:54 AM
Lee is offline
Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
Those are great servos. The MG90s only have about 2Kg of torque which is less than 1/4 the torque of the BMS 620MGs. A little bit of extra strength makes a big difference.
The disadvantage is that they also weigh 50 gms which is why people like the small servos.
Your servo is the only communication you have with your elevon.
I own 40+ of the MG90 servos and recommend them for the smaller planes. They are cheap and light and fairly reliable but they aren't built for the high demand use of big planes at high speed.
My rule is that if the plane is flying with the 2812 motor use the MG90s. Anything bigger needs bigger servos.
Old Dec 28, 2012, 07:59 AM
fnffishcore is offline
Find More Posts by fnffishcore
fnffishcore's Avatar
United States, MD, Chesapeake Beach
Joined Jan 2011
I believe I posted these before, but it's worth reposting... After a nosedive and crash from pretty high up, I replaced the MG90S servos in my Grim Reaper with these much larger TowerPro MG995 Metal Gear Torque Digi High Speed Servo from RCTimer. They are much larger and weigh considerably more, but if it'll keep the elevons moving in a steep dive, I'll compromise And they're $13.99 for a set of 2, so the price is pretty hard to beat!
fnffishcore is offline Find More Posts by fnffishcore
Old Dec 28, 2012, 08:07 AM
E1Allen is offline
UH60 Pilot
E1Allen's Avatar
Joined Jan 2010
HXT 10kg Servo (metal gear) 55g / 10kg / .16sec
This is what I ended up throwing on my drxl.
Old Dec 28, 2012, 08:16 AM
Austang is offline
Austang's Avatar
Joined Jul 2011
Yeah Lee, I read about your mishap with someone else's plane and since I will be running this size motor (35-36A 1800Kv / 875w) with 4s battery's, I figured better safe than sorry.
Old Dec 28, 2012, 10:39 AM
Lee is offline
Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
It is always embarrassing to nose dive another flyers plane into the turf.
I was flying and doing some speed runs checking doppler speeds and I came around the back side of a Cuban 8 turn and it wouldn't pull out. Lucky it was an Assassin. All we had was a minor foam tear and a little dirt imbedded in the foam after the plane hit the ground at 80+ mph.
Normally an Assassin would be OK with the MG90s but he had put a big motor on it and hadn't maximized leverage using the full rotation of the servo.
http://crashtesthobby.com/articles/10-mistakes-to-avoid
Old Dec 28, 2012, 11:04 AM
michaelingp is offline
Find More Posts by michaelingp
United States, MD, Kensington
Joined Dec 2008
Not sure I understand this one:
"Do my servos stall when I test the radio while holding the flight surface?"
Can you be more specific about how you test this and what the outcome should be?
michaelingp is offline Find More Posts by michaelingp
Sold Reaper GR60 Stagger_Wing Aircraft - Electric - Power Systems (FS/W) 0 Jan 13, 2010 01:43 AM
Sold Reaper GR 60 wrpsr1911 Aircraft - Electric - Power Systems (FS/W) 0 Jan 06, 2010 09:28 PM
Build Log House of Balsa "Grim Reaper" P51 Mustang Gun Jam Electric Warbirds 28 Dec 20, 2009 03:25 PM
Discussion Body count... Grim but it's really gotta be done. Bilbobaker Life, The Universe, and Politics 15 Nov 15, 2009 01:09 PM
Gallery Grim reaper Wickett R/C Pumpkin Contest 1 Oct 31, 2005 04:37 PM
