Old Aug 16, 2010, 01:41 PM
Lee is offline
Lee
Find More Posts by Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
Ryan was telling me that he likes the Reaper for a FPV because he now has long range radio and can cover more area int the same amount of time than with the trainer type FPV planes.
We also had a flyer fly into a fence wide open throttle with his Grim Reaper this week. The fence was about 200 feet long and the whole thing shock with the force of the impact and the plane bounced at least 10 feet and made a horrible sound. The flyer is a little on the new side and was sure his plane was destroyed. The scary part is he had landed inside the property of a known RC hater who is quick to call the police even though he has soccer games around his house most of the summer nights and weekends. Luckily the property owner didn't answer the door and the plane was quickly retrieved.
Even with the WOT impact the plane only suffered a couple of foam tears. The fiberglass spars were intact and the radio was protected except for his ESC which is still intact but stopped working. It speaks well for the plane that can survive that kind of abuse. The flyer worked glue into the tears and taped it in place while it cured and was flying the plane the next day.
Lee
Lee is offline Find More Posts by Lee
Old Aug 16, 2010, 01:50 PM
cliffo is offline
Find More Posts by cliffo
cliffo's Avatar
San Antonio, TX
Joined Jul 2004
I take small animals for rides on my Reaper.
cliffo is offline Find More Posts by cliffo
Old Aug 16, 2010, 10:19 PM
scootty83 is offline
Find More Posts by scootty83
THAT'S WHAT SHE SAID!!!
scootty83's Avatar
Joined Aug 2009
What is the best sweep angle to have on the Reaper? I've heard taking 1"-2" out of the trailing edge of each wing is the best. Would you all agree? What have you tested and what provides the best speed:glide ratio?
scootty83 is offline Find More Posts by scootty83
Old Aug 16, 2010, 11:01 PM
chicken hawk is offline
Find More Posts by chicken hawk
Plane Insane RC.com
chicken hawk's Avatar
Spanish Fork Utah
Joined Mar 2005
I took 2 inches from each wing out of mine. I like the way it flies. I was afraid if I took more I would need to add lead to the nose. Couldn't tell you about the speed:glide ratio. All I know if it flies great. I just added some nav lights so soon I'll be posting some night FPV action.
chicken hawk is offline Find More Posts by chicken hawk
Old Aug 20, 2010, 04:35 PM
saucisse is offline
Find More Posts by saucisse
Don't disturb the pilot !!!
saucisse's Avatar
Canada, QC, Quebec
Joined Jun 2008
Anyone can tell me what happened in this video? I crashed 2 times this afternoon and don't know why
It was quite windy and looks like the wind turned over the plane.
http://www.vimeo.com/14304047
saucisse is offline Find More Posts by saucisse
Old Aug 20, 2010, 06:25 PM
Lee is offline
Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
I know in the other video you had some collisions with a tree and such. Check your servos and make sure you didn't strip a gear and double check the CG. It might be a snap roll which happens when the CG is a little to far back and you have too much movement in the elevons. It might also be the push rods flexing if they aren't secured in the middle. The fact that it rotated a couple of times and didn't pull out would suggest the set up problems I described.
Old Aug 20, 2010, 07:28 PM
saucisse is offline
saucisse's Avatar
Canada, QC, Quebec
Joined Jun 2008
Lee, I've check everything twice and found nothing. I just came back from my after dinner flight and flew 6 packs without any problem... Today the GR went through maybe 15 packs total and the only time I had problems where these 2 events shown in my video....
After each crash I've look at the Spektrum receiver/satellite (AR6200) to make sure no failsafe were involved and the LEDs were not blinking.
I'm kind of clueless since this plane is rock steady in the air...maybe it was too windy? Wind was blowing maybe 20-30 mph. Each time it happened I was facing the wind and making a turn in the direction of the wind.
Anyways, I'll keep an eye on it. Good thing this plane and the GoPro's polycarbonate casing are indestructible (knock on wood for now) .
Old Aug 20, 2010, 08:38 PM
Mike_Then is online now
Find More Posts by Mike_Then
I hate waiting for parts
Mike_Then's Avatar
United States, NC, Garner
Joined Apr 2001
How difficult are these to assemble? I'm a take-it-out-of-the-box-and-fly-it kinda guy so my assembly skills are limited to extremely-easy ARFs...
