Old Feb 11, 2010, 11:27 AM
ClayH is offline
Find More Posts by ClayH
ClayH's Avatar
92840
Joined Mar 2003
Do you use a an on/off switch in your sailplane?
I've used different methods of "turning on" my sailplanes thru the years. With many smaller planes I'd just use a short lead and connect to the battery via standard JR type connectors. In most of my 3 meter planes I'd always install an on/off switch with a charge lead attached. I'd usually use a standard size Cermark switch - not the monstrous types that JR produces. Recently I've had a couple of friends bring up switches as a just another failure point in the plane's electrical sytem. They prefer to use Deans Ultra plugs instead.
So just how safe is a quality ON/OFF switch ? How heavy duty does it need to be to function properly in our 6 servo sailplanes on 5 cells? Who makes the best on/off switches for our application ( modern molded planes)? How many of you feel that using Deans plugs is the best way to connect your battery to the receiver?
Clay
ClayH is offline Find More Posts by ClayH
Old Feb 11, 2010, 11:49 AM
schrederman is offline
Find More Posts by schrederman
Hot Dawg Glider Pilot
schrederman's Avatar
United States, TX, Weatherford
Joined Nov 2002
I haven't used switches in many years. My new Xplorer has a bus from the battery to the wing that by-passes the receiver. I'm using Ultra Plugs. The battery end has a servo connector for charging. The model plug has a servo plug going to the receiver. The rudder and elevator are the only 2 servos getting power from the bus in the receiver. I'll be retrofitting my 3.5 Xplorer to this system.
JW
schrederman is offline Find More Posts by schrederman
Old Feb 11, 2010, 11:58 AM
IHAVAWDY is offline
Find More Posts by IHAVAWDY
registered weapon
IHAVAWDY's Avatar
United States, MT
Joined Mar 2008
I had a switch short out on me ONCE. I am with the less is better crowd... switch bypass
IHAVAWDY is offline Find More Posts by IHAVAWDY
Old Feb 11, 2010, 12:13 PM
aeajr is offline
Find More Posts by aeajr
Proud member of LISF and ESL
LI, New York, USA
Joined Mar 2003
Yes I use a switch in all my sailplanes.
aeajr is offline Find More Posts by aeajr
Old Feb 11, 2010, 12:24 PM
ClayH is offline
ClayH's Avatar
92840
Joined Mar 2003
JW
Can you describe the bus setup from the battery to the wing?
Clay
Old Feb 11, 2010, 02:00 PM
Joined Nov 2002
From the plane portion of the plug, I took 2 - 22-guage wires per side (+ and -) directly to the DB-9 connector where the wing plugs on. I also soldered a servo connector lead on that plug for the receiver. I made single-wire servo leads to go from the receiver to the DB-9 to carry the signal to the wing servos. From the pack I soldered 2 - 22-gauage wires per side to the battery plug, and soldered a servo connector to the plug at the same time for charging. That's all in the 4-meter Xplorer build log in the F3X section. If that's still not understandable, I'll draw a wiring diagram and scan it in.
JW
Old Feb 11, 2010, 02:11 PM
R.M. Gellart is offline
Find More Posts by R.M. Gellart
R.M. Gellart's Avatar
Joined Nov 2005
Clay, I do not use a switch either, and am in the process of reworking a wire harness of my 801 to a system somewhat like Jack's but with input from Rob Glover and Chris Lee, both engineering types. When done, each wing side will be directly powered from the battery and and then downstream of that junctiour, it will feed the RX and the elevator and the rudder servos. I am using the new JR378 and 388 High Voltage servos with 2S LiPo pack of about 1800 mah, no regulator needed. Fairly simple to do and will really keep the wing happy especially during launch.
Marc
R.M. Gellart is offline Find More Posts by R.M. Gellart
Old Feb 11, 2010, 02:25 PM
atjurhs is offline
Find More Posts by atjurhs
agony sweetns the victory
atjurhs's Avatar
Any Flying Field Across America
Joined Jul 2005
I don't use on/off switches in any of my planes unless it's EPP
atjurhs is offline Find More Posts by atjurhs
Old Feb 11, 2010, 03:43 PM
SHVentus is offline
Find More Posts by SHVentus
Hawaii
Joined Feb 2009
Jack,
Not sure if it's the day or my old brain, but I'm not sure that I followed your explanation. Can you post both a diagram & some pictures of your bus & wiring? Thanks.
