Old Feb 11, 2010, 11:27 PM
bob_loblaw is offline
Find More Posts by bob_loblaw
bob_loblaw's Avatar
Antarctica
Joined Dec 2009
4s on a 2-3s motor
Is putting 4s through a motor which states that it's for 2-3s a certain death sentence for the motor, or might it be fine if only used at WOT for very short bursts?
It's a suppo outrunner, so it's a decent motor with decent (and oiled) ball bearings.
Thanks.
bob_loblaw is offline Find More Posts by bob_loblaw
Old Feb 12, 2010, 12:22 AM
Xpress.. is offline
Find More Posts by Xpress..
Team Hitec, Customer Support
Xpress..'s Avatar
United States, CA, Poway
Joined Oct 2007
Prop accordingly. The amps are what can kill a motor. If you prop down, then you should be fine
Xpress.. is offline Find More Posts by Xpress..
Old Feb 12, 2010, 05:45 AM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Being decent and properly oiled will not help it if you are exceeding its limits.
If you are going to be using a higher voltage then rated then you should really invest in a watt/amp meter to see what is actualy happening.
Proping down is a must, by not doing so you could be almost doubling the amp draw and this could result in fried ESC and or motor or BOTH.
freechip is offline Find More Posts by freechip
Old Feb 12, 2010, 08:33 AM
jackerbes is offline
Find More Posts by jackerbes
Jack
USA, ME, Ellsworth
Joined May 2008
The watt meter is the key to figuring it all out. That and your fingers.
Use those on some 15 to 30 second static runs, checking the ESC and motor for heating as you do it. Stop the motor and use you fingers for the heat checks if nothing else is available. Too hot to keep you fingers on is 130F/53C, much hotter than that and you/'re headed for trouble.
The heat in the motor will be build in stator and the stator mount/base so feel the fixed part of the motor for heat, not the rotating part.
If your ESC has a linear BEC the extra voltage to drop the battery voltage to the 5V BEC voltage will be turned into heat too. So you'll probably feel a hot spot on one side of the ESC as it drops BEC voltage and then when you start running the motor the field of MOSFETs on the other side of the ESC will start heating up.
It is not too abnormal for the MOSFETs to get too hot to touch at full throttle but if the the temperature continues to climb it will eventually either lead to a overload shutdown (if you're lucky) or a fried ESC. Once you find the spot where the ESC does not exceed 160-180F or so you don't want to exceed that.
Jack
jackerbes is offline Find More Posts by jackerbes
Old Feb 12, 2010, 09:04 AM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
heat test is good but you must understand that its based on what you feel is hot or not. My pain tolerance mite be different then yours but either way, if you are serouis about the hobby the a watt/meter will take the guessing out and you will be able to get the most out of the system.
Old Feb 12, 2010, 08:38 PM
Challenger 413 is offline
Find More Posts by Challenger 413
Challenger 413's Avatar
Dickinson, Tx.
Joined Sep 2004
As long as you prop/gear the motor for the higher voltage, you shouldn't have any problems. The main problem with using high voltage/low amps (HV/LA) is that, most will like the higher power and forget the throttle...
If you prop/gear the motor properly and use good judgement on the throttle, you should see more power and longer flight times.
Challenger413
Challenger 413 is offline Find More Posts by Challenger 413
Old Feb 13, 2010, 02:33 AM
Threshold is offline
Find More Posts by Threshold
Threshold's Avatar
London UK
Joined Jul 2004
I always though that a motor was wound for max efficiency for a certain number of cells. So if you use a higher count you are going to lose efficiency? So the best option if you want to use 4 cells is to get a 4 cell motor. Can anyone verify this?
Threshold is offline Find More Posts by Threshold
Old Feb 13, 2010, 10:43 AM
MikeRx is offline
Find More Posts by MikeRx
MikeRx's Avatar
Dallas, Texas
Joined Dec 2009
Weight is my concern with high power setups but YEA, I'm doin 4cells on a E-Flight 300 motor that comes on the mini P-40. It draws 10.5amps peak around 140 watts with the included 7.2x5 prop..more than double the reccomended 2 cell power reccomended! Heat is NO issue. The setup is constucted of 2 Dualsky 25c 450mah 2cell batteries wired with a jst series harness through a Electrifly 12a controller (rated for 4 cells!) on a Great Planes Riot biplane. AUW is 9.3 oz, batteries and harness is 2.2 oz.
I have flown and tested back to back 2, 3, and 4 cells on 3 different 300 size motors with favorable results. Heat only begins to build when static testing and motor comes down plenty cool from flight. I think the current motor could handle 5 cells on the current prop for short bursts with cooling downlines.. BUT what small controller with LIGHT WEIGHT could handle the voltage?? IDEAS PLEASE?
MikeRx is offline Find More Posts by MikeRx
Old Feb 13, 2010, 10:45 AM
MikeRx is offline
MikeRx's Avatar
Dallas, Texas
Joined Dec 2009
Depends on the amount of draw that is asked of a given motor...prop down and you will see MORE efficiency on many setups.
Sold Batteries 4s 4200,3s 5000, 3s 850, 2s 1350 dodgindirt Aircraft - Electric - Batteries & Chargers (FS/W) 6 Jan 24, 2010 09:39 AM
Discussion equinox 4s adapter on 3s aceinthesky Batteries and Chargers 9 Nov 27, 2009 09:09 AM
Discussion mamba max pro on a 3s or 4s lipo 5th scale dragbikebam Motorcycles 9 Oct 27, 2009 09:04 PM
Sold (2) 4s 2100 20c, (2) 3s 1500 10c, TP 3s 1320 SrCrashAlot Aircraft - Electric - Batteries & Chargers (FS/W) 5 Mar 13, 2008 10:28 PM