Mike_Then is online now Find More Posts by Mike_Then
Latest blog entry: F-14 resurrection
Old Aug 20, 2010, 10:46 PM
Lee is offline
Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
This is a rock solid steady plane designed for AP/FPV. I wish you were close by that I could fly it and check it out. Most of the problems we see are easily fixed in seconds and usually have to do with the things previously mentioned. GRs are becoming a regular in our combat sessions even carrying cameras at times.
Which servos are you using? I have seen some weak servos at times that just aren't strong enough for a 2 lb plane.
Old Aug 20, 2010, 10:49 PM
Lee is offline
Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
They are easy once you have built one. Here are the instructions with links to building videos that show some of the builds.
http://www.rcgroups.com/forums/showp...31&postcount=7
The advantage of a plane like this is how much abuse it can take. Most flyers first comment on how far it will glide with the power off then they comment on how tough it is.
Old Aug 20, 2010, 10:54 PM
saucisse is offline
saucisse's Avatar
Canada, QC, Quebec
Joined Jun 2008
Lee, I'm using the Hitech HS-82MG.
Old Aug 20, 2010, 11:08 PM
Lee is offline
Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
That is what I am using. On one of the prototypes I put bigger servos and it did increase the roll rate since the plane is so big. We might be overloading the servos in aerobatics.
Old Aug 20, 2010, 11:11 PM
saucisse is offline
saucisse's Avatar
Canada, QC, Quebec
Joined Jun 2008
Here's my last video with the GR. Above the Plains of Abraham in my hometown.
http://www.vimeo.com/14309761
Old Aug 21, 2010, 05:03 AM
Lee is offline
Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
Can I buy advertising on the nose of your plane?
That's some pretty country you live in. we are in the desert and everything but the irrigated sod farm here goes gray and brown this time of year.
Looks like it is flying good!
Old Aug 21, 2010, 05:33 AM
Lee is offline
Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
I have received some advice that I thought to pass along to help decrease the shakiness of the video.
If you look at many of the APV videos you will see that it looks like flyers are often making a lot of small flying adjustments in flight. This is an caused by the exaggerated illusion of small movements in the plane with an attached fixed camera. A small direction change in the plane makes a huge sweep of the direction of the camera.
First make sure the plane is trimmed so that it flies straight and level with hands off so you won't need to make many corrections. Simply fine trimming the plane will often smooth out your video.
Second, fly with thumb and finger on the right stick not just thumb. When flyers shoot video while just flying with the thumb on the stick there is a jerky look to the video, especially on a plane as powerful and as instantly responsive as the Grim Reaper. When you pinch the right stick on the transmitter it smooths out some of the jerky look to the video because it forces you to use slower stick inputs and helps prevent the bumping the stick which can be seen on the video.
Third is fly for the camera. Think smooth flat bombing runs and long smooth turns and aim the plane at what you want people to see and let the plane have some flat and level flight time traveling towards the target. I was looking at a video over a waterway in Norway and saw just a glimpse of a boat dock that I would have liked to see more of but it was only on the video for a second or two as the plane was in a turn. I'm sure if the pilot knew I had interest he could have given me a better look.
Fourth, It is always fun to see the pilot flying. Do some low strafing run passes. People notice if you put yourself in the video and show where you are standing to shoot the video.
Sold Reaper GR60 Stagger_Wing Aircraft - Electric - Power Systems (FS/W) 0 Jan 13, 2010 01:43 AM
Sold Reaper GR 60 wrpsr1911 Aircraft - Electric - Power Systems (FS/W) 0 Jan 06, 2010 09:28 PM
Build Log House of Balsa "Grim Reaper" P51 Mustang Gun Jam Electric Warbirds 28 Dec 20, 2009 03:25 PM
Discussion Body count... Grim but it's really gotta be done. Bilbobaker Life, The Universe, and Politics 15 Nov 15, 2009 01:09 PM
Gallery Grim reaper Wickett R/C Pumpkin Contest 1 Oct 31, 2005 04:37 PM
