Espritmodel.com Heli Air
Old Feb 10, 2010, 09:28 PM
Aint nothing like a Mongrel!!
The_Mongrel's Avatar
Australia, NSW, Yass
Joined Dec 2007
Goof Proof Patch vs Commercial Patch
Hey All,
I was just doing a bit of reading and noticed that the Goof Proof Patch (SEEN HERE) and upscaled for 900mhz ends up at just over 10" (or 263mm)
However the ones that are readily available online like these http://www.rangevideo.com/index.php?...products_id=17 are all 8.5"
Why the difference in size?? I am curious.
Cheers
-J
The_Mongrel is offline Find More Posts by The_Mongrel
Old Feb 10, 2010, 09:43 PM
How do I change this text?
Darth_Elevator's Avatar
The Beautiful Mountains of Utah
Joined Oct 2006
Subscribed. I have both antennas and I've wondered the same thing.
Darth_Elevator is offline Find More Posts by Darth_Elevator
Old Feb 10, 2010, 09:45 PM
Joined Dec 2007
Cool!! I was glad it was not just me!!
Old Feb 10, 2010, 10:39 PM
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
The mediums between the receptor and reflector are different, thus effectively changing the velocity of propagation of the wave. Patches are a strange antenna, as they don't seem to follow the rules of the simple dipole.
The Goof proof patch uses an air medium. Commercial patches use some sort of material between the plates. I don't know what it is, though.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Feb 10, 2010, 11:14 PM
Canada, ON
Joined Jan 2009
Plus with the corners trimmed off it makes it circular polarized. http://www.cst.com/Content/Applications/Article/245
Martin Y is offline Find More Posts by Martin Y
Old Feb 11, 2010, 01:58 AM
Joined Dec 2007
Well that has another completely different size again!!
Old Feb 11, 2010, 02:31 AM
Romania, Dolj, Craiova
Joined Sep 2007
The key is in a material constant called "velocity factor", usually found in the cables specs.
Simply put, the size of the antenna in open air, must be divided by the velocity factor when using other insulator between elements. But in reality is more complicated, a more scientific paper can be found here.
On the site of this guy you can buy very large band log period antennas (900-2600Mhz ! ) made on PCB, at a very low price, $12, small dimensions (12 * 13 cm), and impressive specs.
The medium of some comercial antenna is PCB too, and the size difference can be seen here, on the GP patch site. The price of commercial patches comes more from the case and cabling than the antenna itself.
renatoa is online now Find More Posts by renatoa
Old Feb 11, 2010, 02:47 AM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
PCB = Printed Circuit Board
Most PCB patches have the ground plane on one side of the board, and
the driven element on the other, so the gap is determined by the thickness
of the board which is quite small, thus all the other dimensions have to scale
down accordingly.
The difference between GP Patch and the one on the page above
is not only the dieletric (air versus styrofoam) but the spacing between elements
and total gain. The page above doesn't say what their desired gain is, but you
can see their larger air gap version has a significantly higher gain than their
styrofoam version.
ian
Daemon is offline Find More Posts by Daemon
Latest blog entry: My 2012 FPV year in Review
Old Feb 26, 2010, 08:42 PM
THEY MOSTLY COME OUT AT NIGHT
chimaera's Avatar
Kaysville, Utah
Joined Jul 2005
I want to try one of these out. I have Thomas' revision of the GP patch and it calls for 0.060" aluminum ground plane and 0.12-0.20" copper or brass for the element. I would think the ground plane thickness could be about anything, but what about the element. Thicker vs thinner? Copper vs brass? I can get 0.030 or 0.005 locally but how will these work?
chimaera is offline Find More Posts by chimaera
Old Feb 26, 2010, 10:53 PM
Joined Dec 2007
After testing a commercially available patch for $60 - the performance is worth every dollar in my opinion.
Cheers
-J
Old Feb 26, 2010, 11:34 PM
Live FPV or Die
VRflyer's Avatar
Montreal,Canada
Joined Feb 2002
Cheers
-J
all commercial 900mhz antennas are linear polarization. i would prefer to buy a commercial circular polarisation antenna, but I will need to build the GP patch.
Or perhaps you sell circular 900mhz patch Mongrel ?
VRflyer is offline Find More Posts by VRflyer
Old Feb 26, 2010, 11:48 PM
Joined Dec 2007
Hmm... I thought circular polarisation was no good for what we want.
Hmm... Maybe I am confused.
Old Feb 27, 2010, 12:50 AM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
You are confused.
When two linearly polarized antennas are rotated 90 degrees from each other
they can experience a -20 to -30 dB drop in signal strength. Every 6 dB
represents a 50% reduction in effective range.
When a linearly polarized antenna transmits to a circularly polarized antenna it
experiences a constant -3dB loss but it's the same at all rotational angles.
That makes circularly polarized antennas good for tracking moving/turning targets.
You don't see more of them in use, simply because most commercially available
antennas are designed for stationary operation so they they'll just line em up
with each other and avoid the -3dB drop.
ian
Old Feb 27, 2010, 02:26 AM
I think my wheels fell off.
Thumb_number's Avatar
Perth
Joined Oct 2009
Have a look at the PDF of an CP patch I have just ordered. The company has lots of re-sellers near you. I'm paying too much for mine but it's a special order in Oz cause no-one uses them.
I'm getting this model for it's size and weight, perfect for P&T. It's not big on gain, actually only about 2-3dBi when you take into account the constant -3dBi but my intention is not long range, It's for penetration. I don't have a huge mountain to fly up, in fact my area is flat as. I like the low and fast style, so I hope this CP patch will work well when I'm below the tree line's while about 500m out.
Here's hoping anyway, will post any findings when it gets here.
Geo
Thumb_number is offline Find More Posts by Thumb_number
Old Feb 28, 2010, 02:55 AM
chimaera's Avatar
Kaysville, Utah
Joined Jul 2005
I'm hoping someone has an answer to this. I set up and milled a patch out as using these dimensions
http://www.webx.dk/rc/video-wireless/PATCH4.pdf
the element is not centered on the reflector in this one but on the original gp document it is but the element is not square. is this thing supposed to be symetrical? which is correct?
Discussion Goof Proof Patch Antenna for 900mhz EyeFlyPlanes Video Piloting (FPV/RPV) 21 Apr 19, 2009 01:31 PM
Discussion Omni vs Patch vs Yagi vs Dish blade thrasher Video Piloting (FPV/RPV) 2 Apr 05, 2009 11:17 AM
Discussion goof proof patch antenna IFLYRCAZ Video Piloting (FPV/RPV) 5 Dec 31, 2008 10:11 PM
Building a goof-patch antenna for Spylinker set up Canada Goose Aerial Photography 4 Mar 31, 2004 06:21 PM
Goof Proof Patch in Australia ? Lancair Aerial Photography 11 Oct 11, 2003 09:13 PM
