Old Oct 12, 2011, 11:08 PM
ROCKY2 is offline
Find More Posts by ROCKY2
TREES!!! Ouch!!!
ROCKY2's Avatar
Mexico, BC
Joined Jun 2009
Originally Posted by branflakes View Post
question
I bought what I thought was an elevon mixer from tower for the grim (my old radio doesn't mix) when the package got here, flaperon mixer is what's labeled
its the great planes mixer for the tower hobbies flying wing
put it in a plane and try and see if the elivator is elivators and the ailerons are ailerons
ROCKY2 is offline Find More Posts by ROCKY2
Old Oct 13, 2011, 05:22 AM
wheelspinner20 is offline
Find More Posts by wheelspinner20
wheelspinner20's Avatar
S.E.Michigan
Joined Jul 2010
thats what i was going to suggest. use a known working setup that is easy to get to receiver and use a couple new servos by themselves set on the bench like they would be in the reaper . take one pair and go to your good aileron and ele channels...and see what the loose servos do? straight up and down on elevator stick both servos should move same diretion. left right on stik they should move opposite.! take advantage if you get that far and mark all leads and seervo direction and double check before glueing them in!
wheelspinner20 is offline Find More Posts by wheelspinner20
Old Oct 13, 2011, 06:57 AM
ROCKY2 is offline
TREES!!! Ouch!!!
ROCKY2's Avatar
Mexico, BC
Joined Jun 2009
that doesnt matter you can still revers the servos after they are in
Old Oct 13, 2011, 02:35 PM
S.E.Michigan
Joined Jul 2010
rocky how many oz. does all your fpv stuff weigh? and what is minimum spee d it will go when fully loaded ? i know you can get 30 minutes out of your set up right? well when it was all still on the reaper.
Old Oct 13, 2011, 10:59 PM
ROCKY2 is offline
TREES!!! Ouch!!!
ROCKY2's Avatar
Mexico, BC
Joined Jun 2009
it all still is i can go about 65mph and my gear is about 3 ounces
Old Oct 14, 2011, 02:31 PM
S.E.Michigan
Joined Jul 2010
oh ok but what about minimum speed how slow does your osd show in mph before it stalls and or you cant really turn it??
Old Oct 14, 2011, 09:48 PM
ROCKY2 is offline
TREES!!! Ouch!!!
ROCKY2's Avatar
Mexico, BC
Joined Jun 2009
no osd but pretty slow
Old Oct 15, 2011, 02:42 PM
Kerbob is offline
Find More Posts by Kerbob
Kerbob's Avatar
Knoxville, TN
Joined Apr 2008
GoPro folks.. can you post a few photos of your GoPro mount location along with your other gear?
Kerbob is offline Find More Posts by Kerbob
Old Oct 15, 2011, 02:44 PM
Bear_Pants is offline
Find More Posts by Bear_Pants
United States, NJ, Manchester
Joined May 2011
Good plan! I just got mine yesterday and Need mounting ideas. I was thinking of cutting a small square for the go pro to fit and just taping her down. The case for it is way heavy.
I'm thinking right behind and to the left of my FPV camera.
Bear_Pants is offline Find More Posts by Bear_Pants
Reply With Quote  (Disabled)
Old Oct 15, 2011, 03:09 PM
Kerbob is offline
Kerbob's Avatar
Knoxville, TN
Joined Apr 2008
I leave the case off when it is on my EasyStar, but I think I want to use the case on this one. I plan for this to be much more acrobatic/wild than my EasyStar and want the extra protection from the case. I'm going to use the Skeleton Case so I can plug in my cables though.
Old Oct 15, 2011, 03:11 PM
Joined May 2011
Your using your GoPro as an FPV camera? If so I wouldn't use it for acrobatics then.
Old Oct 15, 2011, 04:47 PM
jetpackninja is offline
Find More Posts by jetpackninja
Planes in flames,,,
jetpackninja's Avatar
Gravity Sucks
Joined Aug 2010
Rocky did a nice vid showing his GoPro mount setup. Check out the build threads on his youtube channel. http://www.youtube.com/user/rockyFLYR
jetpackninja is offline Find More Posts by jetpackninja
Old Oct 15, 2011, 04:50 PM
Joined May 2011
That's for the hercules. Right?
Old Oct 15, 2011, 04:53 PM
Planes in flames,,,
Gravity Sucks
Joined Aug 2010
Yeah- I get confused sometimes.
Ryan and Cardo both have GoPro's set up on some Reapers.
A couple 'o pictures?
Old Oct 15, 2011, 04:55 PM
Joined May 2011
I'd love to use the case around the go pro as it's nice insurance. But the extra weight is what kills me. That's why I was figuring I can inbed it into the foam a bit. and put some foam around it to protect it.
Sold Reaper GR60 Stagger_Wing Aircraft - Electric - Power Systems (FS/W) 0 Jan 13, 2010 01:43 AM
Sold Reaper GR 60 wrpsr1911 Aircraft - Electric - Power Systems (FS/W) 0 Jan 06, 2010 09:28 PM
Build Log House of Balsa "Grim Reaper" P51 Mustang Gun Jam Electric Warbirds 28 Dec 20, 2009 03:25 PM
Discussion Body count... Grim but it's really gotta be done. Bilbobaker Life, The Universe, and Politics 15 Nov 15, 2009 01:09 PM
Gallery Grim reaper Wickett R/C Pumpkin Contest 1 Oct 31, 2005 04:37 PM
