Yeah, ive read that befor "fluttering" but a guy on youtube "bankheadrc" did a video of his DRXL to show it. I then built mine with epp and had the fluttering affect too. Balsa is more stable for me and i trust it more for my setup. Side by side balsa is way stronger. Epp elevons are good but for light loads.
It's all preference, so do what you like, but...
I have a suspicion that the flutter a few people have mentioned is due more to the gap they leave in the hinge between elevon and trailing edge. My Herc is loaded up with two 4400mAh lipos, Go Pro, FPV gear, an entire second layer of lam-on color, and even 20 lead bullets in the nose to balance it all out, and it still flies true and smooth with double-laminated EPP elevons. I just make sure the elevon is right up against (barely touching) the trailing edge when they're taped and laminated on. No gap. Now, that does make the hinge a little stiffer, so you need good quality servos to pull them around and hold them in place, but servos are one thing I've learned not to go too cheap on anyway. No real comparative evidence to say that's the cause of the flutter, but considering most people do fine with EPP, it's just my suspicion |
I know, gaps will really affect your plane. But mine was tight. I made sure. I even used 5mil lam. My servos are what i've been using on my larger 69" 7lbs and 80" 5lbs wings. So i know they work good. So it leaves me to fall on the side of weak elevons. And agin i got alot of cash in my osd, so the epp elevons got tossed.
It's just what i did to fix flutter. So if someone ask about a build and runs into this, balsa might help. |
Most of the time flutter is from too weak of servos on this heavy of a plane or slop in the hinge line or linkages or even loose servos that move under stress. I have seen flutter strong enough to break a wing with balsa elevons too.
I think we often put in smaller servos and they can't handle the forces of the plane. Even though many flyers fly with the MG90 and other mid sized servos I have enough concern that I started to recommend full size servos on any plane that has a motor that uses over 20 A. |
Lee, great meeting you yesterday! I appreciate your time and it was awesome to see your planes in person! When I got back home I dug through my stuff and was wondering what you (or any of you other reaper owners) think of this motor: it's a 3020-970. Ok hobby (infinite) makes them. They are a scorpion knock off. Here is a link to the specs: http://www.okhobby.com/product.php?id_product=775 I still haven't decided if I want to go 3 or 4 cell. I plan on using a 9x6. I am looking for speed and wow factor! Nothing too crazy though. It's a heavier motor so I am also concerned with the CG. Thanks for all your inputs!
Just for fun
| Thread Tools | |
| Sold Reaper GR60 | Stagger_Wing | Aircraft - Electric - Power Systems (FS/W) | 0 | Jan 13, 2010 01:43 AM |
| Sold Reaper GR 60 | wrpsr1911 | Aircraft - Electric - Power Systems (FS/W) | 0 | Jan 06, 2010 09:28 PM |
| Build Log House of Balsa "Grim Reaper" P51 Mustang | Gun Jam | Electric Warbirds | 28 | Dec 20, 2009 03:25 PM |
| Discussion Body count... Grim but it's really gotta be done. | Bilbobaker | Life, The Universe, and Politics | 15 | Nov 15, 2009 01:09 PM |
| Gallery Grim reaper | Wickett | R/C Pumpkin Contest | 1 | Oct 31, 2005 04:37 PM |
