Old May 02, 2012, 10:24 PM
fritzdecat is offline
Find More Posts by fritzdecat
Smoke me a Kipper
fritzdecat's Avatar
Cedar Grove North Carolina
Joined Oct 2006
tail heavy and it noses in? did he mention a stall ?
video the launch Mr Rub
get to the bottom of this
fritzdecat is offline Find More Posts by fritzdecat
Old May 02, 2012, 11:28 PM
RUBNorris is offline
Find More Posts by RUBNorris
New Beeeeee
RUBNorris's Avatar
United States, CA, Sacramento
Joined Apr 2011
I'll try to post a flying video on my lil' prob. tomorrow it's going to rain but i'll try to get out. It's just hard to see everyones plane fly sooooo well and mine gives me a head ach. lol
RUBNorris is offline Find More Posts by RUBNorris
Old May 03, 2012, 12:07 AM
elCapitan is offline
Find More Posts by elCapitan
wheeeeee!
elCapitan's Avatar
United States, UT, Provo
Joined Oct 2011
I still think we need to get to the bottom of the CG question. How are you measuring CG?
Remember, CG isn't something you can just choose to move around. Depending on the shape of the airfoil, surface area, etc, the CG is calculated to be inherently at a certain point. How you build your plane will make it either nose heavy, tail heavy, or balance on CG. The reaper's CG is 10.5" back from the nose.
elCapitan is offline Find More Posts by elCapitan
Old May 03, 2012, 08:01 AM
CaribbeanBlue is offline
Find More Posts by CaribbeanBlue
Joined Jul 2010
I think you are confusing people>>The CG is the Centre of Gravity and that is where each individual wing really balances by definition.
The actual CG will be moved depending on how the wing is built>> you move the CG by moving weight ( usually Batt ) towards nose or tail
We need to build so that the actual CG is where its planned to be after the plane is finished.
I suggest we need to agree the planned or target CG ( or a range ) for each model and build to that?
~~~~H
CaribbeanBlue is offline Find More Posts by CaribbeanBlue
Old May 03, 2012, 08:18 AM
wheeeeee!
elCapitan's Avatar
Joined Oct 2011
Yes, you're right. We're saying the same thing with different words. Technically any object in the world has a center of gravity--the point at which it balances--but what I mean is that the "proper" (or as you say, "target") CG for the Reaper is 10.5", and that's where CG should be. That's what you can't just change because you feel like it. I could build a Reaper that balances 3" behind the nose (and you'd say my CG is at 3", and you'd be right), but my CG is wrong. If I held it up and tried to balance it at the proper CG, 10.5", I'd find out that I'm actually very nose heavy.
In the video, he says, "I put the CG up here because I wanted to run two batteries" and points at the nose, about 4" back. That right there makes me think there's something wrong with how it's being measured.
SO... for RUBNorris, my question is, how are you measuring CG? In other words, if you measured back 10.5" from the nose, then used a square or something to extend that point out to the sides, then tried to balance your Reaper along that line, what happens? Does it tip forwards or backwards, and how badly?
Old May 03, 2012, 02:45 PM
McCleary.11 is offline
Find More Posts by McCleary.11
McCleary.11's Avatar
United States, OH, Delaware
Joined Mar 2006
I have seen the CrashTestHobby video for proper take offs (and apparently didn't learn anything). Can I be the star if the video for incorrect take offs comes out?
5 stitches... Keep your fingers out of the prop! I was lucky it wasn't much much worse.
I have the entire thing recorded with my GoPro! I will post it up later...
On a positive note, I maidened my Reaper XL and it flew Great!
McCleary.11 is offline Find More Posts by McCleary.11
Site Sponsor
Old May 03, 2012, 02:56 PM
wheeeeee!
elCapitan's Avatar
Joined Oct 2011
You're not cleaning the blood spatters off the elevon, are you!?
Glad the DRXL flew well for you. Makes it worth it, right? What motor/prop you using?
Heal up quick!
Old May 03, 2012, 03:01 PM
jetpackninja is offline
Find More Posts by jetpackninja
Planes in flames,,,
jetpackninja's Avatar
Gravity Sucks
Joined Aug 2010
Yeah man- definitely worth the time to perfect one of the safer launching techniques.
I tangled with a prop myself and it wasn't much fun. 13 stitches and some industrial strength pain killers. It's all good now but I cringe any time I see somebody launch with their hands back by the motor. Heal well.
jetpackninja is offline Find More Posts by jetpackninja
Old May 03, 2012, 03:12 PM
Joined Mar 2006
Yes, that is blood spatter on the wing! Someone call Dexter!
I am using the 2812-14 Cobra motor with a 10x5 prop on 3s.
Actually my hand was in front. I had just landed a minute before to adjust a camera. Since it was morning, there was dew on the grass which got the wing wet. When I hit the power, my hand slipped a little and allowed it to pivot towards me. While cutting the throttle, my hand must have went to hold the plane up and I got sliced.
Site Sponsor
Old May 03, 2012, 03:23 PM
Planes in flames,,,
Gravity Sucks
Joined Aug 2010
v.1 of the Ninja throttle stick safety.
Rev2 Is on my transmitter now.
I'll try to get some good pictures.
One day maybe I'll start selling these things. I could make millions...
http://www.rcgroups.com/forums/showthread.php?t=1369101
Old May 03, 2012, 03:27 PM
Joined Mar 2006
I like it! Not sure I could afford one of those fancy gadgets though...
Site Sponsor
Old May 03, 2012, 03:30 PM
Planes in flames,,,
Gravity Sucks
Joined Aug 2010
Rev2 cost exponentially more, and still within the Ninja budget
Old May 03, 2012, 03:41 PM
wheeeeee!
elCapitan's Avatar
Joined Oct 2011
Anyone with a Turnigy 9X, go into your settings (for each model) and active the "Throttle Hold" setting. Every time I land, the first thing I do is flip the furthest top left switch, and it doesn't matter if I bump the throttle stick, the motor's not going to turn. Great safety feature.
I also used it once when some kids suddenly ran to try to catch my Albatross as I was landing at a park.
My guess is other tx's have a similar switch setting
Old May 03, 2012, 04:01 PM
Planes in flames,,,
Gravity Sucks
Joined Aug 2010
BTW one of my favorite things is watching people try to throw their wing into the air and forgetting to turn off their throttle lock
Old May 03, 2012, 07:15 PM
ashdec87 is offline
Find More Posts by ashdec87
ashdec87's Avatar
United States, MI, Detroit
Joined Feb 2004
And that's why I use a bungee launcher lol
ashdec87 is offline Find More Posts by ashdec87
Sold Reaper GR60 Stagger_Wing Aircraft - Electric - Power Systems (FS/W) 0 Jan 13, 2010 01:43 AM
Sold Reaper GR 60 wrpsr1911 Aircraft - Electric - Power Systems (FS/W) 0 Jan 06, 2010 09:28 PM
Build Log House of Balsa "Grim Reaper" P51 Mustang Gun Jam Electric Warbirds 28 Dec 20, 2009 03:25 PM
Discussion Body count... Grim but it's really gotta be done. Bilbobaker Life, The Universe, and Politics 15 Nov 15, 2009 01:09 PM
Gallery Grim reaper Wickett R/C Pumpkin Contest 1 Oct 31, 2005 04:37 PM
