Old May 03, 2012, 08:07 PM
Wind_of_Change is offline
Find More Posts by Wind_of_Change
More Combat Please!
Wind_of_Change's Avatar
Utah
Joined Dec 2003
Originally Posted by jetpackninja View Post
BTW one of my favorite things is watching people try to throw their wing into the air and forgetting to turn off their throttle lock
Wait a minute, I'm the only one that does that! You're poking fun at me, aren't you?
Why I oughta....!
I need to put some Norris hurt on a Ninja!
Wind_of_Change is offline Find More Posts by Wind_of_Change
Old May 03, 2012, 11:38 PM
jetpackninja is offline
Find More Posts by jetpackninja
Planes in flames,,,
jetpackninja's Avatar
Gravity Sucks
Joined Aug 2010
Our good friend Steve does it every once in a while too.
But you do it with style. I would call it pulling a Todd but I think that move has already been named
jetpackninja is offline Find More Posts by jetpackninja
Old May 04, 2012, 12:04 AM
Planes in flames,,,
Gravity Sucks
Joined Aug 2010
Ninja Throttle Safety
Trademarked Patent Pending yada yada yada.
Not really.
Make yourself one If you like the idea and you think it'll help you out.
One piece of sewing elastic
A couple 'o pieces of shrink tubing.
One O ring
A little bit of hot glue...
Old May 05, 2012, 10:16 AM
wheelspinner20 is offline
Find More Posts by wheelspinner20
wheelspinner20's Avatar
S.E.Michigan
Joined Jul 2010
wow, do you work for OSHA? Although probably not, because before utilizing that device, there would be a 50 meg PDF form that has to be filled out and signed by 20 people to apply said device, then yet another 10 page form to remove it safely, including all of the affected individuals involved that you would have to notify.!
All kidding aside, I have bumped throttle accidently if I'm not careful while walking, usually against my leg. That got me in the habbit of constantly pushing down with me left thumb on the trl stick. (anything can still happen thought) I finally set a switch for throttle cut safety switch so that wouldnt happen any more.
I think thatas a pretty good idea, especially if you have young ones that like to run out and retrieve the wing for you.
wheelspinner20 is offline Find More Posts by wheelspinner20
Old May 05, 2012, 11:11 AM
Lee is offline
Lee
Find More Posts by Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
When I am carrying my radio once the power is on on my plane I have my left thumb hold the throttle down. I have seen enough accidental throttle ups that I am careful.
I think a tie down strap is a great idea. A simple rubber band strap can do the same thing too.
Lee is offline Find More Posts by Lee
Old May 05, 2012, 12:35 PM
Stone1295 is offline
Find More Posts by Stone1295
AMA 937634
Stone1295's Avatar
United States, AK, Anchorage
Joined Jan 2010
Thanks for the advice guys!
I just added a 'ninja' style throttle lock to my Tx.
-Mike
Stone1295 is offline Find More Posts by Stone1295
Old May 05, 2012, 06:47 PM
Planes in flames,,,
Gravity Sucks
Joined Aug 2010
hahaha- before you know it there will be Ninjalocks all over Alaska
Next thing you know they will be all over the world.
muhahahahaha
Old May 06, 2012, 11:33 AM
Lee is offline
Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
Some one was telling us that they use a similar elastic strap for the DLG flyers and the flaps that they plug into the throttle channel.
Old May 06, 2012, 10:57 PM
elCapitan is offline
Find More Posts by elCapitan
wheeeeee!
elCapitan's Avatar
United States, UT, Provo
Joined Oct 2011
No update on the Reaper, RUBnorris? What happened when you tried to hold it up balancing at 10.5"?
elCapitan is offline Find More Posts by elCapitan
Old May 06, 2012, 11:06 PM
RUBNorris is offline
Find More Posts by RUBNorris
New Beeeeee
RUBNorris's Avatar
United States, CA, Sacramento
Joined Apr 2011
Tryed again to fly my wing........still no good. It's a lost cause. I GIVE UP ON MY REAPER.
RUBNorris is offline Find More Posts by RUBNorris
Old May 06, 2012, 11:16 PM
wheeeeee!
elCapitan's Avatar
Joined Oct 2011
But did you try to hold it up on 10.5"? Flying it again without really figuring out the problem won't change anything, and I think a few of us here are curious.
Old May 06, 2012, 11:26 PM
New Beeeeee
RUBNorris's Avatar
Joined Apr 2011
yup, finger was actually pass the 10.5" mark that i put on. about 11.5" back on mine. How could i put this thing together wrong? I got video, but i was kinda pissed about the flight. I've made scratch build planes fly better then this. Could it be the weight? maybe, i got too much weight?
I'll have to cut another hole out the move the battery between my other holes that i have already made. MORE HOLES
Old May 06, 2012, 11:39 PM
Planes in flames,,,
Gravity Sucks
Joined Aug 2010
11.5 is most likely too far back.
I wouldn't cut any more holes until you find a configuration that is working out for you.
You are worried about the weight, what is your all up weight?
What exactly happens when you try to fly it.
Are you getting a successful launch?
Ar you able to attain controlled level flight?
Are you able to trim for level flight at all?
You mentioned before that it nosed down when you power it off? -Is that still the main issue that you are having?
Old May 07, 2012, 05:38 AM
redrob is offline
Find More Posts by redrob
USA, KY, Letcher
Joined Feb 2005
I always velcro the battery on and check CG and even fly it before I cut out for it. Just fill the holes you got in it up with the extra epp from the aile and glue it up. Then Iron a piece of laminate over it. Then velcro the battery in the right spot and fly it moving it around till u get it right then cut it back out.
redrob is offline Find More Posts by redrob
Old May 07, 2012, 09:01 AM
wheeeeee!
elCapitan's Avatar
Joined Oct 2011
11.5 is a bit far back, yeah, and I'm curious what your all-up weight is.
Sold Reaper GR60 Stagger_Wing Aircraft - Electric - Power Systems (FS/W) 0 Jan 13, 2010 01:43 AM
Sold Reaper GR 60 wrpsr1911 Aircraft - Electric - Power Systems (FS/W) 0 Jan 06, 2010 09:28 PM
Build Log House of Balsa "Grim Reaper" P51 Mustang Gun Jam Electric Warbirds 28 Dec 20, 2009 03:25 PM
Discussion Body count... Grim but it's really gotta be done. Bilbobaker Life, The Universe, and Politics 15 Nov 15, 2009 01:09 PM
Gallery Grim reaper Wickett R/C Pumpkin Contest 1 Oct 31, 2005 04:37 PM
