Old Mar 10, 2012, 06:15 PM
3d Marky is offline
Find More Posts by 3d Marky
United Kingdom, Rochford
Joined Aug 2007
Seeing you video Pavcon has restored my faith in the DX8 so I'm going to chance it in one of these...
LARGE FLYING RC PAPER AIRPLANE (3 min 13 sec)
3d Marky is offline Find More Posts by 3d Marky
Old Mar 10, 2012, 09:35 PM
pavcon is offline
Find More Posts by pavcon
Κύπρος, Λευκωσία, Πέρα Χωριό
Joined Jan 2010
lol
pavcon is offline Find More Posts by pavcon
Old Mar 10, 2012, 10:57 PM
Lilienthal is offline
Find More Posts by Lilienthal
Lilienthal's Avatar
United States, CO
Joined Nov 2010
Cool!
Lilienthal is offline Find More Posts by Lilienthal
Old Mar 12, 2012, 11:04 AM
Franco2fly is offline
Find More Posts by Franco2fly
AMA 84248 since 1964
Joined Jan 2011
I was able to Maiden my RussiaStik (formerly e-flight 25e UglyStik, now modified for trike gear and in Russian colors, Turnigy G-32 motor turning a 14x12)
Went very well, Telemetry reporting it hit 120Mph, but I'm doubtful, still tinkering with STi Application, can't get it to stop reporting voltages (only want warning when it drops below setting) Fowler flaps made landings silky smooth.
KKKKFL
Franco2fly is offline Find More Posts by Franco2fly
Old Mar 12, 2012, 11:14 AM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Originally Posted by Franco2fly View Post
... can't get it to stop reporting voltages (only want warning when it drops below setting) ... KKKKFL
Don't have it in front so I could be wrong but the first selection of SPEAK or Alarm is the one you want and disable the other.
The second is just read out that you set for every what ever time delay you set and you can select what to annouce. disable voltage in that setting but leave the first set to VOICE or SPEAK instead or alarm.
freechip is offline Find More Posts by freechip
Old Mar 12, 2012, 11:49 AM
pavcon is offline
Joined Jan 2010
maybe 120km/h
Old Mar 12, 2012, 12:11 PM
Joined Jan 2011
Its not set for Kilometers....hahaha and from what I've observed with the sensors so far, they're not absolute. Atltude also jumps a bit, I was getting read outs in 15 second intervals yesterday and it seemed I went from flying at 100 feet to 150 feet in a nanosecond. Temp is the only sensor that seems to read out in a linear fashion. The 3 axis G force is kinda neat, but you cannot watch it and fly at the same time, and there's no "Read Out" option, its just nice to have info at this time anyway.
There was an iPhone software update that I had to initiate this morning and it will be interesting to see if I need to re-bind everything since the phone re-booted, and when I did a re-boot yesterday, everything needed to be re-bound.
KKKKFL
Old Mar 12, 2012, 04:55 PM
pavcon is offline
Joined Jan 2010
my airspeed sensor is spot on btw.. confirmed it with a police radar gun pro stuff..
(oh btw for the airspeed sensor there are specific instructions on where to be placed.. has to be clear form the prop wash.. ) m
mine is on my MB339 so installation was very easy..
Old Mar 12, 2012, 05:22 PM
Joined Jan 2011
My pitot tube is just outside the prop arc, about a third the way out the wing to the outside of the first servo protrusion on the bottom of the wing. Its mounted to the servo plate. I could move it outboard some more just for test purposes. Need more flight time. I'm still working out minor details like adding a side duct to allow more air across the ESC heat shrink fins. Just out in the drive with the hatches all buttoned down the temp reaches about 110 degrees when I statically run the motor up to full 800 watts.
In the air I'm expecting it to run a little cooler, but its something I will watch or should I say "Listen for".
KKKKFL
Old Mar 12, 2012, 05:52 PM
AndyKunz is online now
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
The more of it you can have out in front of the model, the better the pitot tube will work. The instructions mention the bare minimum distance - farther out front is better.
Andy
AndyKunz is online now Find More Posts by AndyKunz
Site Sponsor
Old Mar 12, 2012, 06:30 PM
struggleforlife is offline
Find More Posts by struggleforlife
struggleforlife's Avatar
The Netherlands, LI, Gennep
Joined Feb 2011
Guys, something weird with my transmitter/model. Maybe you can tell me whats happening.
I have a plane with flaps. Using AR600.
One flap is on the gear channel (under the flap switch), the other is on aux1. It's mixed 100% with gear channel.
Works like a charm.
However, the other day I set up my model again (all wires are marked, so its highly unlikely that I switched wires), suddenly flap go up instead of down.
So I changed flap switch from 50 and 100 to -50 and -100. And then it was ok again.
I've had this before, but figured I had done something wrong, so didn't pay attention to it.
Could it be something in the transmitter, am I doing something wrong, or am I going crazy?
Regards,
Dave
struggleforlife is offline Find More Posts by struggleforlife
Old Mar 12, 2012, 06:41 PM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Why not use the aileron 2 flap wing type and avoid using a mix?
Then the monitor would also tell you where to plug each servo.
Old Mar 13, 2012, 01:50 PM
jhroof is offline
Find More Posts by jhroof
Orlando, Fl
Sales must be getting slow...now they are "giving away" a 6210 and 6115e with a new DX8.
jhroof is offline Find More Posts by jhroof
Old Mar 13, 2012, 01:53 PM
JC Spohr is offline
Find More Posts by JC Spohr
3D Hack
JC Spohr's Avatar
United States, IL, Glen Carbon
Joined Jul 2010
That offer is only if you buy the full package AND directly from Horizon Hobby...
JC
JC Spohr is offline Find More Posts by JC Spohr
Old Mar 13, 2012, 02:21 PM
flitelab is offline
Find More Posts by flitelab
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
JC
Not only directly from HH at all...
Right now, if you buy a Spektrum DX8 from a participating retailer, you'll get an AR6210 full-range receiver and an AR6115e park flyer receiver FREE!
flitelab is offline Find More Posts by flitelab
Site Sponsor
Question Receivers that work with Spektrum Radios that are not made by Spektrum BD Flyer Radios 29 Sep 26, 2010 04:09 AM
Discussion Spektrum AR6100E or Spektrum AR6100? LaurenceGough Off-road Cars 23 Aug 06, 2009 05:33 AM
For Sale Parkzone 5ch DX10 w/Receiver ch54 CarlHill Aircraft - General - Radio Equipment (FS/W) 7 Jul 10, 2009 12:07 PM
Discussion Can I use a Spektrum Air RX with a Spektrum Surface TX? Bigmaxy Radios 1 Jan 19, 2008 07:57 PM
Sold GeForce 8400Gs PCIx DX10 video card GFBurke Non R/C Items (FS/W) 6 Sep 05, 2007 10:43 PM
