Old Dec 23, 2012, 12:20 PM
Lee is online now
Lee
Find More Posts by Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
You often can see the flex in the linkage system best when the servos are pushing the rods not pulling. Do a couple of outside loops and see how the plane performs. To prevent accidents it is easier to go from inverted flight to an outside loop rather than diving at the ground hoping the plane will make the loop before you know for sure.
In normal flight mini servos work but we have seen that the stresses of the heavy planes and the high speed flying require more servo power than the mini servos can give. I had a couple of customers who reported flutter that went away when they put the bigger servos in their plane and maximized the leverage between the servo and the elevon by:
1) Let the servo make full rotation. Don't use the transmitter to restrict movement.
2) Attach the push rod at the top of the horn on the elevon
3) Attach the push rod as close to the center of the servo arm as possible and still get adequate movement.
4) Use enough rod guides along the push rod to prevent any slack or flex
5) Make sure the servo is glued firmly in the foam and can't move even under stress
Another cause of flutter is that the rods are breaking loose from the wing with the extreme forces. This has been seen when:
1) Gorilla Glue has been used and after a few hard landings it starts to break down allowing the rods to move in the foam
2) The rods were not sanded during construction and or the glue did not stick to them
3) The rods are not tied together at the connecting points and are able to move against each other
4) The Extreme tape is not tight enough or applied in the right places.
I trust our elevon system but it has to be built right. I am using the EPP elevons even on my big planes like the Herc video you just watched in post 4633 and the 78" and 8 lb Herc video below.
You have to build for the style of flying you are going to do. If you want a bullet plane you have to build the plane to handle the stresses.
1) You can add another layer of laminate even after the plane is finished if the elevons are not stiff enough.
2) Double check your hinges and make sure they are tight. If you have too big of a gap in the hinge line or the hinge line isn't straight the hinge will be loose.
Lee
78" Hercules Wind Surfing (5 min 57 sec)
Lee is online now Find More Posts by Lee
Old Dec 23, 2012, 01:30 PM
cmaynex is offline
Find More Posts by cmaynex
United States, CT, New Haven
Joined Dec 2011
Thanks for the response. I am sure it is builder error for I m fairly new at this. This is my 3rd CTH build. I am going to check everything out before I go out and fly. Note, I didn't do this on 3s with 8x4 prop at 700w or more. I was also liberal with he hot glue on the spar install and also the e-tape.
cmaynex is offline Find More Posts by cmaynex
Old Dec 23, 2012, 02:42 PM
ashdec87 is offline
Find More Posts by ashdec87
ashdec87's Avatar
United States, MI, Detroit
Joined Feb 2004
Lee- I would have people try the white gorilla glue. It flexes a little and might be able to withstand impacts better than a rigid yellow glue.
ashdec87 is offline Find More Posts by ashdec87
Old Dec 23, 2012, 02:56 PM
E1Allen is offline
Find More Posts by E1Allen
UH60 Pilot
E1Allen's Avatar
United States, KY, Fort Campbell
Joined Jan 2010
Throw some pictures up or a quick YouTube video. At least your setup so we can take a look at it.
E1Allen is offline Find More Posts by E1Allen
Old Dec 23, 2012, 02:58 PM
E1Allen is offline
UH60 Pilot
E1Allen's Avatar
Joined Jan 2010
I have one reaper spar with hot glue and the other with white gorilla glue. Unfortunately as it sits I won't be able to smash it up in combat as no one is around. I do want to see the difference between the glue methods
Old Dec 23, 2012, 03:28 PM
ashdec87 is offline
ashdec87's Avatar
Joined Feb 2004
the issue I've had with hot glue is that it becomes brittle in cold weather and can release from the surrounding foam. In hot weather it can get just soft enough to allow the spar to wiggle out. I've have planes fall apart because of the heat of summer (thankfully on the ground).
Old Dec 23, 2012, 04:45 PM
cmaynex is offline
Joined Dec 2011
Made sure everything was tight and I noticed that the laminate was coming loose so I re-ironed it and no more high speed flutter. Just came back from the park flying her full throttle against and with the wind.
Old Dec 23, 2012, 05:36 PM
E1Allen is offline
UH60 Pilot
E1Allen's Avatar
Joined Jan 2010
Sounds like problem solved
Old Dec 23, 2012, 05:39 PM
cmaynex is offline
Joined Dec 2011
I do have video but it is not appropriate for this site and youtube. A little bit of cursing. I do not know how to edit out sound or edit a video period. I would like to start posting videos.
Old Dec 23, 2012, 07:10 PM
E1Allen is offline
UH60 Pilot
E1Allen's Avatar
Joined Jan 2010
I don't think YouTube or us mind all too much about your sailor style talk!
Old Dec 23, 2012, 08:36 PM
E1Allen is offline
UH60 Pilot
E1Allen's Avatar
Joined Jan 2010
YouTube you can completely overlay music on your audio.
Old Dec 23, 2012, 10:24 PM
elCapitan is offline
Find More Posts by elCapitan
wheeeeee!
elCapitan's Avatar
United States, UT, Provo
Joined Oct 2011
Unfortunately, the white gg is still not flexible enough (and clearly not as flexible as hot glue). My bro-in-law's plane that I mentioned before, he built entirely with white gg... well, sure enough, it wasn't long before a few crashes had the spars loose, and chunks of gg floating around under the lam. Now that it's in half, pretty much, he's rebuilding with hot glue.
elCapitan is offline Find More Posts by elCapitan
Old Dec 24, 2012, 07:44 AM
Lee is online now
Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
I only use the hot glue. I build a lot of planes and it is definitely the fastest. I don't remember a glue joint failing. I think the Gorilla glue may get weaker if it gets too much water (used for activation) in it when it is applied.
Old Dec 24, 2012, 08:35 AM
E1Allen is offline
UH60 Pilot
E1Allen's Avatar
Joined Jan 2010
3536-1800kv back in stock
Old Dec 24, 2012, 09:27 PM
Xmod is offline
Find More Posts by Xmod
Australia, QLD, Mountain Creek
Joined May 2012
Grim Reaper and box of HobbyKing bits arrived a week ago and were stashed by the family. They ärrived"under the tree this morning. Happy Days.
A merry Christmas and a crash free new year to Lee and all the Crash Test Hobbyists from our family in Australia
Xmod is offline Find More Posts by Xmod
Sold Reaper GR60 Stagger_Wing Aircraft - Electric - Power Systems (FS/W) 0 Jan 13, 2010 02:43 AM
Sold Reaper GR 60 wrpsr1911 Aircraft - Electric - Power Systems (FS/W) 0 Jan 06, 2010 10:28 PM
Build Log House of Balsa "Grim Reaper" P51 Mustang Gun Jam Electric Warbirds 28 Dec 20, 2009 04:25 PM
Discussion Body count... Grim but it's really gotta be done. Bilbobaker Life, The Universe, and Politics 15 Nov 15, 2009 02:09 PM
Gallery Grim reaper Wickett R/C Pumpkin Contest 1 Oct 31, 2005 05:37 PM