SHVentus is offline Find More Posts by SHVentus
Old Feb 11, 2010, 04:03 PM
atmosteve is offline
Find More Posts by atmosteve
Joined Nov 2007
I don't use swithces; extra weight, extra technicality waiting to fail etc. However i would recommend that new flyers use them at first, if asked.
atmosteve is offline Find More Posts by atmosteve
Reply With Quote  (Disabled)
Old Feb 11, 2010, 04:11 PM
Woodstock 1 is offline
Find More Posts by Woodstock 1
Woodstock 1's Avatar
Ireland, County Kerry, Kerry
Joined Dec 2005
No switches for me: I use the big Deans to connect the battery to a short lead into the Rx. The male (Rx side) connector I usually glue into the servo plate (from underneath) so that disconnection is a one-handed job.
Woodstock 1 is offline Find More Posts by Woodstock 1
Old Feb 11, 2010, 05:03 PM
tonyestep is offline
Find More Posts by tonyestep
Yep, Naza-controlled Tricopter
tonyestep's Avatar
St. Louis
Joined Apr 2002
I don't use a switch. When I time for hot-shot contest flyers I note whether or not they have a switch. A few do, but most do not. Many competition planes have little room for a switch, and of course there are many bad things that can happen that can outweigh the convenience of one-finger off/on.
tonyestep is offline Find More Posts by tonyestep
Old Feb 11, 2010, 05:45 PM
target is offline
Find More Posts by target
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Clay-
Here's something that I've been thinking about, similar to what is pictured above (replace the super-duty deans with a 3 pin deans instead)
T
target is offline Find More Posts by target
Old Feb 11, 2010, 06:04 PM
tewatson is offline
Find More Posts by tewatson
Riddle me this...
tewatson's Avatar
United States, CA, Orange
Joined Oct 2006
Good question. I have historically used a switch in everything, but the Freestyler 3 is a bit short on room, so these are the first planes I have not used a switch in. Battery is set up with polarized Deans micro connectors, and wing servos are powered directly from the battery, like Jack has done.
On/off is a two-hand task now, which is even more of a PITA since the FS3 uses an inverted cabin arrangement, but I'm confident in the power system. Another disadvantage is the requirement for a custom charge lead that also puts additional cycles on the pack-side connector.
My F3J planes still use switches, and I'm debating whether to continue to do so...the voltage drop through them is quite amazing and it's another potential failure point to consider. But, I've not had a single failure in 10 years of flying, so another thought is why mess with success?
Tom
tewatson is offline Find More Posts by tewatson
Old Feb 11, 2010, 06:15 PM
rogerflies is offline
Find More Posts by rogerflies
rogerflies's Avatar
Thomasville, GA 31792
Joined Apr 2002
I remember once seeing a three-wire phone jack used as a switch. It had three modes:
1. nothing plugged in = radio on
2. unwired plug inserted = radio off (This plug had a red streamer attached.)
3. wired plug inserted = battery charging
I've used regular switches on all my sailplanes, and I've never had a failure or problem with them. I've bypassed the receiver on some giant-scale power planes to provide battery power directly to some of the servos.
rogerflies is offline Find More Posts by rogerflies
Discussion DX7,How do you program throttle off switch? marcwv Radios 4 Feb 11, 2010 10:22 PM
Question Help with installing an on/off switch into a motor/ESC/servo set-up arukum17 Power Systems 3 Oct 09, 2009 03:21 AM
Discussion Where do you go to find maps and updates on controlled airspace in your area? skunkworks2006 FPV Talk 12 Sep 27, 2009 10:50 AM
Poll Do you use the same Lipos in your Heli & Airplane (Mix them) JezUK1 Electric Plane Talk 12 Aug 28, 2009 01:07 PM
Do you wire in an on/off switch in your setups? steve crewdog Beginner Training Area (Aircraft-Electric) 29 Jul 01, 2005 07:36 AM
