Old Apr 04, 2012, 01:05 PM
Turner2 is offline
Find More Posts by Turner2
Tallahassee, FL
Joined Sep 2009
Originally Posted by JohnathanSwift View Post
Uh, what do I do, now that I've driven off with the hose still attached!
Hope they didn't get your tag number.
Turner2 is offline Find More Posts by Turner2
aerocal is offline
Find More Posts by aerocal
Central California
Joined Dec 2006
Originally Posted by NwRcFlight View Post
Poor example. Gas pumps have an auto cutoff. Even the non-computerized ones.
I'm not entering the fray. I've never had a problem with the charger. But I don't leave it on for more than 2-3 hours.
Your probably right on some level.Many of the fuel pumps I use have no auto shutoff so I guess its a matter of perspective.
aerocal is offline Find More Posts by aerocal
Old Apr 04, 2012, 01:08 PM
Gerry__ is offline
Find More Posts by Gerry__
Bye Bye VP Aug 2010 - Aug 2012
Gerry__'s Avatar
United Kingdom, London
Joined Jan 2005
Originally Posted by jhroof View Post
It's best to use as many methods as you can. When I have a new plane, I choose a conservative flight time and measure the mAh put back in the battery during charge. I then increase the flight times in small increments until I get close the battery capacity. I also use the flight pack voltage telemetry mainly as a safety in case something goes wrong with the battery. It would also be nice to have a mAh telemetry readout as well. You can't have too much redundancy.
Yeah well, chargers on auto use voltage, not time or mAh. Voltage is the best indicator of charge state. I do what you do with flight packs though, except I'm not interested in mAh until I put it back on the charger.
Pretty shocking that some of the regulars in this thread are unable to look after a simple NmHi battery. I read the instructions and they were clear enough. Obviously, if I'm topping up, I'm not going to leave it on charge overnight. Are people really that bad at battery management that they can't adjust the charge length to the amount needed and judge the amount needed by looking at the volts?
Gerry__ is offline Find More Posts by Gerry__
Latest blog entry: Eflite Gee Bee Racing
Old Apr 04, 2012, 01:10 PM
Gerry__ is offline
Gerry__'s Avatar
Joined Jan 2005
Was it not explained in the instruction manual?
aerocal is offline
Central California
Joined Dec 2006
Originally Posted by randall_l View Post
You sue the gas bar for not having an 'inactivity timer' of course. Lol!
I don't mean to stir the pot, but I'm getting some good laughs off this thread lately.
Thanks folks.
Cheers!
Randall
In California you would sue the guy that tightened your lugnuts as well as the wiper blade manufacturer.
Its always good to maintain a healthy sense of humor.
Old Apr 04, 2012, 01:13 PM
JohnathanSwift is offline
Find More Posts by JohnathanSwift
Greenland
Joined Mar 2012
Um, it was vague and ambiguous: it said the gauge would go to full with premium, but didn't say anything about regular.
JohnathanSwift is offline Find More Posts by JohnathanSwift
Reply With Quote  (Disabled)
Old Apr 04, 2012, 01:15 PM
Gerry__ is offline
Gerry__'s Avatar
Joined Jan 2005
You best start a poll about it.
Old Apr 04, 2012, 01:25 PM
Greenland
Joined Mar 2012
Say, that's not an ethnic joke is it?
Old Apr 04, 2012, 01:33 PM
NwRcFlight is offline
Find More Posts by NwRcFlight
EDF Junkie
Pacific Northwest
Joined Oct 2007
Did you put the hose in the tank in the first place? That might not have been in the manual. And 20 gallons of gas just poured on the ground!!!
NwRcFlight is offline Find More Posts by NwRcFlight
Old Apr 04, 2012, 01:36 PM
JC Spohr is offline
Find More Posts by JC Spohr
3D Hack
JC Spohr's Avatar
United States, IL, Glen Carbon
Joined Jul 2010
Originally Posted by grumpy42 View Post
This is a CRUCIAL caveat that is omitted from ANY documentation and apparently only recently has become the official word on the matter. The documentation merely states that the battery should not be left on the charger for more than 12h (and that is ONLY mentioned in the "Getting Started" guide). NOTHING is mentioned about the charge time needing to be proportional to the charge state. Fully charging the NiMH is an imprecise endeavour any way you slice it. You can only know how long to charge the DX8 if you know the TOTAL uptime (as far as I know there is no "system level" timer).
