Old Aug 29, 2012, 11:31 AM
cmaynex is offline
Find More Posts by cmaynex
United States, CT, New Haven
Joined Dec 2011
Thank you Rubnorris.
cmaynex is offline Find More Posts by cmaynex
Old Aug 29, 2012, 12:07 PM
RUBNorris is offline
Find More Posts by RUBNorris
New Beeeeee
RUBNorris's Avatar
United States, CA, Sacramento
Joined Apr 2011
Your welcome
RUBNorris is offline Find More Posts by RUBNorris
Old Aug 29, 2012, 01:33 PM
hobie14 is offline
Find More Posts by hobie14
hobie14's Avatar
Western Europe 52.7 N 8.9 W
Joined Jul 2007
Originally Posted by Lee View Post
If you really need some help put a 3" drawer handle under the CG in the center of the plane. It gives you some where to hang on.
It has to be mounted on a plywood base but it is an easy way to get a grip.
Is there a photo of this setup anywhere? .....
hobie14 is offline Find More Posts by hobie14
Old Aug 29, 2012, 01:59 PM
Lee is offline
Lee
Find More Posts by Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
I don't have any set up like that now. but just take a piece of plywood that is about 5x3, screw the 3" handle down the middle and glue the plywood under CG with the handle front to back. don't get your finger clear through the handle as you throw it or you may get hung up. Choose a simple round metal handle.
Lee is offline Find More Posts by Lee
Old Aug 29, 2012, 09:40 PM
elCapitan is offline
Find More Posts by elCapitan
wheeeeee!
elCapitan's Avatar
United States, UT, Provo
Joined Oct 2011
Originally Posted by RUBNorris View Post
Builing my DRXL and have a ntm 35-36 1400kv and 2 - 4000mah 3s. Will that motor be enough for the xl or should i look a a bigger motor? Seting up the layout tonight and getting the cg down. Thaks
I first built mine with a 3536 1400kv, and it flew, for sure. I eventually swapped out for a 3536 1800kv, and was pleased with the improvement, though.
That said, I didn't play much with prop size. My 60A ESC was already getting warm on a 9" prop, with that 1400kv motor, so I didn't want to go much bigger.
elCapitan is offline Find More Posts by elCapitan
Old Aug 29, 2012, 10:59 PM
New Beeeeee
RUBNorris's Avatar
Joined Apr 2011
hmm.. I dont like my gear getting hot. Ill see what i get with a 10x5 on the watt test.
Im lamming the XL now, so i need the mount for the test. Hope it works out ok. Should be done by saturday..... well thats the idea.
Old Aug 30, 2012, 12:19 AM
cmaynex is offline
Joined Dec 2011
el capitain, I just finished my Grimm reaper and I have the 3536 1400kv and also have the 1800kv that I plan to switch out at a later date. What size lipo are you running and what type of time are you getting. With the 1400 and the 1800. I can't decide what size to run, 2200, 2650 4500 or two 2200's/
Old Aug 30, 2012, 03:29 PM
wheeeeee!
elCapitan's Avatar
Joined Oct 2011
Well, I was talking about my DRXL, so a much bigger plane. I use two 4000's on that one, and have never timed my flight, but I'd guess it's around 18-20 min.
For my regular Reaper, I run a 2200 battery (3530 1400kv motor), and get about 10-15 min, depending on how I am on the throttle.
My dad has two 2200's in his regular Reaper (also a 3530 1400kv motor), and flight characteristics are only slightly different. Requires more speed, and doesn't glide like mine, but as long as you get CG right, the Reaper handles weight pretty dang well.
Old Aug 30, 2012, 06:41 PM
cmaynex is offline
Joined Dec 2011
Thank you elcapitain. I am going to try the 3s 2200 and 2650 with the 1400. When I switch to the 1800 I will go with a 3300 to 4500 mah.
Old Aug 31, 2012, 08:38 AM
Parke_ParkeFlyer is offline
Find More Posts by Parke_ParkeFlyer
Fly Now.
United States, TX, Austin
Joined Aug 2012
What is this reflex you speak of?
I'm building my DRxl now, and this thread has been very useful. Thanks to all! I keep coming across the term "reflex" when talking about elevon setup. Forgive my ignorance, but what does this mean?
Parke_ParkeFlyer is offline Find More Posts by Parke_ParkeFlyer
Old Aug 31, 2012, 09:06 AM
wheeeeee!
elCapitan's Avatar
Joined Oct 2011
Reflex is the amount of up-trim in the elevons in their centered, rested state. In other words, when your hands are off the sticks, your elevons should still be angled slightly higher than the surface of the wing.
I don't have one handy, but maybe someone can supply a picture, if this didn't make enough sense
Old Aug 31, 2012, 09:07 AM
jwjohnson is offline
Find More Posts by jwjohnson
Hit Me! Please!
jwjohnson's Avatar
Provo, UT
Joined Jan 2005
Reflex it the upward deflection of the elevons that is required to maintain level flight in a flying wing. If you set up a flying wing with the elevons in a true neutral position it will dive into the ground when you attempt to launch it. Good luck with your build.
jwjohnson is offline Find More Posts by jwjohnson
Old Aug 31, 2012, 09:02 PM
AbsAltitudes is offline
Find More Posts by AbsAltitudes
United States, MI, Wyoming
Joined Mar 2012
So I have a problem....
Has anyone tried to equip a deep reaper with an Eflite power 10 motor?
I just recently crashed my only balsa plane, and thought it would be nice to use the power system on my next plane. I did a google search to see if I could find anything about using the power 10 on a deep reaper but the search did not return anything. So I thought asking might be the easiest solution rather than searching through pages. I was hoping to turn a deep reaper into a nice FPV platform.
AbsAltitudes is offline Find More Posts by AbsAltitudes
Old Aug 31, 2012, 09:11 PM
wheeeeee!
elCapitan's Avatar
Joined Oct 2011
a while back someone else asked about an Eflite power 10.
Originally Posted by demonspawn78 View Post
What if I went to a lower kv motor? Im looking at the eflite power 10 1100 kv motor with a 10x5 prop. Will that slow it down and give me more stability and flight time?
Here was one guy's response:
Originally Posted by Wind_of_Change View Post
That'll likely be too weak. On 4S packs that motor would be perfect, but it's not rated for 4S and would probably burn up. You'd be wanting more power on 3S probably. Is this an FPV plane, or just a general flying plane? Most guys flying 3S go with approximately 1500 kv on 10x6, or around 1750kv on 9x6.
Old Aug 31, 2012, 09:26 PM
Joined Mar 2012
Thanks! Doesnt say it wont work. but likely not enough power. I wonder if it is worth a shot or if I should attempt to sell the electronics and just buy new stuff?
Anyone interested in a power 10, and a 40amp pro esc?...lol
Sold Reaper GR60 Stagger_Wing Aircraft - Electric - Power Systems (FS/W) 0 Jan 13, 2010 01:43 AM
Sold Reaper GR 60 wrpsr1911 Aircraft - Electric - Power Systems (FS/W) 0 Jan 06, 2010 09:28 PM
Build Log House of Balsa "Grim Reaper" P51 Mustang Gun Jam Electric Warbirds 28 Dec 20, 2009 03:25 PM
Discussion Body count... Grim but it's really gotta be done. Bilbobaker Life, The Universe, and Politics 15 Nov 15, 2009 01:09 PM
Gallery Grim reaper Wickett R/C Pumpkin Contest 1 Oct 31, 2005 04:37 PM
