Old Feb 10, 2010, 06:18 PM
framos is offline
Find More Posts by framos
framos's Avatar
Joined Jul 2008
HK 450 - ESC and Engine hot hot hot
ESC and Motor too hot and eventually the engine off after a few seconds or not reach the speed to take off.
HK 450 ORIGINAL KIT
STOCK BLADES
ESC TOWER PRO H40A
MOTOR TURNIGY E500 4000K
WITH STOCK PINION 13T
BATTERY FLIGHTMAX 2200mAh 3S 20C
SERVOS 3X HXT900 AND INO-LAB201 TAIL
GYRO HK 401B CLONE
What is wrong with my settings? When I turn on the helicopter it runs for about 10 seconds and the engine off. The esc is very hot, although several people have recommended.
framos is offline Find More Posts by framos
Old Feb 10, 2010, 06:27 PM
planedude91 is offline
Find More Posts by planedude91
Gerktron Remix
planedude91's Avatar
La Crosse, WI
Joined Oct 2005
Well, 4000Kv is a little excessive for a 450, especially with a 13t pinion. Try using a 10t or 11t pinion.
planedude91 is offline Find More Posts by planedude91
Old Feb 10, 2010, 06:52 PM
Xrayted is offline
Find More Posts by Xrayted
Closed Account
Joined Dec 2007
Also make sure that you dont have the gear mesh between your pinion and main gear too tight when you change out the pinion. That will rob power and really heat things up. There should be a paper thickness gap between the teeth. I run a 3700Kv motor with an 11 or 12T pinion for sport flying.
Xrayted is offline Find More Posts by Xrayted
Old Feb 10, 2010, 07:19 PM
W,,,,,,,,,,,,,,,,,,,, is offline
Find More Posts by W,,,,,,,,,,,,,,,,,,,,
LoS sUAS AP/V is not a crime.
W,,,,,,,,,,,,,,,,,,,,'s Avatar
Grass Valley, CA
Joined Feb 2008
Yea waht Xrayted said plus....
Make sure the belt is not too tight and pull the head off and make sure everything moves without binding.
I had to ream out a few links to smooth my HK450 out.
W,,,,,,,,,,,,,,,,,,,, is offline Find More Posts by W,,,,,,,,,,,,,,,,,,,,
Old Feb 10, 2010, 07:25 PM
dze is offline
dze
Find More Posts by dze
dze
agreed, too high a kv motor to be efficient and really on the low side of wattage for 450, think closer to 250-300watt .. a small pinion probably wont even get it cool .. i would use that motor in a king2/300 size heli with a 9T likely ...
dze is offline Find More Posts by dze
Old Feb 11, 2010, 12:58 AM
prop bender is offline
Find More Posts by prop bender
USA, CA, Red Bluff
Joined Dec 2007
Allso--It helps if your throtle curve at half stick is at least 80%. Use a pinion like a 10 or 11 tooth. That lets your moter run closer to its power curve so it runs cooler, keeps the controller running cooler to! the smaller tooth pinion will slow the head speed down. A 4000kv moter with a 13 tooth pinion at 80% power curve is a bit wild hence the 11 tooth to tame it a bit. Hope this helps. PB
prop bender is offline Find More Posts by prop bender
Old Feb 11, 2010, 07:22 PM
jombo is offline
Find More Posts by jombo
Bad News Everyone
jombo's Avatar
United States, CT, Trumbull
Joined Dec 2007
its your esc ,
http://www.hobbycity.com/hobbycity/s...idProduct=9299
if you read the limits you are at the very edge with it, its your esc shutting down because the motor wants more power . you need this one , i have this 40a in mine with this motor and its fine all day long .http://www.hobbycity.com/hobbycity/s...idproduct=6387
http://www.hobbycity.com/hobbycity/s...idproduct=2165
jombo is offline Find More Posts by jombo
Old Feb 11, 2010, 09:49 PM
planemann2000 is offline
Find More Posts by planemann2000
United States, AR, Atkins
Joined Jan 2004
I've had the same problem with that ESC. Changed to another ESC with a 3 amp BES and cured the problem. I also run the E500 4000kv on a 13 tooth pinion with no over heating after I changed the ESC
planemann2000 is offline Find More Posts by planemann2000
Old Feb 11, 2010, 10:05 PM
skunkworks2006 is offline
Find More Posts by skunkworks2006
skunkworks2006's Avatar
Michigan
Joined Nov 2006
This is frustrating for me to read. I have that same motor and ESC waiting to swap out the Turnigy 2830 -3500kv and 30A Plush ESC. I've had fun with my set-up, but I'm ready to up the head speed and power for some mild 3D.
skunkworks2006 is offline Find More Posts by skunkworks2006
Old Feb 12, 2010, 01:21 AM
MicroJago is offline
Find More Posts by MicroJago
Wausau, WI
Joined Mar 2009
I have the same ESC with no issues.
MicroJago is offline Find More Posts by MicroJago
Old Feb 12, 2010, 07:49 PM
framos is offline
framos's Avatar
Joined Jul 2008
Thanks for the respose.
Xrayted - About the grip between the engine and main rotor, I afrox a little, to no avail. I changed the ESC by a SS 50-65A, not heated so much, has more faults to start the engine now does not work anything in the engine, only the BEC.
I returned to the H40A TowerPro ESC and motor worked, but even to 60% throttle. Not yet tested by changing the pinion, because there have one of 11 teeth, I'll buy and try.
I think the connections are not well soldered on new ESC (SS 50-65A), I weld it all over again.
Regarding configuration, already researched the forum and found some Class 450 with this engine and ESC of 30A (okay that was a Plush). Most really puts a 3700kv with 11T pinion. Has a video of a guy playing a 3D angry with 4000kv and 13T.
A friend told me to change blades for carbon, I will try too. The original blade has holes (not cast) and some adhesives. I did not cheat the patches, this may create some resistance. I change the blades and see what happens!
My heli does not leave the ground! Bad got hovering for about 5 to 10 seconds! 'm Headquarters!
Any other ideas?
I'll post some pictures and video of the heli for you to see.
Old Feb 12, 2010, 09:45 PM
framos is offline
framos's Avatar
Joined Jul 2008
Hi Guys,
Show! It worked!
I changed the blades to the carbon fiber. Heated much less, can you be holding his hand !
Now, what happened to the new ESC? Do burned? Well, it do not matter anymore.
Tomorrow I will test it on the field and return to describe the change actually solved definitively.
I appreciate the cooperation of all.
Old Feb 12, 2010, 11:43 PM
Wausau, WI
Joined Mar 2009
lol, good job. I think.
Old Feb 12, 2010, 11:54 PM
framos is offline
framos's Avatar
Joined Jul 2008
I agee Prop Bender, I'll change the pinion to 11T. I think to config throttle to 75% and put gauge pitch to +6 (now is +9) will to tame too, for now I don't change the pinion.
Discussion Flasher 450 VS. HK 450 comparison glenwyatt Mini Helis 238 Nov 22, 2010 12:31 AM
Discussion HK 450 : hard to be cheaper for a 450 KABAL99 Mini Helis 17838 Nov 09, 2010 01:52 PM
Discussion Hot Deals! Building an T-Rex/EXI-450 RC Helicopter hobbypartz HobbyPartz.com 0 Jan 25, 2010 01:04 PM
Sold hk-450 heli trex 450 clone bth9318 Aircraft - Electric - Helis (FS/W) 1 Oct 11, 2009 09:12 PM
Discussion Very HOT Eagle ESC on new Trex 450 blade thrasher Mini Helis 20 Jun 29, 2007 08:01 PM
