Old Feb 05, 2012, 06:38 AM
Gerry__ is offline
Find More Posts by Gerry__
Bye Bye VP Aug 2010 - Aug 2012
Gerry__'s Avatar
United Kingdom, London
Joined Jan 2005
Originally Posted by grumpy42 View Post
C/10 is defined as a SLOW charge NOT a trickle charge. A true trickle charge is much lower - typically in the range of c/50.
Furthermore, the DX8 may use low self-discharge NiMHs, and LSD batteries are much more susceptible to overcharging than regular NiMHs.
LSD batteries don't need to be put on trickle charge, that's the point of them!
Gerry__ is offline Find More Posts by Gerry__
Latest blog entry: Foamie Resurrection
Old Feb 05, 2012, 07:11 AM
A Rdnek is online now
Find More Posts by A Rdnek
Bruno, GOOD DOG
A Rdnek's Avatar
United States, IA, Grinnell
Joined Aug 2007
Constantly performing an overnight charge on a partially depleted pack WILL overcharge your NiMH batteries (the manual even warns against leaving the charger plugged in too long). If you like to keep your TX pack "topped off" you are better off investing in the LIPO since the charge will terminate automatically once the pack is charged.
Alternatively, you can remove the NiMH battery pack and use a "proper" peak detection charger.
What is the maximum rate you would run this "proper" peak detection charger, I have a Duratrax "ICE", a Triton "GREEN DOT" and a Thunder AC 6, all of which are capable of this charge job. I have been using the Duratrax ICE at 500 mil, will that damage the pack, or can I go even higher, would a 2000 mil charge rate be too much?
Ron
A Rdnek is online now Find More Posts by A Rdnek
Old Feb 05, 2012, 07:15 AM
Victory Pete is offline
Find More Posts by Victory Pete
Rhode Island USA
Joined Aug 2010
Ron
I charge my DX8 NiMH pack outside the Tx at .5 amp, which is .25C. It takes about 4 hours.
VP
Victory Pete is offline Find More Posts by Victory Pete
Reply With Quote  (Disabled)
Old Feb 05, 2012, 08:28 AM
grumpy42 is offline
Find More Posts by grumpy42
grumpy42's Avatar
Canada
Joined Aug 2004
I am an impatient bloke, so I tend charge my other TX NiMHs at 1C (I haven't charged the DX8 pack outside the TX). Usually C/2-1C is required for proper peak detection (depends on charger and number of cells). If you select too high of a rate, the temperature gets too high towards the end of the charge (does your charger have a temp probe?). Also, old packs may "false peak", so just lower the charge rate until you stop getting "false peaks".
I never said that LSD batteries should be trickle charged
I just said that DX8 MAY use LSD batteries, and if it does, they are much more susceptible to overcharging.
grumpy42 is offline Find More Posts by grumpy42
Old Feb 05, 2012, 08:31 AM
AndyKunz is offline
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
The stock cells are not LSD.
Andy
AndyKunz is offline Find More Posts by AndyKunz
Site Sponsor
Old Feb 05, 2012, 08:45 AM
Rhode Island USA
Joined Aug 2010
At .25C, 500ma (.5 A) battery temperature at the end gets around 100 degrees F.
VP
Old Feb 05, 2012, 09:12 AM
Gerry__ is offline
Gerry__'s Avatar
Joined Jan 2005
What led you to believe they MAY use LSD cells? Merely opening battery hatch and looking at them would have confirmed to you that they are NOT LSD.
Old Feb 05, 2012, 09:28 AM
grumpy42 is offline
grumpy42's Avatar
Canada
Joined Aug 2004
I don't understand your wacky units
NiMH should be warm after charging. Too hot to handle is bad. Actually, I think that NiMH can get up to 60 degree C (140F) without incurring damage.
So far, the batteries seem to exhibit decent charge retention. Also, since the DX8 is relatively new and LSD batteries have been available for a while now, it seemed to make sense that Spektrum would include LSD batteries.
Hmmmm.... Really? How?
It is a sealed heat shrink pack. You cannot see the actual cells (unless you cut the pack open). Even the cells may not directly indicate whether they are LSD cells or not. I have LSD NiMH from a couple different manufacturers. One has no indication that they are LSD, while the others only indicate that they are "ready to use".
Old Feb 05, 2012, 09:39 AM
Rhode Island USA
Joined Aug 2010
The fact they last so long.
VP
Old Feb 05, 2012, 09:41 AM
Gerry__ is offline
Gerry__'s Avatar
Joined Jan 2005
If the pack was LSD it would say so. Maybe your LDS packs aren't LSD. All the good ones actually say they are.
Rhode Island USA
Joined Aug 2010
As usual, great common sense and logic.
Cheers and tables!
VP
Old Feb 05, 2012, 09:43 AM
Rhode Island USA
Joined Aug 2010
Nope! I have Duracell "Precharged" and it says nothing about "LSD".
VP
Old Feb 05, 2012, 10:05 AM
Gerry__ is offline
Gerry__'s Avatar
Joined Jan 2005
VP
Do you really think they would be pre-charged if they weren't LSD?
Old Feb 05, 2012, 10:20 AM
grumpy42 is offline
grumpy42's Avatar
Canada
Joined Aug 2004
Sorry, but this is not necessarily the case.
My eneloops say "ready to use"
My Panasonics have no indication on the cells that they are LSD, but the packaging said that they are precharged. Also, if you look up the part number, they are listed as "super low discharge"
Old Feb 05, 2012, 10:32 AM
FlyHighSelllow is offline
Find More Posts by FlyHighSelllow
Champagne Supernova
FlyHighSelllow's Avatar
United States, FL, Orlando
Joined Jul 2010
Had a weird event at the field today. Turned on radio and no display, blank like it wasn't powered up but there was a little vibrate going on, you could feel and hear it but not as loud and potent as the activity alarm.
I checked all my switches like flaps etc. all in correct position. I turned it off and tried again. Same thing. I cycled power like 5-6 times and the display came up and no vibration, all was good from that point. Batt is fully charged.
Anybody seen this yet ?
FlyHighSelllow is offline Find More Posts by FlyHighSelllow
Question Receivers that work with Spektrum Radios that are not made by Spektrum BD Flyer Radios 29 Sep 26, 2010 04:09 AM
Discussion Spektrum AR6100E or Spektrum AR6100? LaurenceGough Off-road Cars 23 Aug 06, 2009 05:33 AM
For Sale Parkzone 5ch DX10 w/Receiver ch54 CarlHill Aircraft - General - Radio Equipment (FS/W) 7 Jul 10, 2009 12:07 PM
Discussion Can I use a Spektrum Air RX with a Spektrum Surface TX? Bigmaxy Radios 1 Jan 19, 2008 07:57 PM
Sold GeForce 8400Gs PCIx DX10 video card GFBurke Non R/C Items (FS/W) 6 Sep 05, 2007 10:43 PM
