Old Nov 11, 2011, 08:58 PM
teryn1 is offline
Find More Posts by teryn1
teryn1's Avatar
Tucson, AZ
Joined Aug 2004
From your earlier comment, you basically said the hardware (processor) doesn;t support it. can the processor support it or not?
Originally Posted by AndyKunz View Post
Not what I said at all. It's just an expensive (my time) feature. I won't say "Never" but I will say, "Don't hold your breath." I'm sure the decision-makers will be influenced by how well the feature is received by the DX10t owners.
Andy
teryn1 is offline Find More Posts by teryn1
Old Nov 11, 2011, 09:46 PM
Dave H. is online now
Find More Posts by Dave H.
Joined Feb 2008
He said the 10t had a faster processor. That doesn't make the the slower processor hopeless, but it may take much more work to get it running on a slower processor without losing anything.
Dave H. is online now Find More Posts by Dave H.
Old Nov 11, 2011, 10:57 PM
flyboy50 is offline
Find More Posts by flyboy50
3DHS RULEZ!!!
flyboy50's Avatar
United States, VA, Wythe
Joined Jan 2011
has anyone tryed this?http://www.commonsenserc.com/product...oducts_id=2769
flyboy50 is offline Find More Posts by flyboy50
Old Nov 12, 2011, 03:08 AM
tachy kard is offline
Find More Posts by tachy kard
Deutschland, Bayern, München
Joined Jan 2009
I would rather buy the original one from HH or the cheap one from Hobbyking.
tachy kard is offline Find More Posts by tachy kard
Old Nov 12, 2011, 05:02 AM
Gerry__ is offline
Find More Posts by Gerry__
Bye Bye VP Aug 2010 - Aug 2012
Gerry__'s Avatar
United Kingdom, London
Joined Jan 2005
Throttle not hitting 100%
My throttle isn't hitting 100% UNLESS I push the stick a bit harder! I've tried changing modes and recalibrating, but the problem is still there.
Anyone else had this?
Gerry__ is offline Find More Posts by Gerry__
Latest blog entry: Eflte Gee Bee Racing
Old Nov 12, 2011, 05:09 AM
Victory Pete is offline
Find More Posts by Victory Pete
Rhode Island USA
Joined Aug 2010
Yes.
VP
Victory Pete is offline Find More Posts by Victory Pete
Reply With Quote  (Disabled)
Old Nov 12, 2011, 05:47 AM
FlyHighSelllow is offline
Find More Posts by FlyHighSelllow
Champagne Supernova
FlyHighSelllow's Avatar
United States, FL, Orlando
Joined Jul 2010
Yep Still got it and I hate it. It does not bottom out to zero. errr
FlyHighSelllow is offline Find More Posts by FlyHighSelllow
Old Nov 12, 2011, 06:02 AM
Gerry__ is offline
Gerry__'s Avatar
Joined Jan 2005
Actually, thinking about it, as long as the ESC is calibrated within the available range of the throttle, it should be a problem, should it?
Old Nov 12, 2011, 06:14 AM
Rhode Island USA
Joined Aug 2010
There is a simple procedure to correct this. Do a calibration again and when you are doing the throttle stick make sure the stick does not get pushed hard to the extents. You can try to do this by feel or you can shim it some how, I think I did it by making an effort not to even let it just touch the extents. It did work though. I think Freechip came up with this. Good luck.
VP
Old Nov 12, 2011, 06:29 AM
Gerry__ is offline
Gerry__'s Avatar
Joined Jan 2005
VP
In other words: short calibrate. It will reduce the resolution, but not by anything worth worrying about.
Old Nov 12, 2011, 06:49 AM
zmonster97 is offline
Find More Posts by zmonster97
Team Aztech Aeromodels!
zmonster97's Avatar
United States, PA, Allentown
Joined May 2011
Originally Posted by flyboy50 View Post
Get the one from hobbyking. Cheaper and just as good.
http://www.hobbyking.com/hobbyking/s...ter_Pack_.html
zmonster97 is offline Find More Posts by zmonster97
Old Nov 12, 2011, 07:10 AM
michil is offline
Find More Posts by michil
Joined Apr 2008
Throttle to high?
Hi,
I'm using an Heli with DX8 and RPM control by my ESC. SO I programmed an throttle straight in my transmitter on different F Modes.
Everything works fine. WHen I switch on the transmitter and my pitch stick is not in total down position, the transmitter complains about "Throttle High". Why?
I do not have a coupling between Pitch and Throttle. Probably it's an wrong check in the transmitter about the Pitch stick position and not the Throttle output.
I think programming the transmitters always the "old" engine powered Helis are in mind and not the electric powered Helis which sometimes do not have and Throttle curve (only throttle straight).
Kind regards
Michael
michil is offline Find More Posts by michil
Old Nov 12, 2011, 08:01 AM
Mukenukem is offline
Find More Posts by Mukenukem
Vienna, Austria
Joined Oct 2010
Disable the throttle warning in the system menu. It does not work for guys switching on their engine on with a switch (like me). Unfortunately you have to buy a DX10t if you want to configure the switches freely to the alarm...
Or pester Andy long enough
As for the "not 100%" throttle, just be very sensitive when calibrating the sticks. Mine work perfectly after I calibrated them.
Mukenukem is offline Find More Posts by Mukenukem
Old Nov 12, 2011, 09:24 AM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Either be sensitive or limit the movement of the stick like I did.
freechip is offline Find More Posts by freechip
Old Nov 12, 2011, 09:52 AM
Rhode Island USA
Joined Aug 2010
I just checked my DX8 for calibration and I guess it wandered a bit. I suppose this is normal. So I recalibrated. To avoid the throttle "Extent Issue" I just simply noted where the extent positions are by looking at the tick marks and then just made sure I didnt go that far. It does now read 100% for both extents. Shimming doesnt really work for the throttle and elevator, it does however work for the Rudder and Aileron (Mode 2), the gymbals are different for the 2 axes.
VP
Question Receivers that work with Spektrum Radios that are not made by Spektrum BD Flyer Radios 29 Sep 26, 2010 04:09 AM
Discussion Spektrum AR6100E or Spektrum AR6100? LaurenceGough Off-road Cars 23 Aug 06, 2009 05:33 AM
For Sale Parkzone 5ch DX10 w/Receiver ch54 CarlHill Aircraft - General - Radio Equipment (FS/W) 7 Jul 10, 2009 12:07 PM
Discussion Can I use a Spektrum Air RX with a Spektrum Surface TX? Bigmaxy Radios 1 Jan 19, 2008 07:57 PM
Sold GeForce 8400Gs PCIx DX10 video card GFBurke Non R/C Items (FS/W) 6 Sep 05, 2007 10:43 PM
