Old Dec 29, 2009, 04:18 PM
Crazy Eddie is offline
Find More Posts by Crazy Eddie
Newbee AMA # 912488
Crazy Eddie's Avatar
USA, FL, Pembroke Pines
Joined Sep 2008
Originally Posted by rcHeli101 View Post
It is recommended that beginners should set controls to 50% of the maximum possible or 25 degrees for ailerons and elevator. To achieve 25 degrees, should I move further out on the servo arm or should I move in to the inside hole on the control horn?
Jeff
For max deflection at the servo horn: Move pushrod inwards on horn.
For max deflection on control surface: Move pushrod outwards on the control horns.
Regards,
Eddie
Crazy Eddie is offline Find More Posts by Crazy Eddie
Old Dec 29, 2009, 04:38 PM
Liquidity is offline
Find More Posts by Liquidity
YardGoat lives with mama
Joined Feb 2007
Originally Posted by AzHeliCrasher View Post
Hey all, what futaba servos would you recommend for the SSX?
I can't stand hitec's and would use either Futaba or hobbycity servos
Umm. I used HS55s all around. So whatever is equal to that.
S75s would be fine on a SSX
Liquidity is offline Find More Posts by Liquidity
Old Dec 29, 2009, 04:39 PM
rcHeli101 is offline
Find More Posts by rcHeli101
United States, NC, Raleigh
Joined Oct 2009
Thanks, are they really $34.99 or did get them somewhere else at a better price? Or did they come with your radio?
They are $34.99 (slightly cheaper in places). The three that came with my DX7 needed new gears, so I bought three sets of gears and one new servo.
jeff
rcHeli101 is offline Find More Posts by rcHeli101
Old Dec 29, 2009, 08:09 PM
jdr43 is online now
Find More Posts by jdr43
jdr43's Avatar
USA, AR, Bella Vista
Joined Oct 2005
Regards,
Eddie
It's just the opposite !!! of what you say in your above statement
jdr43 is online now Find More Posts by jdr43
Old Dec 29, 2009, 08:13 PM
jamesppp is offline
Find More Posts by jamesppp
jamesppp's Avatar
Georgia, USA
Regards,
Eddie
I thought that moving the pushrod in (closer to the control surface)gives you more control throw for the same amount of pushrod movement(max deflection at the control surface). And, the farther out on the servo horn, the more the control surface moves.
jamesppp is offline Find More Posts by jamesppp
Old Dec 29, 2009, 08:55 PM
jkarpy is offline
Find More Posts by jkarpy
jkarpy's Avatar
USA, FL, Orlando
Joined Aug 2006
The Futaba S3114 would be fine.
jkarpy is offline Find More Posts by jkarpy
Old Dec 29, 2009, 08:57 PM
jkarpy is offline
jkarpy's Avatar
USA, FL, Orlando
Joined Aug 2006
You are correct!
Old Dec 29, 2009, 08:58 PM
jkarpy is offline
jkarpy's Avatar
USA, FL, Orlando
Joined Aug 2006
Currently, the ailerons are at +- 17 degrees and the elevator is at +-15 degrees. I'm using JR DS285 Servos with a Dubro EZ Connector mounted 10mm from the center of the servo arm for all channels. Servo travel is set to 100% on my Spektrum DX7.
Note that the elevator pushrod would not pass through the rear wing saddle pushrod guide if it were to move out further on the servo arm. Moreover, it seems that it might rub against the rubber bands as well.
Although I did not measure the incedence, I'd assume the rudder would get adjusted in the same manner as the other three channels, whether it be a longer control arm or moving the pushrod to the inside hole on the control horn.
Thanks for any insight!
Jeff
You can bend the rods in and then strait so you can go further out on the servo arms.
Old Dec 29, 2009, 09:11 PM
Joined Oct 2009
Thanks James!
Old Dec 30, 2009, 10:41 AM
Newbee AMA # 912488
Joined Sep 2008
Yep! I fudged that post up! Sorry!
Regards,
Eddie
Old Jan 01, 2010, 09:29 AM
_Lunchbox_ is offline
Find More Posts by _Lunchbox_
Hodgehound # 3
_Lunchbox_'s Avatar
Adrian, GA
Joined Mar 2005
James, you'll be happy to know that the 1st plane to leave the ground in 2010 at Hodges field was a SSX!!!!
_Lunchbox_ is offline Find More Posts by _Lunchbox_
Old Jan 01, 2010, 11:01 AM
Manta1 is offline
Find More Posts by Manta1
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
yea too bad it died upon landing,as jeff was the pilot.
Manta1 is offline Find More Posts by Manta1
Old Jan 01, 2010, 11:25 AM
Hodgehound # 3
_Lunchbox_'s Avatar
Adrian, GA
Joined Mar 2005
nope... I don't kill them like you do
Old Jan 01, 2010, 11:28 AM
Manta1 is offline
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
lol.
Old Jan 01, 2010, 01:25 PM
TipStalled is offline
Find More Posts by TipStalled
Mark 12:30
TipStalled's Avatar
United States, GA, Alpharetta
Joined Jan 2004
Rear saddle mount pieces.....
Flew in the new years with my SSX. IMC prevailed and a crash ensued due to spatial disorientation. All is repaired except for the rear saddle mount for the wing. Is there a print/diemension drawing that can be printed out ? I have some basswood and could cut some new ones. Can I order just the rear saddle-mount pieces ?
TipStalled is offline Find More Posts by TipStalled
Build Log Quick build Slow Stick mattyfly4fun Foamies (Scratchbuilt) 14 Feb 18, 2013 12:12 AM
Discussion Will this Slow Stick build "work"? chapped Beginner Training Area (Aircraft-Electric) 36 Mar 08, 2010 07:29 PM
Discussion Help me with a brushless Slow Stick build chapped Beginner Training Area (Aircraft-Electric) 10 Jan 13, 2010 12:27 PM
Sold Millenium X-gear Carbon Fiber Landing gear for Slow Stick Scirocco14 Aircraft - General - Miscellaneous (FS/W) 2 Jan 11, 2010 11:38 PM
