Old Feb 11, 2010, 09:58 PM
John Pilot is offline
Find More Posts by John Pilot
apprentice shipwright
John Pilot's Avatar
Little Rock, AR
Joined Sep 2005
Question
Bending brass K&S tubes
I'm in need of some expert advice on bending brass tubes . Diameters about 1/8" - 3/8". Bend radius I'm trying to achieve is about 2x to 3x tube diameter. Tried filling tubes with salt etc, tried heating them, but so far no luck getting decent bends.
I'm sure someone out there has this down to a science and is willing to share their knowledge.
Thanks in advance.
John Pilot is offline Find More Posts by John Pilot
Old Feb 11, 2010, 10:06 PM
ZZ56 is offline
Find More Posts by ZZ56
Nickel Belter
ZZ56's Avatar
Canada, MB, Winnipeg
Joined Jun 2009
I saw on TV that trombone and trumpet makers put a soap and water solution in brass tubes and freeze them solid before bending. The soap keeps the ice from shattering.
ZZ56 is offline Find More Posts by ZZ56
Old Feb 11, 2010, 10:11 PM
MILLERTIME is offline
Find More Posts by MILLERTIME
Taking care of the pond.
MILLERTIME's Avatar
United States, CA, Sanger
Joined Apr 2004
I got one of these, works good.
Dubro 1/8" Tubing Bender
http://cgi.ebay.com/Dubro-1-8-Tubing...item27ae8e6114
MILLERTIME is offline Find More Posts by MILLERTIME
Old Feb 11, 2010, 11:03 PM
Kmot is offline
Find More Posts by Kmot
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
You must anneal the brass tube first. Then pack it with salt, not loose but packed. Then crimp the ends so it cannot escape. Now, using a tube bending mandrel, make your bends. 2x and 3x tube diameter is an extremely tight radius. The Dubro benders cannot go that tight. A mandrel like the Higley is better for tight radii.
http://www3.towerhobbies.com/cgi-bin...P?I=LXL781&P=8
Kmot is offline Find More Posts by Kmot
Old Feb 12, 2010, 07:20 AM
der kapitan is offline
Find More Posts by der kapitan
"day ain't over yet-"
der kapitan's Avatar
Western N.Y. winemaking country
Joined Jun 2005
And again- I've mentioned this before, K&S makes malleable tubing that will work well for motor casings. I don't know about the small diameters that John Pilot is shooting for, but I'd have to say LOL---.
der kapitan is offline Find More Posts by der kapitan
Old Feb 12, 2010, 10:49 AM
Cold Duck is offline
Find More Posts by Cold Duck
Joined Nov 2005
Dowel Works
John, I used a wooden dowel with a 1/8" groove filed into it. It makes clean radius without crimping, bending, or collapsing the K&S tubing. My son-in-law (professional mechanic and not a model builder) "invented" the device when I whined about the trouble I was having. A picture is on page 6 of my build thread titled "F-31 Trojan Modification". After the grooved dowel solved the collapse/crimp problems, I had trouble getting the correct lengths for the multiple bends, so I added a Rube Goldberg guide for making a square structure with 90 degree bends. Hope this will help you.
Cold Duck is offline Find More Posts by Cold Duck
Discussion M i a s k i d s helicraig Micro Helis 77 Mar 09, 2010 09:43 PM
Question Need Mike K's help Xrayted Site Suggestions / Complaints 4 Jan 25, 2010 11:14 AM
For Sale Misc. brass rods and tubes, Nylon steering arm assemblies dan n Aircraft - General - Miscellaneous (FS/W) 0 Nov 25, 2009 10:08 PM
Discussion I need brass angle stock by K&S Engineering legacy3 Sailboats 2 Oct 17, 2009 08:05 AM
Help! Need K&S brass angle stock legacy3 Aerial Photography 0 Oct 16, 2009 05:53 PM
