Old Aug 31, 2012, 09:33 PM
elCapitan is offline
Find More Posts by elCapitan
wheeeeee!
elCapitan's Avatar
United States, UT, Provo
Joined Oct 2011
I would go ahead and buy a new system, personally. PlaneInsaneRC.com has a combo kit for a good price, or HK's NTM Prop-Drive series is a pretty good deal
elCapitan is offline Find More Posts by elCapitan
Old Sep 01, 2012, 12:06 AM
cmaynex is offline
Find More Posts by cmaynex
United States, CT, New Haven
Joined Dec 2011
Friday my Grim Reaper had it's maiden flight and this is wing flew out of my hands at 3/4 throttle and needed very little trim. The COG was spot on and man this thing hauls WOT. Can't wait to try her with the 1800kv. Oh and it was windy about 10 to 15 mph winds and stronger gust.
These wings are great. Already looking at the Titan.
cmaynex is offline Find More Posts by cmaynex
Old Sep 01, 2012, 02:10 AM
RUBNorris is offline
Find More Posts by RUBNorris
New Beeeeee
RUBNorris's Avatar
United States, CA, Sacramento
Joined Apr 2011
I finished my Reaper XL today and ready for its maiden. Getting 500Watts with a 10x10prop. Low Amps. Not bad for a NTM motor. I'll try to post video. Looks nice but i would like alittle more room for folding wires =) Eh, I'll test tomorrow..
Deep Reaper XL Build 2012 (4 min 49 sec)
RUBNorris is offline Find More Posts by RUBNorris
Old Sep 02, 2012, 09:22 PM
New Beeeeee
RUBNorris's Avatar
Joined Apr 2011
Here's my Deep Reaper XL. Very happy BUT! With it was alittle bit thicker and Elivons Vibrate bad at high speed. It flaps very loud. My buddys where freaked out by the EPP elivons. Might need to switch to balsa.
But I like it. 30+ flight times
CTH Deep Reaper XL Maiden (5 min 39 sec)
Old Sep 02, 2012, 11:44 PM
Lee is offline
Lee
Find More Posts by Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
https://www.youtube.com/watch?v=bJLYHa0nRJ4
I noticed you tapered your elevons so there isn't much material to mount the horns in. This may have weakened the elevons and caused the flex that is allowing the elevon to flutter.
We have not had a flutter problem with the full elevon in place as long as the linkages and servos are tight.
Lee
Lee is offline Find More Posts by Lee
Old Sep 03, 2012, 10:12 PM
New Beeeeee
RUBNorris's Avatar
Joined Apr 2011
Lee
Yeah i noticed that that would be a problem. When lamming them they still flexed and thought about the weight of a high speed pass like I was doing on my 3rd flight. I still am going to switch to balsa. I would feel safe with them carring my gear.
For the servos they shake alittle like on my ZII by ritewing and they dont flutter. I think I can make it work. =)
Old Sep 04, 2012, 12:21 AM
Lee is offline
Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
I have gone back and replaced all of the balsa elevons on the old planes with EPP elevons. I think it is all in how you set them up including the linkages and choice of servos. I am using more standard sized servos on the planes bigger than 40" to make sure I am not stalling the servos.
I saw some great aerobatic flying today with a local flyer and a Reaper. I have seen him fly alot of times but he really has some surprising stunts he is doing with the Reaper. he is using an Axi 2808/24 motor and is getting surprising long flights with a 9x6 prop.
Old Sep 04, 2012, 10:42 AM
Parke_ParkeFlyer is offline
Find More Posts by Parke_ParkeFlyer
Fly Now.
United States, TX, Austin
Joined Aug 2012
Thanks for the explanation of "reflex". -- I'm about to cut the notch for the motor and being a FPV rig, the build guide says to put it 14" from the nose (DR-XL). This requires not much foam removal and I have no reason to defer from the guide, but I've seen several pictures with much deeper cuts. Tonight I hope to temporarily place the gear to get a better idea of CG, but was wondering if there was a general consensus. Where are most of you putting your motor?
Parke_ParkeFlyer is offline Find More Posts by Parke_ParkeFlyer
Old Sep 04, 2012, 11:06 AM
New Beeeeee
RUBNorris's Avatar
Joined Apr 2011
I would say, it depends on battery size . Mine is 14-15" back and ment for 2 4000 3s packs. Mark your cg and tape everthing on to about its lacation and make your call. Just dont cut too early.
Old Sep 04, 2012, 07:32 PM
wheeeeee!
elCapitan's Avatar
Joined Oct 2011
It's kind of a catch-22. If you wanted to figure out exactly how far to cut out for the motor, you'd have to get everything balanced first, then cut out the trailing edge. But at the same time, you can't get everything balanced until it's all laminated, and you can't laminate until the shock cord is in, and you can't put the shock cord in until you've cut out the trailing edge! ...hm, darnit.
I followed what the instructions say, and I use two 4000 mAh batteries, a GoPro (without case) and minimal fpv gear. It was pretty close, but I had to put the batteries farther forward than I wanted, so if I were to do it again, I would have cut the motor up another inch.
Even still, most of the weight is from all that laminated wing behind CG, so don't be shy about loading it up with a second camera if you want, or plenty of battery power. It can certainly take the weight.
Old Sep 08, 2012, 02:56 PM
cmaynex is offline
Joined Dec 2011
Took the Reaper out in 20 mph winds and 30 mph gust. I had to use all my limited skills not to crash. I did alright and had a lot of fun. Kept me on my toes. Waiting for another pair of video sunglasses in the mail. First pair worked great, tried them out and then left them on the charger to long and killed the battery.
I know this horse has been beat to death but I want to get in to FPV and wanted to hear ideas for beginners?
Thanks in advance.
Old Sep 08, 2012, 05:53 PM
New Beeeeee
RUBNorris's Avatar
Joined Apr 2011
Thanks in advance.
5.8ghz set from Hobbyking. Best beginner set out.
Old Sep 08, 2012, 07:43 PM
cmaynex is offline
Joined Dec 2011
Are you talking about the silver ones?
Old Sep 08, 2012, 08:51 PM
New Beeeeee
RUBNorris's Avatar
Joined Apr 2011
Hot items
http://www.hobbyking.com/hobbyking/s...Tx_Rx_Set.html
http://www.hobbyking.com/hobbyking/s...era_NTSC_.html
http://www.ebay.com/itm/4-3-TFT-Colo...item256f0a87e2
With some CL antenas
Old Sep 08, 2012, 09:30 PM
Lee is offline
Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
I told you that we had a flyer that has built his Reaper light and does some flat spins and rolls that are worth seeing. Here is a video with a little combat towards the end.
Reaper Stunts - Randy 9-12 (5 min 45 sec)
Sold Reaper GR60 Stagger_Wing Aircraft - Electric - Power Systems (FS/W) 0 Jan 13, 2010 01:43 AM
Sold Reaper GR 60 wrpsr1911 Aircraft - Electric - Power Systems (FS/W) 0 Jan 06, 2010 09:28 PM
Build Log House of Balsa "Grim Reaper" P51 Mustang Gun Jam Electric Warbirds 28 Dec 20, 2009 03:25 PM
Discussion Body count... Grim but it's really gotta be done. Bilbobaker Life, The Universe, and Politics 15 Nov 15, 2009 01:09 PM
Gallery Grim reaper Wickett R/C Pumpkin Contest 1 Oct 31, 2005 04:37 PM
