Take your time Lee...and all testers....good things come in time..I am loving both my Titan and Assassin...so I am watching this to see how we go on this one. Never rush the batch grandma used to say.....it spoils the cookies. |
Thankyou for your loyality.
Let me describe the 60" Grim Reaper in the air. The flying ability of this plane is excellent. It can carry weight and would be a good camera platform. I was doing low passes with it on Saturday and 2 spectators ordered one. We have cut about 60 of these over the years mostly for our club for combat. The variation we have done with this kit is that it has less sweep for more lift and a little slower speed. It has a thinner airfoil design than the Titan but is still thick enough to stand a battery on it's side to protect it from combat damage. The GR as shown weighs about 2lb AUW. At that weight it needs the bigger motor. With the bigger motor and the bigger battery I was able to get CG without adding weight. This plane can easy carry 8+oz of battery battery. My prime battery that I use on most of my planes is the 1300 3s so I put 2 side by side that isn't shown in this picture. The A-frame spar system is so stiff I was getting "OOOoooos and aaahhhhhhs" as people felt how strong it is. It feels almost as strong as a vacuum bagged glass plane, especially with the laminate on it. It doesn't bend and there isn't the slightest hint of a flutter. I did death dives and hard loops over and over and the plane just did what it was told. I used 1/8" round fiberglass spars on this plane. The round fiberglass rods are very strong but flexible so they needed to be both top and bottom on the plane to get the rigidity. I have fiberglass rods and flat carbons spars in stock for those who want to order them with the kit. It takes 6x of the 3' spars of which ever you want to use. I will however tell you that I am not afraid of using the 1/4" spruce dowels or square stock that is available at your local hardware lumber yards for spars. The carbon will add $20 to the kit and the fiberglass spars will add $15 to the kit. I am flying this R/D finless it is very controlable but I did have more yaw than with some of the smaller planes because of the thin wing and the overal weight of the plane. All of our kits are cut at the angles to add fins on the tips when we ship them if you don't want to go finless. |
The Park 480 is rated at 275 watts but I have to use a rather large prop which makes it have a lot of drag. I used it before on a 48" glassed Divinity at 27 oz. It did have the power but I didn't like the drag. I will re think the motor. Something in the 1500-2200Kv range and a smaller prop. What motor/ prop are you using on the one pictured? Are you using HiTec 82 MG's or something larger?
Thank you for your time, Kent |
This is the motor. It is rated at 340W. Mine is an older model that is a different color but the same motor. I fly it with the same prop as the CF28-12 the 7x6.
This motor will run 4S!!! The plane could easily handle it!!! http://www.hobbycity.com/hobbycity/s...idProduct=3885 Lee ,. |
The 480 will need a bigger prop than is reasonable on the Reaper. Meaning you would need large cutouts of the ailirons also the 480 weighs I think 3.5 ounces. Get the motor Lee recommends, I think 1700KV with a 7X6 prop and 3S will be right at 300 watts. Cliff |
The Grim Reaper is a big plane. At our altitude we need to have a little more power than at sea level. I would like to hear what other motors people are trying. |
With two recomendations I'll go with the Turnigy TR35-30A-1700 @ $18.20
Turnigy Plush 60a speed control @ $34.58 Programming card @ $6.95 Four Rhino2150ma two cell 20c @ $8.79 ea. (no Zippy Flightmax in stock) $98.49 + shipping Running two two cells in series will weigh a little under 9.5oz. Not sure what to do about spars. Was thinking about tapering plywood with flat carbon top and bottom caps to make an "I" beam. I don't know about the weight though as compared to something else. Would be very strong I think. Bill Steven's of Steven's Aero could laser me some out of ply. I live at 6,500 feet and know what you mean by having to have a little more power. Your shipping is always fast since we are neighbors
| Thread Tools | |
| Sold Reaper GR60 | Stagger_Wing | Aircraft - Electric - Power Systems (FS/W) | 0 | Jan 13, 2010 01:43 AM |
| Sold Reaper GR 60 | wrpsr1911 | Aircraft - Electric - Power Systems (FS/W) | 0 | Jan 06, 2010 09:28 PM |
| Build Log House of Balsa "Grim Reaper" P51 Mustang | Gun Jam | Electric Warbirds | 28 | Dec 20, 2009 03:25 PM |
| Discussion Body count... Grim but it's really gotta be done. | Bilbobaker | Life, The Universe, and Politics | 15 | Nov 15, 2009 01:09 PM |
| Gallery Grim reaper | Wickett | R/C Pumpkin Contest | 1 | Oct 31, 2005 04:37 PM |
