Old Dec 11, 2012, 12:47 PM
Parke_ParkeFlyer is offline
Find More Posts by Parke_ParkeFlyer
Fly Now.
United States, TX, Austin
Joined Aug 2012
Originally Posted by nightfox7 View Post
... i use VERY little water, because the more water you use, the more expansion and bubbles you get, and to me, that means a weaker joint, and most of the time i don't even use water, i just smear a little on both surfaces, the breathe hot air on it. Like you would to clean your glasses, and that seems to be plenty...
I think it might depend on how much humidity is in the air. Georgia, if I recall correctly, is pretty humid so you may not need to add as much. In central Texas, where I'm from, it's humid, but I still need to add water. The water activates the glue causing the bubbles and expansion and also the stickiness. Since this is a chemical process, I was always under the impression that the bubbles and expansion were key to the bonding, therefore a significant amount of water is needed. But I could be totally wrong about this.
Parke_ParkeFlyer is offline Find More Posts by Parke_ParkeFlyer
Old Dec 11, 2012, 12:58 PM
E1Allen is offline
Find More Posts by E1Allen
UH60 Pilot
E1Allen's Avatar
United States, KY, Fort Campbell
Joined Jan 2010
I add water to gorilla glue. I just monitor the expansion for the first five minutes and keep pushing the expansion back into the foam. I just let the excess water dry off through evaporation if I used too much.
E1Allen is offline Find More Posts by E1Allen
Old Dec 11, 2012, 03:54 PM
elCapitan is offline
Find More Posts by elCapitan
wheeeeee!
elCapitan's Avatar
United States, UT, Provo
Joined Oct 2011
I also think GG is great for the shock cord (wet string method) and have never had any problem with that. I've also used it to fill in gaps where a chunk of foam used to be, but just needs filling in now. I use GG white, and to wet the foam, I have water in a small pump-spray bottle like the one in the attached image. One spray in any area is plenty.
But I also have not used it for areas that are going to flex a lot, like for the spars. I can tell you that my bro-in-law did a Reaper with GG white for the spars, and after 3-5 solid crashes, had plenty of separation, and ended up gutting the wing and re-doing it with hot glue.
elCapitan is offline Find More Posts by elCapitan
Old Dec 11, 2012, 04:55 PM
nightfox7 is offline
Find More Posts by nightfox7
┌∩┐(⋟﹏⋞)┌∩┐ The FAA
nightfox7's Avatar
United States, GA, Cornelia
Joined Jan 2012
About the humidity, this is true, it is a little known fact that we do not get our water by drinking; rather we just breathe.
nightfox7 is offline Find More Posts by nightfox7
Old Dec 11, 2012, 08:07 PM
HoosierGuy is offline
Find More Posts by HoosierGuy
HoosierGuy's Avatar
United States, IN
Joined Jan 2012
Is the Grim Reaper hard to build? When I got my 35 inch pop wing I had to glue the two halves together, take a knife and cut grooves for the reinforcing carbon/fiberglass rods, and glue in the servos.
How much harder is the grim reaper? Is it difficult to put on that film covering that goes over the Grim Reaper?
Also, do you have to fly it with those side wings on? On my pop wing the only thing I don't like is those side wings.
HoosierGuy is offline Find More Posts by HoosierGuy
Old Dec 11, 2012, 08:18 PM
E1Allen is offline
UH60 Pilot
E1Allen's Avatar
Joined Jan 2010
Originally Posted by Xmod View Post
Allen, I didn't know you could use a truck battery in a GR XL
I didn't know either but I plan on using two.
Old Dec 11, 2012, 08:30 PM
wheeeeee!
elCapitan's Avatar
Joined Oct 2011
Well, yes, you glue the halves together, install the spars, etc. on your own with the Reaper, too, but that's half the fun! Besides, CTH has some pretty dang good step-by-step .pdf instructions available on their website with lots of pictures, specific to each plane. Stick to those, and you'll be fine.
As for the winglets on the wing tips, yeah, they're pretty critical. They're what keeps the plane from wagging side to side almost uncontrollably. It would be like a passenger plane trying to fly without its upright tail section. Doesn't make for a smooth flight, if any flight at all.
