Old Jul 24, 2010, 03:48 PM
trees is offline
Find More Posts by trees
Slope Sauce
trees's Avatar
White Salmon WA
Joined Oct 2009
That would work with one side but on the other side I criss-crossed the spars so I could actually tie them together with string. I had no idea.
trees is offline Find More Posts by trees
Old Jul 24, 2010, 06:38 PM
Lee is offline
Lee
Find More Posts by Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
Like I said it will probably be OK with out the extra reinforcement.
Flex your wing. Are you seeing movement where the spars meet? If so it should be an easy modification to add a tie rod between the two rods.
I haven't reinforced many of the connections where the cross piece of the middle spar connects to the spars on the leading edge although it is a good idea.
Lee
Lee is offline Find More Posts by Lee
Old Jul 24, 2010, 07:29 PM
trees is offline
Slope Sauce
trees's Avatar
White Salmon WA
Joined Oct 2009
It survived a 150' dive into the water so it's probably fine.
Old Jul 24, 2010, 07:34 PM
Lee is offline
Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
150' and survived is good!!!
Old Jul 28, 2010, 09:51 PM
etman is offline
Find More Posts by etman
Flying with the eagles
etman's Avatar
Eagle's nest
Joined Nov 2008
Ok I'm gathering parts for my GR build.
This is going to be an FPV platform for my GoPro.
Target AUW 1.4 kg
I have these
HS-82MG x 2
8 ch RX
3s 2200 mah x 1 OR 4s 2200 mah x 1 ??
To buy
40A ESC
7 x 6 APC prop
1700 kv motor
I often fly in tight spaces with trees around, should I do a crow mix to get it to slow down quickly?
Then I'll need another two servos and cut the elevons into half.
Outer elevons go up, inner elevons go down.
etman is offline Find More Posts by etman
Old Jul 28, 2010, 10:47 PM
chicken hawk is offline
Find More Posts by chicken hawk
Plane Insane RC.com
chicken hawk's Avatar
Spanish Fork Utah
Joined Mar 2005
Finally
It's taken me a few months but I finally had some time to work on my GR FPV. It's sporting a new look. Pan and tilt camera with Key cam for on board recording. Copilot for stabilization (I hope it works). Remzibi's OSD, Dragon Link UHF for long range, 500mW 2.4 transmitter. I'm going to start with a 2200mah battery and possibly go to 4400mah for longer flights. I'll be running camera and plane off the same battery right now. This will change if the video looks bad.
Test flight will be tomorrow. Wish me luck.
Ryan
chicken hawk is offline Find More Posts by chicken hawk
Old Jul 29, 2010, 05:34 AM
Lee is offline
Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
Wow!!!!
I've seen what Ryan can do with the camera and it is impressive.
Lee
Old Jul 29, 2010, 11:27 PM
Plane Insane RC.com
Spanish Fork Utah
Joined Mar 2005
I test flew it today. Weather was great! We had a small group. I think there were 4 counting me. In the group I fly with there are a couple of assassin kits and a titan. None of the guys have seen the Reaper so when it went up fully loaded it was a collective Ahhh. I think I may have sold a couple of Reapers for you today Lee. The wing flew great but the video had a lot of static. I will defiantly be using a separate battery for video. My dragon link went into fail safe a couple of times. I'm not sure why. I have had that same radio out to a mile with no glitches. The work continues.
Old Jul 29, 2010, 11:47 PM
etman is offline
etman's Avatar
Eagle's nest
Joined Nov 2008
Any videos please?
Old Jul 30, 2010, 11:56 AM
Plane Insane RC.com
Spanish Fork Utah
Joined Mar 2005
I did record the on board video to my laptop. I haven’t had a chance to look at it but I don’t think it turned out very good. My goal for this first flight was to make sure it would fly the weight safely and have enough power to get up to altitude fast. I think it was a success. I’m using the Titan Core Kit with the C3530-1700kv motor and 30amp ESC. I’m not going to have a chance to post any video for a couple of days.
Old Jul 30, 2010, 08:07 PM
saucisse is offline
Find More Posts by saucisse
Don't disturb the pilot !!!
saucisse's Avatar
Canada, QC, Quebec
Joined Jun 2008
I was finally able to do de maiden flight tonight and after 3 launches (its too nose heavy right now) I was able to record a 13min flight with the GoProHD.
I'll post the video later on.
This is going to be my primary FPV rig so tomorrow I'll do some more testing to get the CG right and add my EzOSD along with EzUHF LRSand 500mw ImmersionRC 2.4Ghz Tx.
Some pictures for now,
Did a custom mount using the ''fixture'' the GoPro is attached too in its original box. The are zip ties that goes trough the frame and attaches underneath using a plate to distribute the force...sorry don't know how to say this correctly in English.
Dispite being too nose heavy for now the plane is pure joy to fly!!! This will make a perfect FPV rig!!!
The ''under plate'' which is carved in the foam so the bottom of the plane is flush.
The fins:
saucisse is offline Find More Posts by saucisse
Old Jul 30, 2010, 08:09 PM
saucisse is offline
saucisse's Avatar
Canada, QC, Quebec
Joined Jun 2008
Here's the video:
Flying wing Grim Reaper maiden flight with GoPro HD onboard (4 min 13 sec)
Old Aug 07, 2010, 12:33 AM
Plane Insane RC.com
Spanish Fork Utah
Joined Mar 2005
Nice Vid Saucisse. I like the gopro much better than what I'm using for FPV. I'll mount the gopro up again soon.
Here is a video from today. It's long and boring so grab some popcorn.
Grim FPV 8 6 2010 (5 min 33 sec)
Old Aug 08, 2010, 08:21 PM
saucisse is offline
saucisse's Avatar
Canada, QC, Quebec
Joined Jun 2008
If anyone is still in doubt about this plane not being tough...just watch this small clip:
http://www.vimeo.com/13988168
Old Aug 08, 2010, 08:27 PM
etman is offline
etman's Avatar
Eagle's nest
Joined Nov 2008
Hi guys,
I just received my GR. Will be building it soon.
I think I'll add two more pieces of formica for the GoPro Mount and make four screw holes in my GoPro mount for that.
Sold Reaper GR60 Stagger_Wing Aircraft - Electric - Power Systems (FS/W) 0 Jan 13, 2010 01:43 AM
Sold Reaper GR 60 wrpsr1911 Aircraft - Electric - Power Systems (FS/W) 0 Jan 06, 2010 09:28 PM
Build Log House of Balsa "Grim Reaper" P51 Mustang Gun Jam Electric Warbirds 28 Dec 20, 2009 03:25 PM
Discussion Body count... Grim but it's really gotta be done. Bilbobaker Life, The Universe, and Politics 15 Nov 15, 2009 01:09 PM
Gallery Grim reaper Wickett R/C Pumpkin Contest 1 Oct 31, 2005 04:37 PM
