Joined Jan 2011
Longer Flight Times?
I'm looking to set up an FPV wing, and am hoping for 20-30 minute flight times. I'm not looking to fly super aggressively, so I'd be okay to sacrifice a bit of max-speed for longer flights. Any suggestions on how to set up a GR like this? Do you think that the standard 35-30A 1700 motor, combined with a 2700mah or 3300mah 3-cell battery would do the job? Even if carrying a GoPro?
![]() Thanks for any suggestions you can give me! |
What does the wing fly like when it is nose heavy? Is there a lack of control in pitch? Also, how much throw/deflection are you using Rocky? |
can you get a link to the servos i use these servos and work great and i flew my reaper at 3 pounds 5.2 ounces
http://www.hobbyking.com/hobbyking/s...idProduct=6608 |
Joined Jan 2011
Thanks ROCKY2,
I'm not on a super-tight budget (although I think the Team Black Sheep Zephyr Kit for $1400 is a bit out of my range...). I already have 1 set of FPV gear working great in my EZStar, and another set (including a 2nd DragonLink receiver, free from referring a friend) ready to install into a wing. So what I still need to figure out is mostly the wing's power system. Motor, battery, prop. If you're getting 38 minute flights on a 3500mah battery, and you're happy with how it flies, then I think I'll just try to duplicate your setup! ![]() Could you tell me what motor you use, and do you suggest a folding prop to reduce drag and landing damage? Thanks! |
Also bieng nose heavy isn't bad, I like knowing that if I am having issues such as a faulty ESC, etc. I can get some glide speed quickly....saved my @$$ the other evening |
Here is what I am using. A little more power than yours, Rocky.
http://www.valuehobby.com/product_de...21&item_id=480 |
| Thread Tools | |
| Sold Reaper GR60 | Stagger_Wing | Aircraft - Electric - Power Systems (FS/W) | 0 | Jan 13, 2010 01:43 AM |
| Sold Reaper GR 60 | wrpsr1911 | Aircraft - Electric - Power Systems (FS/W) | 0 | Jan 06, 2010 09:28 PM |
| Build Log House of Balsa "Grim Reaper" P51 Mustang | Gun Jam | Electric Warbirds | 28 | Dec 20, 2009 03:25 PM |
| Discussion Body count... Grim but it's really gotta be done. | Bilbobaker | Life, The Universe, and Politics | 15 | Nov 15, 2009 01:09 PM |
| Gallery Grim reaper | Wickett | R/C Pumpkin Contest | 1 | Oct 31, 2005 04:37 PM |
