Old Nov 17, 2011, 07:31 AM
egicar is offline
Find More Posts by egicar
egicar's Avatar
Nuvolera (Italy)
Joined Jul 2007
Originally Posted by freechip View Post
Something like this you mean.
When you have been here for quite some time you come to know that people just rather ask here then have to read manuals.
There is a thread here just on calibrating.
I know that therad.
I agree on the bad habit of not reading the manuals and ask on the forum.
But I am convinced that the manufacturer sholuld update the product manual, if the product is changed (even if no one will read the manual ).
egicar is offline Find More Posts by egicar
Old Nov 17, 2011, 08:11 AM
pavcon is offline
Find More Posts by pavcon
Κύπρος, Λευκωσία, Πέρα Χωριό
Joined Jan 2010
just tried the telemetry.. working JUUUST fine... 128km/h on the test flight
pavcon is offline Find More Posts by pavcon
Old Nov 17, 2011, 08:25 AM
AndyKunz is online now
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
Originally Posted by pavcon View Post
or if you combine 2 of the existing receivers
Considering the way you add sensors to the tm1000 with the xbus im pretty convinced that spektrum has already achieved this but havent announced it yet.
Maybe andy can enlighten us leak it leak it leak it
It's called XPlus, it's already described in the DX10t stuff online. You get 8 additional fully-proportional channels. There is a serial connection between the base receiver (AR10000) and the XPlus module (basically it looks like an AR10000 without the antennas).
The XPlus channels have all the same controls as the normal channels - mixing, input assignments, speed controls, travel, balancing, etc. They're perfect for scale modelers for operating retracts, opening canopies, bomb drops, etc.
Andy
AndyKunz is online now Find More Posts by AndyKunz
Site Sponsor
Old Nov 17, 2011, 08:28 AM
FlyHighSelllow is offline
Find More Posts by FlyHighSelllow
Champagne Supernova
FlyHighSelllow's Avatar
United States, FL, Orlando
Joined Jul 2010
• Users are now able to calibrate the knob and both stick in both axes. This is done by selecting NEXT several times from the System Setup menu. Move the sticks in a “+” format, NOT in an X or O. It is important not to push the sticks to the corners.
Those aren't instructions. There a quick brief of the new feature and the thread on calibrating is lacking a complete how to. The info is there for the most part but its all hacked up.
I finally updated and calibrated mine last night. I had to wade thru a you tube video, a couple threads and then several posts before I got all the info I needed to be successful.
Well I thought was successfule anyways I went back to Andys thread this morning and saw the post about a stick not being centered and the guy had to push it left to get it to change to OK so he could roll over to Save. I had to do that too with my right stick. I pushed it over to the left, got OK and barely held pressure just enuf to keep save there, rolled to Save and saved it. I se Andys reply to that post and see I was supposed to get Save to appear, roll to Save then center the stick and click Save.
I recalibrated mine this am. Oh also this am is when I found out what knob they are talking about and what I was supposed to do with that.
I had no idea I was supposed to calibrate Aux 3 knob or how !!!!
Some step by step instructions, pdf. would be in order and then you could print them out and add them to your manual.
FlyHighSelllow is offline Find More Posts by FlyHighSelllow
Old Nov 17, 2011, 08:30 AM
AndyKunz's Avatar
Illinois
Joined Sep 2001
We're working on that.
Did you watch the John Redman video? That's about as step-by-step as it comes.
Andy
Site Sponsor
Old Nov 17, 2011, 08:57 AM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
I understand what you are saying. BUT
... Oh also this am is when I found out what knob they are talking about and what I was supposed to do with that.
I did not think there was more then one knob on the radio. AUX3 has nothing to do with the knob since this is only default channel assigned to it.
But I get what you are saying. Once they create this new memo/instructions we will be providing it to almost every body else who just want to ask here instead of reading anyways. RIGHT?
freechip is offline Find More Posts by freechip
Old Nov 17, 2011, 09:23 AM
Champagne Supernova
Joined Jul 2010
I understand what you are saying. BUT I did not think there was more then one knob on the radio. AUX3 has nothing to do with the knob since this is only default channel assigned to it.
