Old Apr 30, 2012, 11:03 PM
Lee is offline
Lee
Find More Posts by Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
Mike used the 3536 - 1400 with a 9x6 prop on both his DRXL and his Herc Pusher. This is the same motor Scott and another Mike used in their 72 minute flight. It has a lot of power, a great price and isn't much bigger than the 3530.
Lee
Lee is offline Find More Posts by Lee
Old Apr 30, 2012, 11:46 PM
jbmccoy205 is offline
Find More Posts by jbmccoy205
jbmccoy205's Avatar
columbus, ohio
Joined Aug 2010
This is a pic with the Cobra motor with a 3530 1700Kv... Its very small.......
jbmccoy205 is offline Find More Posts by jbmccoy205
Old May 01, 2012, 12:05 AM
elCapitan is offline
Find More Posts by elCapitan
wheeeeee!
elCapitan's Avatar
United States, UT, Provo
Joined Oct 2011
Thanks for the pic. You're right, that is a bit small.
Thanks for all the input, everyone. So I think I'm going to try a 3536 1400kv with a 3000 or 3300 4S battery. ...now I just have to get the parts and build the thing.
elCapitan is offline Find More Posts by elCapitan
Old May 02, 2012, 02:30 PM
redrob is offline
Find More Posts by redrob
USA, KY, Letcher
Joined Feb 2005
I'm interested in getting a reaper to compliment my scythe. I have the power system from a crashed out stryker q. It's the 40 amp esc and BL park480 out-runner 2200kva. Will that work well with the reaper? or better suited to the assassin.
redrob is offline Find More Posts by redrob
Old May 02, 2012, 03:03 PM
jetpackninja is offline
Find More Posts by jetpackninja
Planes in flames,,,
jetpackninja's Avatar
Gravity Sucks
Joined Aug 2010
The 2200kv is going to be a lot noisier than the 3530 1700 motors we like to use on a Reaper.
it would probably work, I'd guess you'd need a smaller prop than we like to use (maybe a 6x4?)
Where do you fly? Is noise an issue?
There are several Reaper flyers that are actually going with a 3530 1400kv motor and using a larger prop. (like maybe a 9x4.7) and are really happy with the results.
What kind of flying do you intend to do?
If you are thinking about doing FPV you are probably gonna be happier with one of the bigger prop setups. For combat, I like the cheap 7x6 props on the 1700kv motor.
jetpackninja is offline Find More Posts by jetpackninja
Old May 02, 2012, 04:07 PM
redrob is offline
USA, KY, Letcher
Joined Feb 2005
I only plan on normal flying. I like the bigger wings as they are easier to see and tend to float well. I have the 2200 sitting on the shelf and would be nice to put it to use. Noise is not an issue. I guess it's worth a try.
Old May 02, 2012, 04:16 PM
Planes in flames,,,
Gravity Sucks
Joined Aug 2010
BTW- I was born in the beautiful state of KY.
I spent a good portion of every summer there and almost every holiday all through my youthful years. I miss it dearly- maybe I'll retire there one of these days
Old May 02, 2012, 04:43 PM
redrob is offline
USA, KY, Letcher
Joined Feb 2005
I agree it is a beautiful place. I live in the far eastern portion of the state and we have plenty on flat level areas to fly due to mining. I have a reclaimed mine 10 mins from home with about 3 square miles of flat grass on top of the mountains. No homes or property to worry about. Fly as far, fast, loud as you want and no one complains. If you crash the only thing to worry about is the plane it's self.
Old May 02, 2012, 04:49 PM
Planes in flames,,,
Gravity Sucks
Joined Aug 2010
Sounds gorgeous. Post an in flight vid if you ever do such a thing.
Old May 02, 2012, 05:05 PM
redrob is offline
USA, KY, Letcher
Joined Feb 2005
Will do. I have a couple slow sticks to take vids with.
Old May 02, 2012, 07:46 PM
RUBNorris is offline
Find More Posts by RUBNorris
New Beeeeee
RUBNorris's Avatar
United States, CA, Sacramento
Joined Apr 2011
Ok so here is the video of my reaper that i can't seem to balance out. It flys OK but it's takes alot of work. I dont know what to do with it. It's gonna have alot of holes in it.... To me it seems like the battery needs to go back more. Wings are not my thing i guess?
