Old Nov 12, 2011, 10:33 AM
tachy kard is offline
Find More Posts by tachy kard
Deutschland, Bayern, München
Joined Jan 2009
Today I got some interesting data from the field after flying my new biplane. For the firt time I used a 8V system an BEC with an additional 2s buffering battery. DX8 telemetry reported a min rx voltage of 6.1V. Is this really possible or just some kind of data error?
tachy kard is offline Find More Posts by tachy kard
Old Nov 12, 2011, 11:16 AM
Mukenukem is offline
Find More Posts by Mukenukem
Vienna, Austria
Joined Oct 2010
It is useful to reset the values before you start your model, and read the min/max values before you disconnect the battery.
Of course the RX voltage can drop to 6.1V. I had drops on my 550 Rex down to 3.4V. After changing the BEC and using green caps for buffering, the voltage stays above 5.8V (6V BEC)
Telemetry also is a curse. You see things you could not notice before
Mukenukem is offline Find More Posts by Mukenukem
Old Nov 12, 2011, 11:38 AM
FlyHighSelllow is offline
Find More Posts by FlyHighSelllow
Champagne Supernova
FlyHighSelllow's Avatar
United States, FL, Orlando
Joined Jul 2010
Originally Posted by Gerry__ View Post
Actually, thinking about it, as long as the ESC is calibrated within the available range of the throttle, it should be a problem, should it?
Not really but every once in a while it will arm with series of beeps tones indicating throttle is in up position when in fact it is in down position just not all the way just a hair up like your seeing. I reach over and force it down to bottom out.
FlyHighSelllow is offline Find More Posts by FlyHighSelllow
Old Nov 12, 2011, 02:33 PM
AndyKunz is offline
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
In other words: short calibrate. It will reduce the resolution, but not by anything worth worrying about.
No, follow the instructions I posted in this thread: http://www.rcgroups.com/forums/showthread.php?t=1476084
DO NOT PUT THE STICK IN THE CORNERS. That is what causes you to limit the range at the center. It's a mechanical thing that over-rotates the pot when you push into the corner.
Andy
AndyKunz is offline Find More Posts by AndyKunz
Site Sponsor
Old Nov 12, 2011, 02:38 PM
AndyKunz is offline
AndyKunz's Avatar
Illinois
Joined Sep 2001
When we first started using it, it scared me seeing just how close I was skating to the "edge of the world" on some of my planes. I ended up spending a bunch to use better ESCs and servos, and then cleaned up my linkages.
Things I knew all along, but had gotten complacent with because you could on the old analog radios.
Andy
Site Sponsor
Old Nov 12, 2011, 02:41 PM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Agreed, it's how I discovered my E-flite's 30A Pro only had .7A (700mah) BECs in planes then had more then 4 servos. Could of been bad.
Spektrum telemetry increased my collection of external bec equiped planes.
freechip is offline Find More Posts by freechip
Old Nov 12, 2011, 03:20 PM
stgdz is offline
Find More Posts by stgdz
Volts>amps
stgdz's Avatar
United States, MN, Buffalo
Joined Jul 2011
So my altimeter sensor doesn't work or the software on the dx8 for the amps, speed and altitude don't work.
1. It doesn't display the altitude at all
2. Warnings go off but the altitude is off by a factor of 10! It doesn't display the altitude I am just guessing as I changed the height twice.
stgdz is offline Find More Posts by stgdz
Old Nov 12, 2011, 04:05 PM
AndyKunz is offline
AndyKunz's Avatar
Illinois
Joined Sep 2001
You need to update your transmitter. The off-by-10 issue was noted in the PDF. Or you can just set the alarm 10X what you really want it to be.
You also need to set Display to On on the altitude setup screen.
Andy
Site Sponsor
Old Nov 12, 2011, 06:27 PM
stgdz is offline
Volts>amps
stgdz's Avatar
Joined Jul 2011
Andy
2.03beta?
I have 2.01 installed now and I have the screen enabled.
Old Nov 12, 2011, 06:43 PM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Originally Posted by stgdz View Post
2.03beta?
2.03b
Software Corrections
• Telemetry - Changed scaling for telemetry alarms Altitude & Airspeed. Fixed
‘hidden status’ screens when using models created in older versions.
Maybe this is what you are experiencing.
Old Nov 12, 2011, 07:08 PM
stgdz is offline
Volts>amps
stgdz's Avatar
Joined Jul 2011
Yeah that's what I thought but ibdidnt see the specific -10 mentioned in the PDF. There was a scaling in there.
Its beta also so I am uncertain about it
Old Nov 12, 2011, 07:35 PM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Well it's been out for some time now so other then whats already been discussed which does not affect everybody it's just as good as what you are currently using.
Remember 2.01 has bugs also.
Flap/Elevator Smoothness – Elevator compensation travel was not smooth
when there was significant trim on the elevator channel.
Flap Overdrive – Initial flap movement could sometimes cause flaps to jump to
one extreme of travel before moving to correct setting.
Translations – Improve/Correct translation of some terms for German, Spanish
and Italian modes, particularly on the Timer and Telemetry screens.
2.03 has an issue with certain airplanes with Elevon wing types. Some mixing issue that does affect the 27Q Stryker.
Other then that I would say it pretty good to use unless you have this specific plane but even with this plane I believe there is a work around by inhibiting FLAP system.
Old Nov 12, 2011, 07:41 PM
pavcon is offline
Find More Posts by pavcon
Κύπρος, Λευκωσία, Πέρα Χωριό
Joined Jan 2010
I got the 2.03b since day 1 and has been working flawlessly
also binded the telemetry and the airspeed sensor.
I got it mounted on my flyfly MB339 and my retracts arrived inland yesterday. gonna have them on monday and test it the same day weather permitting, as winter started to kick in and it has been raining all day.
pavcon is offline Find More Posts by pavcon
Old Nov 13, 2011, 09:34 AM
Thomas B is offline
Find More Posts by Thomas B
Electric Coolhunter
Thomas B's Avatar
United States, TX, Fort Worth
Joined Jun 2000
Picked up the Spektrum STI dongle at the LHS yesterday and downloaded the Iphone app this AM
Would get out and try it today, except for the wind gusts to 30mph here in north Texas today.....yuck.
Thomas B is offline Find More Posts by Thomas B
Latest blog entry: 2014 events and travel
Old Nov 15, 2011, 01:40 PM
vascoboy is offline
Find More Posts by vascoboy
United States, CA, SF
Joined Apr 2011
sent in my Tx today...known problems:
my aileron channel is off center by 30%+ after trims all set to -0-
my rudder channel is twitchy, especially when i up/down throttle...
things appear to have gotten worse after i downloaded air 2.1(?) update. I will report back when i get me Tx back...
vascoboy is offline Find More Posts by vascoboy
Question Receivers that work with Spektrum Radios that are not made by Spektrum BD Flyer Radios 29 Sep 26, 2010 04:09 AM
Discussion Spektrum AR6100E or Spektrum AR6100? LaurenceGough Off-road Cars 23 Aug 06, 2009 05:33 AM
For Sale Parkzone 5ch DX10 w/Receiver ch54 CarlHill Aircraft - General - Radio Equipment (FS/W) 7 Jul 10, 2009 12:07 PM
Discussion Can I use a Spektrum Air RX with a Spektrum Surface TX? Bigmaxy Radios 1 Jan 19, 2008 07:57 PM
Sold GeForce 8400Gs PCIx DX10 video card GFBurke Non R/C Items (FS/W) 6 Sep 05, 2007 10:43 PM