Old Dec 11, 2012, 10:04 PM
Fly Now.
Joined Aug 2012
I wouldn't say it's hard, but it is time consuming. Especially for the first build. I feel like I could build a second one in about half the time. I was hoping to I could do it in a long weekend, but it ended up taking a few weekends and several evenings.
Old Dec 11, 2012, 10:49 PM
E1Allen is offline
UH60 Pilot
E1Allen's Avatar
Joined Jan 2010
I wouldn't say it's too hard either, I'm in the process of building mine right now, however it's my fourth cth wing so I kind of get the hang of it. Check out some fin designs others have used, you may find them more appealing and they still get the job done.
Eric
Old Dec 11, 2012, 10:50 PM
ashdec87 is offline
Find More Posts by ashdec87
ashdec87's Avatar
United States, MI, Detroit
Joined Feb 2004
White GG is slightly flexible compared to the yellow stuff.
I simply used a spray bottle to lightly mist the parts needing to be glued. Usually the water gets pushed out as the parts are pushed together. Never have had issues with that method, and I use that stuff in just about every build.
ashdec87 is offline Find More Posts by ashdec87
Old Dec 11, 2012, 10:52 PM
E1Allen is offline
UH60 Pilot
E1Allen's Avatar
Joined Jan 2010
I also use a full size iron and put one of those plastic iron covers on it to make it easier and less likely to melt I guess.
Old Dec 11, 2012, 10:58 PM
E1Allen is offline
UH60 Pilot
E1Allen's Avatar
Joined Jan 2010
Speaking of builds and our hot glue or gorilla glue. I went ahead and glued the top spar in with white gorilla glue and the bottom with hot glue. Needless to say I used quite a bit more hot glue than gorilla glue.
Old Dec 11, 2012, 11:04 PM
E1Allen is offline
UH60 Pilot
E1Allen's Avatar
Joined Jan 2010
Wrong pic
Old Dec 12, 2012, 07:25 AM
michaelingp is offline
Find More Posts by michaelingp
United States, MD, Kensington
Joined Dec 2008
The Grim Reaper comes as a KIT, not an ARF. Not everybody likes to build. Before you buy, make sure you read the instruction manual, which is on-line, to make sure you understand what is involved, and what tools and supplies you'll need.
That said, it's not like the balsa kits of old. My friend, who has never built a model plane in his life, and knew really nothing about the motors, electronics and servos, built a CTH Hercules, which is a much more involved kit and had no problems. I think it took him about a week, after work in the evenings. For the laminate, he ignored all my suggestions, and bought some kind of travel iron at Target, of all places, and it worked fine for ironing the laminate onto the wing. Of course, he made a few mistakes, but nothing serious, and the plane flew great on its maiden flight.
michaelingp is offline Find More Posts by michaelingp
Old Dec 13, 2012, 12:50 PM
CaribbeanBlue is offline
Find More Posts by CaribbeanBlue
Joined Jul 2010
Gglue
I have used the Amber GGlue type PU glues in past. I think the coloured PU glues are UV unstable after time and goes brittle or crumbles. I think hot glue or Goop stays flexible and holds onto sanded spars better.
H
CaribbeanBlue is offline Find More Posts by CaribbeanBlue
Sold Reaper GR60 Stagger_Wing Aircraft - Electric - Power Systems (FS/W) 0 Jan 13, 2010 01:43 AM
Sold Reaper GR 60 wrpsr1911 Aircraft - Electric - Power Systems (FS/W) 0 Jan 06, 2010 09:28 PM
Build Log House of Balsa "Grim Reaper" P51 Mustang Gun Jam Electric Warbirds 28 Dec 20, 2009 03:25 PM
Discussion Body count... Grim but it's really gotta be done. Bilbobaker Life, The Universe, and Politics 15 Nov 15, 2009 01:09 PM
Gallery Grim reaper Wickett R/C Pumpkin Contest 1 Oct 31, 2005 04:37 PM
