Old Jun 07, 2010, 04:48 PM
rp181 is offline
Find More Posts by rp181
Joined Mar 2010
Someone open it up and look to see if the USB data wires are connected. If they are, they should connect to a FTDI chip. That means you can use it for other things, it would take a little snooping though.
rp181 is offline Find More Posts by rp181
Old Jun 07, 2010, 06:15 PM
jj604 is offline
Find More Posts by jj604
ancora imparo
jj604's Avatar
Melbourne, Australia
Joined Jul 2005
I'll hack my V1 Rx when I get a moment. Won't be surprised to find an ATMEL micro inside and the the 6 pads for ICSP programming on the board BUT then it will take someone cleverer than me to figure out how to reprogram it.
John
jj604 is offline Find More Posts by jj604
Old Jun 07, 2010, 09:07 PM
rp181 is offline
Joined Mar 2010
I would be surprised to find an atmel (those are general purpose, specilized is cheaper) in it
If the USB data lines are connected, chances are the firmware already supports it. Hard part is figuring out what it does.
Old Jun 07, 2010, 10:34 PM
jj604 is offline
ancora imparo
jj604's Avatar
Joined Jul 2005
I'm no expert but the HobbyCity $7 6A ESC's have Atmega 8L's in them from memory so I don't think they can be regarded as costly.
One way to find out. Screwdriver, where are you?
Old Jun 08, 2010, 03:16 AM
jaccies is offline
Find More Posts by jaccies
The Netherlands, LI, Venray
Joined Dec 2008
Originally Posted by paracanary View Post
i am sure that usb port is used for other things besides charging. Wouldn't it be nice if it could be used for calibration and changing the alarm values.
thats right, but lack of service is a major bad thing of this company, look at their website , V2 is not mentioned at all....
this company Quanum is same as Durafly who sells planes, i bought one a Cessna but they are not willing to sell spareparts for this plane....FUNNY and is bad service.
jaccies is offline Find More Posts by jaccies
Old Jun 08, 2010, 03:52 AM
jj604 is offline
ancora imparo
jj604's Avatar
Joined Jul 2005
Here's what a V1 Tx and Rx look like inside. Ident has been ground off all the chips but the Rx is pretty simple. It has a USB chip and a micro which to my uninformed eye seems to do all the signal processing, including the 2.4GHz decoding.
Both Tx and Rx have the 6 pads for ICSP programming.
Expert comments welcome.
John
PS Bet those three unused holes on the Tx are where the v2 sensor lead attaches. So maybe you could even reprogram v1 TX to be V2 and add the lead -- just a wild thought.
Old Jun 08, 2010, 04:18 AM
J.E. Johnson is offline
Find More Posts by J.E. Johnson
Newcastle
Joined Oct 2003
How do you change the screen to have the Amp, Temp and MAH reading? Does it do it automatically once you attch the additional sensors? I have one of these but have only used it for volts per cell so far. I have the temp and Amp sensors but not used them yet.
J.E. Johnson is offline Find More Posts by J.E. Johnson
Old Jun 08, 2010, 04:35 AM
psychosaffa is offline
Find More Posts by psychosaffa
touching cloudbase not cloth!
psychosaffa's Avatar
UK
Joined Dec 2009
you just press the bind button once.
psychosaffa is offline Find More Posts by psychosaffa
Old Jun 08, 2010, 05:40 AM
Newcastle
Joined Oct 2003
thanks
Old Jun 09, 2010, 01:26 AM
Newcastle
Joined Oct 2003
Help please!
Mine does not change when I press the bind or power button.
When I start it up it says v2.0.0.0
Has anyone else had this issue? It is pretty pointless having the temp and amp upgrade if I can't see the readings.
Old Jun 09, 2010, 04:07 AM
UK
Joined Dec 2009
Help please!
the v2 tx has what looks like a servo wire attached to it, are you sure that this is connected to the right terminal and not the temperature terminal? also make sure that everything is connected to your batteries and that the tx is switched on before you switch on the rx.
hope this helps
Old Jun 09, 2010, 04:20 AM
Newcastle
Joined Oct 2003
hope this helps
I don't have anything connected to the transmitter except for the battery it is reading at this stage
Because when I asked before I read this to say you only had to press the bind button. Hmmm I will hook up the amp and temp portion and report what happens! I might get lucky and look silly when it works!
Old Jun 09, 2010, 04:25 AM
Newcastle
Joined Oct 2003
Okay this is how it works:
You have to hook up the additional temp sensor to the transmitter and then rebind this to the receiver.
Once the unit has bound it works exactly as described - push the bind button to switch between volts and volts/temp/amp/Mah display.
Thanks for your help guys!
Old Jun 10, 2010, 06:21 AM
diver don is offline
Find More Posts by diver don
"Each Day Is A Lesson"
diver don's Avatar
Goldsboro, NC
Joined May 2004
My,V-2, is on it's way, but I have one question.
Can the "Temp" be displayed in Ferienheit or or it just Celcius?
Thanks.
DD
diver don is offline Find More Posts by diver don
Old Jun 10, 2010, 06:35 AM
UK
Joined Dec 2009
Thanks.
DD
just celcius, unless im missing something something somewhere.
Discussion Quanum battery voltage telemetry - and 'voltage under load' question ... JJJNYC Batteries and Chargers 51 Oct 22, 2014 11:55 AM
For Sale 2.4 Friendly Super Star - Can B Picked Up at SWC Blayne Chastain Aircraft - Sailplanes (FS/W) 6 Mar 02, 2010 08:28 AM
For Sale Sprite "Mini Supra" 2 Meter TD - Can B Picked Up at SWC Blayne Chastain Aircraft - Sailplanes (FS/W) 1 Jan 26, 2010 01:19 PM
Discussion dreamped up this last night fer the footies. nigelpheron Sailboats 12 Feb 07, 2007 07:58 AM
Picked this up at a yardsale today...need some help! kctrading Beginner Training Area (Fuel) 16 Mar 30, 2005 11:23 PM
