Old May 13, 2012, 12:20 PM
Stone1295 is offline
Find More Posts by Stone1295
AMA 937634
Stone1295's Avatar
United States, AK, Anchorage
Joined Jan 2010
I tried a prop saver on my Reaper XL and then decided to go with a collet.
The APC 9x6E props that I use are around $2 each and I haven't broken one yet though I have put a couple of dings in one. I balanced it out and it still flies!
I do use the prop savers on my Assassin and my Widowmaker but those are combat airplanes and my XL is used for FPV.
-Mike
Stone1295 is offline Find More Posts by Stone1295
Old May 13, 2012, 06:10 PM
burhead27 is offline
Find More Posts by burhead27
Payson, Utah
Joined Feb 2010
Someone had mentioned storm chaiser some posts back. I will be starting my build with a pod this week. Will post pic on the storm chaiser thread maby some of us can work togeather and help each other. If its half the plane as the DEEP REAPER ill giggle like a school girl.
burhead27 is offline Find More Posts by burhead27
Old May 13, 2012, 09:23 PM
Tom Eutsler is offline
Find More Posts by Tom Eutsler
Tom Eutsler's Avatar
Asheville,NC
Joined Jun 2002
Storm Chaser
Just flew mine Friday PM flys just fine - just like the pelican and albatross
I had a CC 50 Amp Esc and Nano tech 5000 . As Lee mentioned to me , LE of wing is approx 11 " from the Nose and mine worked out to be 11 3/16th
Is there a S Chaser Thread ? .................te
Tom Eutsler is offline Find More Posts by Tom Eutsler
Old May 13, 2012, 10:05 PM
ashdec87 is offline
Find More Posts by ashdec87
ashdec87's Avatar
United States, MI, Detroit
Joined Feb 2004
I flew the SS FPV, and recently converted to the albatross. Albatross is much better, but the SS does fly slower (good for between the trees flying). The albatross is definitely tough as nails, I've slammed it into the ground, with not a scratch.
On a side note, anyone have recommendations on how to quiet the Reaper down slightly? I have the prop about 2 inches behind the trailing edge. The only obvious thing I can think of is to turn the blunt TE into a sharper edge.
I did put a fairing in front of the motor and behind my HD camera, which actually raised the cruise speed by 5 mph.
ashdec87 is offline Find More Posts by ashdec87
Old May 13, 2012, 10:28 PM
jetpackninja is offline
Find More Posts by jetpackninja
Planes in flames,,,
jetpackninja's Avatar
Gravity Sucks
Joined Aug 2010
You are on to something with tapering the edge.
That will help.
Which motor and prop combo are you using?
Lower KV motor, bigger prop would likely quiet it down too.
jetpackninja is offline Find More Posts by jetpackninja
Old May 13, 2012, 10:46 PM
elCapitan is offline
Find More Posts by elCapitan
wheeeeee!
elCapitan's Avatar
United States, UT, Provo
Joined Oct 2011
The TE of the Reaper is already somewhat thin, so if you're using a shock cord, you might run into problems there. But I hear some people have started installing the shock cord in a slit on the bottom of the foan, about 1" in from the TE, instead of right along the perimeter. That would allow you to use a shock cord AND taper the TE a bit more. Never tried it, but sounds like a way to have both.
elCapitan is offline Find More Posts by elCapitan
Old May 13, 2012, 10:48 PM
ashdec87 is offline
ashdec87's Avatar
Joined Feb 2004
I'm using a 1400kv on a 4s pack with a 8x6 prop. I know I can go larger with a lower kv, but I wanted a higher speed.
Capt- The way I cut the wing to allow for the prop, the cut edge is pretty thick/blunt. I think that's where most of the sound comes from. At a higher RPM, you can literally hear the prop "gurgle" in the turbulence from the wing. Its there weirdest thing. I think I can taper it without cutting the shock cord.
Oh last time I flew the Reaper I decided to keep 90% of the FPV flight under 50 feet and over 50mph. Needless to say, it turned out to be an awesome video. I'll have it uploaded tomorrow.
Old May 13, 2012, 10:53 PM
wheeeeee!
elCapitan's Avatar
Joined Oct 2011
Yeah, if you can, then do it. When I built my DRXL I obviously had to cut out the back, and completely forgot about tapering the TE. It was very loud (about 1" of flat surface on the TE. I tapered it later and could barely believe the difference it made. Much quieter.
The guy I often build and fly with did the same thing with a mid-motor Roswell. Huge difference in sound once he tapered it, front and back.
Old May 13, 2012, 11:04 PM
Plane Insane RC is offline
Find More Posts by Plane Insane RC
BUZZ KILL
Plane Insane RC's Avatar
Utah
Joined Aug 2010
I've flown a lot with a slow stick and now with the Albatross. The Albatross with a flat wing is killer for FPV. It's small, light and with the flat wing and ailerons can be flown pretty aggressively but is still really stable. The best part is I don't destroy the plane when I put it in my car like I do with the slow sticks.
Ryan
Plane Insane RC is offline Find More Posts by Plane Insane RC
Old May 13, 2012, 11:20 PM
ashdec87 is offline
ashdec87's Avatar
Joined Feb 2004
capt- ok, i'll give it a shot.
Ryan- I love that motor mount. I might have to copy!
Old May 13, 2012, 11:27 PM
Planes in flames,,,
Gravity Sucks
Joined Aug 2010
Ryan,
What did you make the motor pod mount out of?
Can you take a couple of pics that show how you mount it to the fuse?
Old May 14, 2012, 09:35 AM
BUZZ KILL
Utah
Joined Aug 2010
It’s just made it from aluminum from Lowe’s bent 90 degrees and then a bit more to give it a slight up angle. A soldering iron was used to melt some foam out under the wing so it sits level with the wing saddle. I hot glued and extreme tapped it in place. I did the same thing with my Storm Chaser. Now you can order a Storm Chaser with a wood pod mount. When I got mine, it wasn’t an option. I’ll try to get some pictures.
Old May 14, 2012, 11:17 AM
Lee is offline
Lee
Find More Posts by Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
I like the wood mounts and they are a little easier to make and wood is always easy to get, but I also have seen and like Ryan's mount.
Lee is offline Find More Posts by Lee
Old May 14, 2012, 11:47 AM
Payson, Utah
Joined Feb 2010
YES try this http://www.rcgroups.com/forums/showt...t=storm+chaser
Old May 14, 2012, 11:56 AM
Lee is offline
Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
We are waiting on the instructions and the full beta tests then we will start an FPV thread. Until then it is mixed in with the Pelican and Albatross.
We are pleased with the feedback so far. Looks like we have an easy simple FPV plane
Sold Reaper GR60 Stagger_Wing Aircraft - Electric - Power Systems (FS/W) 0 Jan 13, 2010 01:43 AM
Sold Reaper GR 60 wrpsr1911 Aircraft - Electric - Power Systems (FS/W) 0 Jan 06, 2010 09:28 PM
Build Log House of Balsa "Grim Reaper" P51 Mustang Gun Jam Electric Warbirds 28 Dec 20, 2009 03:25 PM
Discussion Body count... Grim but it's really gotta be done. Bilbobaker Life, The Universe, and Politics 15 Nov 15, 2009 01:09 PM
Gallery Grim reaper Wickett R/C Pumpkin Contest 1 Oct 31, 2005 04:37 PM
