United States, NJ, Manchester
Joined May 2011
Great video Rock!! I need to get my but in gear and finish my Herc, it looks very smooth!
Here is my latest video taken with my FPV Grim. It was a bit breezy in the places I was flying so allot of the video is a little bumpy. But it was the most fun I've had FPV flying!
Bwahahaha. Great stuff McG! Loved it.
Looks like you're getting bounced around just as much as I am. We need to build our larger FPV ships so we can get slightly more stable video around the cliff faces. I just finished swapping in the 1400kv motor with that prop, made a bunch of other fixes to the plane and spent more time trying to balance it. If you have a minute, could you measure the weight of your plane in ounces? Mine is 54 ounces, which seems really heavy to me. I'll bet yours is half a pound lighter based on the climb rate you're getting. Gonna try taking mine out today to see how it flies and see if it'll get me by while building the bigger Reaper. |
Zambia, Lusaka, Lusaka
Joined Jun 2005
was flying mostly at about 1/4 throttle... any prop suggestions to try b4 i remove the motor?thanks Willie
This is on the 1700KV motor |
Joined May 2011
found it! http://www.headsuprc.com/servlet/the...Hub-for/Detail |
no you just use the center part
order a set of these also and you will be good to go http://www.fpvmanuals.com/prop-stop/ watch the video |
Joined May 2011
I promise you will be satisfied with this setup, if not, I will buy it from you just to have a full backup set. have you ordered the props? Graupner sells a 6mm-8mm bushing for the yoke so that it fits tightly around the prop adapter. If need be I have an extra one that I can mail to you.
Joined May 2011
http://www.espritmodel.com/aeronaut-...ariation=20731 http://www.fpvmanuals.com/prop-stop/ http://www.headsuprc.com/servlet/the...Hub-for/Detail |
| Thread Tools | |
| Sold Reaper GR60 | Stagger_Wing | Aircraft - Electric - Power Systems (FS/W) | 0 | Jan 13, 2010 01:43 AM |
| Sold Reaper GR 60 | wrpsr1911 | Aircraft - Electric - Power Systems (FS/W) | 0 | Jan 06, 2010 09:28 PM |
| Build Log House of Balsa "Grim Reaper" P51 Mustang | Gun Jam | Electric Warbirds | 28 | Dec 20, 2009 03:25 PM |
| Discussion Body count... Grim but it's really gotta be done. | Bilbobaker | Life, The Universe, and Politics | 15 | Nov 15, 2009 01:09 PM |
| Gallery Grim reaper | Wickett | R/C Pumpkin Contest | 1 | Oct 31, 2005 04:37 PM |
