Old Dec 20, 2012, 08:49 PM
KD0ZEQ is offline
Find More Posts by KD0ZEQ
Aviation Enthusiast
KD0ZEQ's Avatar
United States, CO
Joined Nov 2012
Batteries
Finishing up my first Crash Test plane. Am getting ready to put my radio gear in . My question is this.. as far as getting in the ball park for correct CG what size batteries are you guys using? I was thinking two 3 cell 4000mah. Or maybe two 3000mah?
KD0ZEQ is offline Find More Posts by KD0ZEQ
Old Dec 20, 2012, 09:03 PM
KD0ZEQ is offline
Aviation Enthusiast
KD0ZEQ's Avatar
United States, CO
Joined Nov 2012
Wing Tips and fins
I pretty much built my deep reaper from the instructions on the CTH website.
However came across instructions on here also the RCgroups. I noticed there was some instuctions on wing tips that were not in the one on site. I have not put my fins on yet . Is there some cuts that i should have made on tips. I have stock wing tips with no modifications . Will i be o.k just slapping fins on with a little toe in??
Old Dec 20, 2012, 10:37 PM
Lee is offline
Lee
Find More Posts by Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
The instructions at the first of this thread are out dated although the basics are still there. Go with the instructions here http://crashtesthobby.com/products/grim-reaper. They are regularly updated.
Lee is offline Find More Posts by Lee
Old Dec 20, 2012, 10:40 PM
Lee is offline
Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
Lighter flies better but you still need to get CG correct and I am a believer in not adding lead when you can add batteries for longer flights. I think either way it will work depending on placement. Difference in weight between 2X 3000s and 2X 4000s will be 8+ oz.
Lee
Old Dec 21, 2012, 06:55 AM
michaelingp is offline
Find More Posts by michaelingp
United States, MD, Kensington
Joined Dec 2008
To add to what Lee said... It's really about how fast you fly and how long a flight time you want. The Reaper should balance fine with a single 3 cell 3000mah battery up against the forward spars. I use a 2300 mah battery and the flight time is fine for me. But I'm not usually flying full throttle either, and I keep a spare battery in my pocket.
You don't have to get it perfect the first time. It's easy enough to cut a new battery hole, perhaps stuffing the old one with a chunk of scrap EPP.
michaelingp is offline Find More Posts by michaelingp
Old Dec 21, 2012, 07:58 AM
E1Allen is offline
Find More Posts by E1Allen
UH60 Pilot
E1Allen's Avatar
United States, KY, Fort Campbell
Joined Jan 2010
Lee
I agree, none of the wings I've built from Lee required lead. Battery always went in last. If I've ever added anything just to make it that much closer it would be tape which just protects. Also I've built a few light and heavy wings. Seems like getting the CG right is the most important thing.
E1Allen is offline Find More Posts by E1Allen
Old Dec 21, 2012, 08:32 AM
elCapitan is offline
Find More Posts by elCapitan
wheeeeee!
elCapitan's Avatar
United States, UT, Provo
Joined Oct 2011
Indeed, getting CG correct is the real important thing, here, and I think you should be able to accomplish that with either of those battery setups.
The instructions used to include a really good, widely used method to make sure you get the proper CG, but it seems to be gone now. Basically, once everything is laminated, and the elevons attached, you flip over to the bottom of the wing, and measure back from the nose the proper distance for CG. Then use a square to measure out from that, onto either side of the wing, and make symmetrical marks. (A line between the two would then be the CG axis). Place a pushpin in the marks.
Now flip the wing back upright, and lay out all your electronics, including the batteries, where you think you want them. Try to lift the wing from underneath, balancing it on the pushpins with your fingers. If it tips forward, you know you're nose-heavy, and have to move some of the electronics back. Vice versa for tail heavy. Once you get things as close as possible to balancing on those pushpins, mark where all your electronics will go, and then you can actually cut or melt the bays.
The good things about this method are that it's proven (lots of people build this way and accurately attain the proper CG), and versatile. In other words, it doesn't matter what wing you're building, or which electronics you're using. You can always make sure you're on CG by building this way instead of relying on measurements that may not work for your particular setup, or trial and error guessing based off pictures of someone else's build.
elCapitan is offline Find More Posts by elCapitan
Old Dec 21, 2012, 08:44 AM
KD0ZEQ is offline
Aviation Enthusiast
KD0ZEQ's Avatar
United States, CO
Joined Nov 2012
Thanks you guys . That helps a lot. Nice to get feedback so quickly!!
Cant wait to get this bird in the air. Is like no other that ive built thats for sure.