CTH Reaper HELP! (4 min 54 sec)
RUBNorris is offline Find More Posts by RUBNorris
Old May 02, 2012, 09:24 PM
fritzdecat is offline
Find More Posts by fritzdecat
Smoke me a Kipper
fritzdecat's Avatar
Cedar Grove North Carolina
Joined Oct 2006
I think you still need to add some weight back by the esc ....just a tiny bit
Go with a 9 X 6 E
Don't giver up yet
fritzdecat is offline Find More Posts by fritzdecat
Old May 02, 2012, 09:39 PM
Lee is offline
Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
http://www.youtube.com/watch?v=RjDys...e_gdata_player
I wish I could come and fly it for you. Locally I trim in a lot of planes and usually a problem is something simple and correctable.
I have seen many things happen that make a plane fly strangely. Seeing that you are flying a Scythe the Reaper should be easier to fly so something has happened which would make me think there is a set up problem.
I have great confidence in the Reaper. If you look at the Swarm competition we just had most of the planes in the video are Reapers.
Here is the check list from the website for things to check.
http://crashtesthobby.com/articles/10-mistakes-to-avoid
Flyers I have helped have the following problems.
CG is not right. I frequently see planes that are tail heavy and many flyers mistake a stall for nose heavy. If the plane rolls or tip stalls instead of going flat and level to the ground it may be tail heavy not nose heavy. The Reaper can carry a large battery and camera and balance. This may be the problem.
Servos are too weak or reversed. I have seen a dozen planes this year with up and down or elevons reversed. This happens to even experienced flyers.
I have seen planes with linkage problems that under any type of stress are flexing or servos moving especially under compression. If the right signal isn't getting to the elevons the plane can't fly. This most frequently happens if the pushrod is from the tip of the servo arm to the horn on the elevon and there isn't enough leverage.
I see you have not used the standard elevons and this is OK but they have to have the right amount of movement or it will stall the wing before it even gets up to speed. We use bigger elevons on our planes because they have less drag. Because the elevons are bigger they don't have to move as much to get the same effect on the wing. If they move too much they will stall the wing and make the plane seem out of balance. If they don't move enough you don't have the time to get the plane under control before it is on the ground.
I have seen props on backwards and weak batteries that are not giving enough power.
I have seen many flyers who are having trouble launching the bigger plane.
I hope this helps. I know the plane design is a great design.
Lee
Old May 02, 2012, 10:03 PM
Smoke me a Kipper
fritzdecat's Avatar
Joined Oct 2006
Exhaust every option
Because the one thing you can do with this plane is hammer it into the ground and try again til you get it right
Show me another plane that can do that ...
Old May 02, 2012, 10:20 PM
fnffishcore is offline
Find More Posts by fnffishcore
fnffishcore's Avatar
United States, MD, Chesapeake Beach
Joined Jan 2011
Just my 2, it looks to me like it'd be tail-heavy. My setup is very similar to yours, except my batteries are definitely further forward. Even with my GoPro attached to the nose, I'd typically have my lipos (2 x 1500mah or 1 x 4000mah) closer to the front. Of course if it noses down under glide, moving the batteries forward would probably make that worse... And I totally contradict what fritzedcat said earlier, hehe
fnffishcore is offline Find More Posts by fnffishcore
Sold Reaper GR60 Stagger_Wing Aircraft - Electric - Power Systems (FS/W) 0 Jan 13, 2010 01:43 AM
Sold Reaper GR 60 wrpsr1911 Aircraft - Electric - Power Systems (FS/W) 0 Jan 06, 2010 09:28 PM
Build Log House of Balsa "Grim Reaper" P51 Mustang Gun Jam Electric Warbirds 28 Dec 20, 2009 03:25 PM
Discussion Body count... Grim but it's really gotta be done. Bilbobaker Life, The Universe, and Politics 15 Nov 15, 2009 01:09 PM
Gallery Grim reaper Wickett R/C Pumpkin Contest 1 Oct 31, 2005 04:37 PM
