Old Feb 24, 2010, 12:49 PM
Rudderman98 is offline
Find More Posts by Rudderman98
AMA 670207
Rudderman98's Avatar
United States, WA, Sumner
Joined Oct 2000
Originally Posted by everydayflyer View Post
Made up my parallel charger / Quanum adapters and updated post
http://www.rcgroups.com/forums/showp...1&postcount=56
with results. I am a very happy camper.
Charles
Charles,
Would love to see some pics.
Perry
Rudderman98 is offline Find More Posts by Rudderman98
Old Feb 24, 2010, 01:21 PM
Highfly! is offline
Find More Posts by Highfly!
Highfly!'s Avatar
United States, CA, Cameron Park
Joined May 2007
Wow, never thought about that. I would like to see my wifes face when I show up at the table with my mobile phone, ipod and now also a Quanum....
Charles
Highfly! is offline Find More Posts by Highfly!
Old Feb 24, 2010, 09:46 PM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Primary reason for purchse
http://www.rcgroups.com/forums/showp...9&postcount=13
Charles,
Perry
Pictures of what? A Y balancing harness is just a bunch of wires.The two displays do not photograph well together as one is backlite and the other is not and the Quanum swaps (no signal) when close to the transmitter.
If you are asking how the just in parallel as if you were balancing two packs in parallel.
Charles
Old Feb 24, 2010, 11:39 PM
wolffcub is offline
Find More Posts by wolffcub
wolffcub's Avatar
Joined Apr 2007
Got my unit today! I cant wait to try it out this weekend. I never mounted it on the antenna but instead installed it to my radio strap clip. It fits perfect and not i don't have to worry about some potential binding issues some are saying might happen if you bolt it right around the radio antenna. It leaves plenty of room under the unit to reach all the toggles and trims. Plus the radio still fits perfectly in my flight kit.
I will do the testing on my cub first so if something happens its no big loss, cheap and easy to fix. I secured the transmitter into the fuselage and notched the battery try to allow the balance plug leads to stick out. see pic. Plenty of room available in the belly for the antenna for the transmitter also.
wolffcub is offline Find More Posts by wolffcub
Old Feb 25, 2010, 07:43 AM
jet-ster is offline
Find More Posts by jet-ster
Watts Up?
jet-ster's Avatar
USA, TX, Arlington
Joined Jun 2006
here is mine on my 2.4 JR 9303
jet-ster is offline Find More Posts by jet-ster
Old Feb 25, 2010, 08:31 AM
skeppley is offline
Find More Posts by skeppley
2 Turbos...Nope 1 Big one
skeppley's Avatar
United States, PA, Lake Wynonah
Joined Aug 2004
Now those look pretty cool mounted up on the transmitters.
Thats a great idea on the dx7.
Guess i'll have to order now
skeppley is offline Find More Posts by skeppley
Old Feb 26, 2010, 08:53 AM
Southern Pride
Yes it works in parallel with a charger.
Old Feb 28, 2010, 10:28 PM
Tommy D is offline
Find More Posts by Tommy D
Hooper, full throttle!
Tommy D's Avatar
USA, NY, East Islip
Joined Feb 2004
Charles, no effect at all <in other words it does not disturb charging/balancing?>
Tommy D is offline Find More Posts by Tommy D
Old Mar 01, 2010, 08:13 AM
Southern Pride
No effect at all that I can detect. Now I can get more than 10 feet from a liPoly being charged without having to rush back to my charging area every few minutes.
Think about it. The transmitter uses very little current(30 mA?) I have not verified this as yet and is a load not a resistence.
Charles
Old Mar 01, 2010, 10:14 AM
Tommy D is offline
Tommy D's Avatar
USA, NY, East Islip
Joined Feb 2004
Thanks Charles. I would only use this in flight to help diag a problem <let a spotter read it>. However for at home charging this is a plus!
Can I bind it to say more then one RX and switch between them if I charge more then 1 pack at a time?
Thanks!
Tommy D
Old Mar 02, 2010, 04:41 PM
paracanary is online now
Find More Posts by paracanary
paracanary's Avatar
La Habra, California
Joined May 2004
polarity protection
Curious if the transmitter is protected against plugging in the balance leads backwards. Anyone done this yet?
paracanary is online now Find More Posts by paracanary
Old Mar 02, 2010, 05:34 PM
JJJNYC is offline
Find More Posts by JJJNYC
Talk to me Goose ...
Poquott, NY
Joined Jun 2009
Many times ... its worked out fine.
JJJNYC is offline Find More Posts by JJJNYC
Old Mar 02, 2010, 05:40 PM
paracanary's Avatar
Joined May 2004
Thanks, it saves me a lot of worry
Old Mar 03, 2010, 03:09 PM
paracanary's Avatar
Joined May 2004
Alarm fix
Has anyone tried putting 100 ? ohm resistors in series between the battery and transmitter to knock the volts down by .5 for each cell. Maybe a small diode would be better. This would give relative volts and the alarm would be at a more practical 3.6 volts. This could be done with a small circuit board plug in. As it is now, the alarm just tells you when your battery pack is destroyed.
Old Mar 03, 2010, 03:32 PM
CyberJay is offline
Find More Posts by CyberJay
Rsetiegerd Uesr
CyberJay's Avatar
USA, AR, Cave Springs
Joined Apr 2005
I like this thing but I'm going to hold out for the next revision.
I'd like to see adjustable voltage levels for the alarm and I'd like to see extensive audible alerts. At a minimum two alarms, one for "start thinking about landing" and one for "get it on the ground right now!" It would be even neater(is that a word? ) if it would verbally announce the voltage every minute and then alarm at whatever you had it set to. 3.5/3.6 sounds good to me.
-Jay
CyberJay is offline Find More Posts by CyberJay
Discussion Quanum battery voltage telemetry - and 'voltage under load' question ... JJJNYC Batteries and Chargers 51 Oct 22, 2014 11:55 AM
For Sale 2.4 Friendly Super Star - Can B Picked Up at SWC Blayne Chastain Aircraft - Sailplanes (FS/W) 6 Mar 02, 2010 08:28 AM
For Sale Sprite "Mini Supra" 2 Meter TD - Can B Picked Up at SWC Blayne Chastain Aircraft - Sailplanes (FS/W) 1 Jan 26, 2010 01:19 PM
Discussion dreamped up this last night fer the footies. nigelpheron Sailboats 12 Feb 07, 2007 07:58 AM
Picked this up at a yardsale today...need some help! kctrading Beginner Training Area (Fuel) 16 Mar 30, 2005 11:23 PM