I don't think that it is unreasonable to expect "charge and forget" simplicity in a device that cost ~$400. It is a common concept that has been present in most consumer electronics for quite some time.
I personally consider the charging system to be a design flaw, but it is what it is, and I know how to work around it. However, the charging system will likely continue to befuddle new users since it is counter intuitive and not what users have become accustomed to.
Wow - those other radios are so superior in their design. For Example...
The more expensive and somewhat comparable Futaba 8FG:
From page 22 of the Users Guide -
* Battery charging will not automatically stop. Remove the battery and transmitter from the charger and the charger from the wall socket.
It also states -
1. Connect the "Special" charger to the wall socket (AC outlet).
2. Connect [...]
3. Remove the battery after 15 hours.
There are no mentions on charge time or handling other than suggested cycling.
Page 7 under warnings is interesting in its point that you should NOT rely on the radios warning systems...
For those who want to see the manual, go here > http://manuals.hobbico.com/fut/8fgs-2_4ghz-manual.pdf
The 8FG is about $100 more and has virtually the same instructions and method of battery charging. Note the bold quoted text above.
JC
ps - Go to page 34 of the DX8 manual to learn more about the alleged "missing system timer". Pay attention to the words "RESET" and "Internal".
JC Spohr is offline Find More Posts by JC Spohr
Old Apr 04, 2012, 01:39 PM
Greenland
Joined Mar 2012
It also states -
2. Connect [...]
JC
Yeah, but where do I put the hose?
With gas near $5 a gallon for premium....
Old Apr 04, 2012, 01:42 PM
JC Spohr is offline
3D Hack
JC Spohr's Avatar
Joined Jul 2010
Wrong manual...
And just because you cut the wire... juice will not flow out of it.
Old Apr 04, 2012, 01:43 PM
Victory Pete is offline
Find More Posts by Victory Pete
Rhode Island USA
Joined Aug 2010
It also states -
2. Connect [...]
JC
2 wrongs dont make a right.
VP
Victory Pete is offline Find More Posts by Victory Pete
Old Apr 04, 2012, 01:45 PM
grumpy42 is offline
Find More Posts by grumpy42
grumpy42's Avatar
Canada
Joined Aug 2004
This is just not the case - especially with NiMH. Voltage will only tell you if the battery is depleted or fully charged (or "mostly" depleted/charged). Voltage will not tell you anything about the "intermediate" charge state. NiMH have a fairly flat discharge curve and will remain at their nominal voltage for approximately 80% of their use.
Without knowing the "charge state" of the battery coupled with a charger that does not terminate is BAD. This is why the current "best practice" is to perform a 10h charge when the battery is depleted.
Actually, most NiMH chargers will use peak detection as a means of charge termination.
grumpy42 is offline Find More Posts by grumpy42
Greenland
Joined Mar 2012
Wrong manual...
Actually, I think the guy running out of the door, screaming, said his name was Manuel.
I figured I must have taken a wrong turn into Florida cuz he keeps saying, "Sunny Beaches! Sunny Beaches!"
Question Receivers that work with Spektrum Radios that are not made by Spektrum BD Flyer Radios 29 Sep 26, 2010 04:09 AM
Discussion Spektrum AR6100E or Spektrum AR6100? LaurenceGough Off-road Cars 23 Aug 06, 2009 05:33 AM
For Sale Parkzone 5ch DX10 w/Receiver ch54 CarlHill Aircraft - General - Radio Equipment (FS/W) 7 Jul 10, 2009 12:07 PM
Discussion Can I use a Spektrum Air RX with a Spektrum Surface TX? Bigmaxy Radios 1 Jan 19, 2008 07:57 PM
Sold GeForce 8400Gs PCIx DX10 video card GFBurke Non R/C Items (FS/W) 6 Sep 05, 2007 10:43 PM
