Central California
Joined Dec 2006
Pete
"Idleup" is what is also known as FM-1 or FM-2(Flightmode 1 or 2).Controlled by guess what? FMode. You go to FMode menu and assign a switch and then that switch controls mode changes.Then you go to Throttle Curve and Pitch Curve menus to set what your throttle and pitch will do in the different modes.You may also want to assign other functions such as dual rate,expo,gyro gain or others to the Fmode switch. For the majority of Gyros HH mode will be values above(plus side) of center and Rate mode will be values below(minus side) of center.That is if the gyro has the gain controlled by a radio channel.Most but not all do.Read the documentation for your specific gyro. No explanation would be complete without knowing how the trims work."Common" will carry the same trim across all modes(Normal,FM-1&FM-2). Set to "FMode" the trims will be unique for each mode. It might help if we knew what specifc heli you are flying and what equipment it is equipped with.The combinations are almost endless and the differences between them can be huge.In the future when you ask questions its important to give all equipment details to get the correct advise. |
Joined Jan 2006
Gyro is simply under "Gyro". Most guys I know use the up (switch) position for HH, down for rate. You wil have to play around with the settings, as different manufacturers use different values. On my eflite Blade 450, HH is positive 53. On my Trex 250 with a JR gyro, HH is positive 16. On my Gaui 425, with Futaba 401 gyro, HH is Negative 66. |
United Kingdom, England, Lincs
Joined Mar 2011
Searching the pdf manual finds several hits for stunt 1. It appears to be one of the helicopter flight modes - I don't do helicopters (yet) so cant add any more to help -- Allan |
Rhode Island USA
Joined Aug 2010
VP |
Rhode Island USA
Joined Aug 2010
VP |
Rhode Island USA
Joined Aug 2010
I am confused by this from the manual:
Page 33 "Adjusting the Rate Values Rotate the roller to select the desired gain value then press. Select the gain value. Any time a T displays, the gyro is in tail lock (Heading Lock). If an N displays, the gyro is in normal mode." I dont see an N or a T displayed VP |
That's a manual error. No T or N is displayed - instead they are + and - (as noted above by aerocal).
Your best bet might be to ask for an SPM file on one of the Heli areas. Tell them what you're trying to do and see how they help. "Idle Up" (typically all modes other than Normal) set your RPM to a fixed value (Throttle channle output) and the throttle stick changes to a Pitch stick. The motor will run at a fixed RPM (especially if you have Governor enabled in your model), and the throttle stick will only control Pitch. Refer to the setup manual for your desired heli. Andy |
Joined Jan 2006
If you get a Blade 450, you can download the setup from the Spektrum site. All the pitch and throttle settings already done for you, and includes an intermediate and advanced setup. |
If you want to benifit from the features of your radio I suggest you start by downloading the SPM files that are offered for your specific heli. They are offered in advance and intermediate B450 (blade 450).
As for learning how and when to use specific heli features/programming you should visit local club to get hands info. Flight sim is also great place to learn since instead of hitting your wallet you can hit the reset button and get back in the air. |
Latest blog entry: Get Help by posting your SPM File
| Thread Tools | |
| Question Receivers that work with Spektrum Radios that are not made by Spektrum | BD Flyer | Radios | 29 | Sep 26, 2010 04:09 AM |
| Discussion Spektrum AR6100E or Spektrum AR6100? | LaurenceGough | Off-road Cars | 23 | Aug 06, 2009 05:33 AM |
| For Sale Parkzone 5ch DX10 w/Receiver ch54 | CarlHill | Aircraft - General - Radio Equipment (FS/W) | 7 | Jul 10, 2009 12:07 PM |
| Discussion Can I use a Spektrum Air RX with a Spektrum Surface TX? | Bigmaxy | Radios | 1 | Jan 19, 2008 07:57 PM |
| Sold GeForce 8400Gs PCIx DX10 video card | GFBurke | Non R/C Items (FS/W) | 6 | Sep 05, 2007 10:43 PM |