Old Dec 21, 2012, 08:53 AM
E1Allen is offline
UH60 Pilot
E1Allen's Avatar
Joined Jan 2010
Elcapitan's method is what I usually do as well. I did that to make sure I could keep my batteries within the spars when I added the 2x8000mah batteries at 600g each. Almost 2.7lbs in batteries alone.
Old Dec 21, 2012, 10:59 AM
Joined Dec 2008
Originally Posted by E1Allen View Post
make sure I could keep my batteries within the spars .
This is important. Once you've covered the plane it becomes hard to see the white spars, and even the extreme tape. So, it's not like you can just put the electronics and batteries anywhere you want. You can't cut the spars, and I assume you want to minimize cuts into the Extreme tape.
elCapitan, I think the instructions still include the "move the battery to adjust the CG" steps. I know it does for the Grim Reaper, because I just looked. Maybe it's not as explicit as before, but it's still there:
Installing the electronics.
b) Set the parts on the top of the plane where shown and see if the CG needs to be adjusted.
e) Move the battery forward or back to get the CG 10.5" back from the nose of the plane.
Old Dec 21, 2012, 01:40 PM
Lee is offline
Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
I see conflicting weather reports for today.
http://www.google.com/imgres?hl=en&s...2&tx=179&ty=82
http://www.google.com/imgres?hl=en&s...9,r:1,s:0,i:95
http://www.google.com/imgres?hl=en&s...r:11,s:0,i:130
Happy End of the World!!!!
Old Dec 21, 2012, 01:54 PM
Parke_ParkeFlyer is offline
Find More Posts by Parke_ParkeFlyer
Fly Now.
United States, TX, Austin
Joined Aug 2012
This too is how I determined gear placement. Forgive me if this was already mentioned, but be sure to have your winglets installed as this adds a significant weight behind the CG.
As far as batteries, on my DeepReaperXL with a 3536 motor, and lots of camera gear up front, I still needed nose weights with 2x 3300mah3S. I've recently bought some 4400mah, but haven't tried the CG yet.
If you're going with a similar setup as mine but don't plan on a lot of FPV gear, I would think about moving your motor closer to the CG than what is in the instructions. I was really worried about being nose heavy during the build, but the opposite happened.
-Parke
Edit: I just looked at your pict, and your motor looks pretty far forward already. You should be good shape.
The instructions used to include a really good, widely used method to make sure you get the proper CG, but it seems to be gone now...
Parke_ParkeFlyer is offline Find More Posts by Parke_ParkeFlyer
Old Dec 22, 2012, 07:53 PM
Lee is offline
Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
We shot this video this afternoon of and with the 63" Herc Pusher.
Herc Pusher 63" with 808 #16D (5 min 20 sec)
Old Dec 23, 2012, 10:38 AM
cmaynex is offline
Find More Posts by cmaynex
United States, CT, New Haven
Joined Dec 2011
I fly my Grim Reaper with an NTM 3536 1800KV with and 8X4 prop. Overkill I know but this is what I like, power on tap. I recently experimented and put a 7x6 prop and a 4s battery in her and when I opened her up to full throttle the plane started to I guess you call high speed flutter. Am I going to fast is there a limit or is something wrong It flew fine as long as I didn't go full throttle. I switched back to 3s on 8x4, it's also less noisy. Any thoughts (I know this plane is not designed to be a speed racer)?
cmaynex is offline Find More Posts by cmaynex
Old Dec 23, 2012, 10:53 AM
Joined Dec 2008
Traditionally there are two causes of flutter. The first is a hinge gap, but most Reapers have continuous hinges. The other cause is play in the control rods or in the servos. You need to beef up the servos and control rods. CTH now recommends standard (40g) servos for the Reaper. If you're not going to fly combat, I'd recommend solid control rods, like dowels. The CTH instructions are optimized for combat survive-ability, and the thin rods and the staple used to minimize play in the rod are probably not adequate for really high speeds.
Sold Reaper GR60 Stagger_Wing Aircraft - Electric - Power Systems (FS/W) 0 Jan 13, 2010 01:43 AM
Sold Reaper GR 60 wrpsr1911 Aircraft - Electric - Power Systems (FS/W) 0 Jan 06, 2010 09:28 PM
Build Log House of Balsa "Grim Reaper" P51 Mustang Gun Jam Electric Warbirds 28 Dec 20, 2009 03:25 PM
Discussion Body count... Grim but it's really gotta be done. Bilbobaker Life, The Universe, and Politics 15 Nov 15, 2009 01:09 PM
Gallery Grim reaper Wickett R/C Pumpkin Contest 1 Oct 31, 2005 04:37 PM
