Old Feb 09, 2010, 11:24 PM
RC-ace is offline
Find More Posts by RC-ace
Joined Feb 2010
Increase RC range
How do I increase an RC planes range to lets say 5 miles?? xD
RC-ace is offline Find More Posts by RC-ace
Old Feb 09, 2010, 11:40 PM
Daemon is offline
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Search in this forum on keywords "long range"
ian
Daemon is offline Find More Posts by Daemon
Old Feb 11, 2010, 02:57 AM
renatoa is online now
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
If you are on 2.4Ghz RC, first thing you must do is to switch.
renatoa is online now Find More Posts by renatoa
Old Feb 11, 2010, 03:10 AM
The_Mongrel is offline
Find More Posts by The_Mongrel
CASA Certified RPAS Instructor
The_Mongrel's Avatar
Australia, NSW, Yass
Joined Dec 2007
I will say one thing...
THOMAS LRS http://www.rcgroups.com/forums/showthread.php?t=905915
The_Mongrel is offline Find More Posts by The_Mongrel
Old Feb 11, 2010, 06:53 AM
barok is offline
Find More Posts by barok
barok's Avatar
Joined Apr 2006
i've heard extending (doubling 2x) the antenna wire on 72mhz rx's will give extra range..
barok is offline Find More Posts by barok
Old Feb 11, 2010, 06:59 AM
wedge98 is offline
Find More Posts by wedge98
wedge98's Avatar
East Hartford, CT
Joined Sep 2006
5 miles...
well you need a UHF signal TX/RX so Thomas, DragonLink, or EZUHF
Now you need a very good setup for Video signal, so two very high gain antenna(15+dBi) plus an omni antenna for launch(2-3Dbi) Diversity setup for all three antennas plus antenna tracker for the high gain. Then you need a low-noise area to fly in to minimize interference.
If all that works out right and your video camera is not noisy you can do this.
Probably around $1000-$2000 in equipment when it's all said and done.
Good luck.
wedge98 is offline Find More Posts by wedge98
Old Feb 11, 2010, 07:24 AM
Joined Sep 2007
We have localy a record of 10km, using 35MHz gear.
Transmitter used was a Futaba T9C with an extended 8m antenna, receiver R149DP PCM with normal antenna.
Old Feb 11, 2010, 11:09 AM
JettPilot is offline
Find More Posts by JettPilot
JettPilot's Avatar
Miami
Joined Apr 2005
10 KM, EASY !!!
www.dragonlinklabs.com
A long range UHF system is the only way to get RELIABLE RC control at long distances. There may be a couple isolated cases of 35 MHZ going far, but it is under ideal and special conditions, and the rare exception. Trying to fly more than 3 KM with a standard RC system is a very good way to crash or loose your plane. Average RC range is 3 KM or 1.5 miles for normal RC systems, and even less for 2.4 GHZ RC systems.
JettPilot is offline Find More Posts by JettPilot
Site Sponsor
Old Feb 11, 2010, 11:24 AM
Neo360 is offline
Find More Posts by Neo360
Joined Jul 2009
Neo360 is offline Find More Posts by Neo360
Old Feb 11, 2010, 12:43 PM
Joined Sep 2007
Originally Posted by JettPilot View Post
...Average RC range is 3 KM or 1.5 miles for normal RC systems, and even less for 2.4 GHZ RC systems.
Like more than 4km for the newest 2.4Ghz systems.
Old Feb 11, 2010, 02:57 PM
scrape is offline
Find More Posts by scrape
Joined Mar 2006
Bigger battery.
scrape is offline Find More Posts by scrape
Old Feb 11, 2010, 03:01 PM
ommadawn is offline
Find More Posts by ommadawn
The Flying Circus
ommadawn's Avatar
Adelaide South Australia
Joined Sep 2007
Or use a chase car
ommadawn is offline Find More Posts by ommadawn
Old Feb 11, 2010, 03:04 PM
Patrick R is offline
Find More Posts by Patrick R
Dos Hermanas (Sevilla)
Joined Dec 2007
Wich one?.
Regards.
Patrick
Patrick R is offline Find More Posts by Patrick R
Old Feb 11, 2010, 04:36 PM
trappy is offline
Find More Posts by trappy
trappy's Avatar
Austria
Joined Feb 2007
http://www.weatronic.com/
I still wouldn't recommend it
trappy is offline Find More Posts by trappy
Old Feb 12, 2010, 01:42 AM
Joined Sep 2007
Originally Posted by Patrick R View Post
Wich one?.
Regards.
Patrick
Have a look on the 2.4GHz range testing thread of Mel Duval.
He already tested a lot of radios featuring over 2.5 miles in air.
Idea DX6i Hack to increase range? StealthWorkx FPV Talk 10 Dec 24, 2009 09:29 PM
Discussion how to increase range on stock micro citabria plane.? raptorddd Micro Ready-to-Fly 1 Dec 04, 2009 10:03 PM
Discussion Mounting antenna on a mast to increase range SugarLandFlyer FPV Talk 14 Oct 11, 2009 12:30 AM
Discussion DX6i increase range Snaydher Radios 6 Aug 25, 2009 09:06 AM
Does flying near wire/metal fencing increase radio range? RPatrick Electric Plane Talk 10 Feb 02, 2002 08:08 PM