Well my knob is labeled Aux 3 so thats the knob I calibrated. Maybe others knobs are labeled differently ?
I could probably do a written step by step instructions by memory but I need to get back to work .
Old Nov 17, 2011, 09:25 AM
Champagne Supernova
Joined Jul 2010
Andy
Ya know that might have been the video I watched. It was a pretty good one but he has you go into mode 4 then shutdown, startup then switch back to Mode 2 and start up and it would go directly to calibrate . My radio wouldnt do that. I just went to system setings, next, next, next etc and calibrate.
Old Nov 17, 2011, 09:57 AM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Thats the old way of accessing the calibration menu, now its down threw menu directly.
Old Nov 17, 2011, 10:01 AM
AndyKunz's Avatar
Illinois
Joined Sep 2001
That was not it. The one I'm talking about is probably on Horizon's YouTube page, and it documents the 2.03 update.
Andy
Site Sponsor
Old Nov 17, 2011, 10:18 AM
summitbill is offline
Find More Posts by summitbill
Slipping the surly bonds...
summitbill's Avatar
Elizabethton, TN
Joined Jan 2003
Hey guys,
Anyone have a similar problem with the Turnigy 4000 mah DX8 battery? I purchased two of them, and they both had a problem once fully charged. From the factory, they were displaying 7.7v, and both worked fine in the DX8. Then, I plugged in the charger and let them charge over night. In the morning, when I turned on the xmitter, the screen would just flash quickly and then go black. Both batteries did the exact same thing. I soldered on a pigtail to each so that I could check the voltage and charge/discharge thru my normal lipo charger. The voltage was 8.37 on both, so the wall charger and DX8 did shut off properly at 8.4 volts. However, I had to discharge both batteries down to 8.1 volts before they would work in the DX8. Haven't heard of anyone having a problem with the DX8 working with this lipo at full charge, but I have two batteries and at 8.4, neither work. Anyone seen this?
Bill
summitbill is offline Find More Posts by summitbill
Old Nov 17, 2011, 10:19 AM
summitbill's Avatar
Elizabethton, TN
Joined Jan 2003
Hey guys,
Bill
Old Nov 17, 2011, 10:43 AM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
I have the stock lipo and at 8.4 my DX8 does not display this issue. Would be interesting for you to try a stock lipo if you know where to barrow one and test. Could possibly something wrong with the TX.
Old Nov 17, 2011, 10:47 AM
mikeruth is offline
Find More Posts by mikeruth
The "Foaminator"
mikeruth's Avatar
Joined Mar 2007
A lipo is a lipo is a lipo, 8.4 Volts is 8.4 Volts!!!
For what's its worth double check that voltage on two or more meters.
My 2 cents.
MIke R
mikeruth is offline Find More Posts by mikeruth
Old Nov 17, 2011, 11:04 AM
3DeltaFly is offline
Find More Posts by 3DeltaFly
Byron C
3DeltaFly's Avatar
United States, TN, Knoxville
Joined Apr 2011
Originally Posted by summitbill View Post
Hey guys,
Bill
That is indeed a weird problem Bill. I wonder.., you did set the DX8 up in it's battery type menu when changing from NiMH to LiPo I assume? Others have reported success with the Turnigy packs, and 8.37 VDC is well within the full charge specs. for 2S packs.
It will be a week or so yet before my LiPo packs arrive. Then I'll be able to report back, etc.
-Byron
3DeltaFly is offline Find More Posts by 3DeltaFly
Question Receivers that work with Spektrum Radios that are not made by Spektrum BD Flyer Radios 29 Sep 26, 2010 04:09 AM
Discussion Spektrum AR6100E or Spektrum AR6100? LaurenceGough Off-road Cars 23 Aug 06, 2009 05:33 AM
For Sale Parkzone 5ch DX10 w/Receiver ch54 CarlHill Aircraft - General - Radio Equipment (FS/W) 7 Jul 10, 2009 12:07 PM
Discussion Can I use a Spektrum Air RX with a Spektrum Surface TX? Bigmaxy Radios 1 Jan 19, 2008 07:57 PM
Sold GeForce 8400Gs PCIx DX10 video card GFBurke Non R/C Items (FS/W) 6 Sep 05, 2007 10:43 PM
