Old Nov 10, 2011, 02:12 PM
AndyKunz is online now
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
Originally Posted by grumpy42 View Post
If I am reading this correctly, it seems that your are writing the telemetry data in "real time". It seems that it it would make more sense buffer the data and perform periodic writes.
Yes and no. Without getting into the various technical aspects, early on I made a quick streaming tool for testing telemetry that pointed out a need for significantly more work if it were to be productized for the DX7s/DX8 platform. The DX10t has a faster processor that does not have the same limitations, so enabling it in the baseline product was a non-issue.
As for buffering, that's actually how the file system works.
That is unfortunate. I would also be content with a module that plugs into the telemetry module and records to either internal memory a MicroSD card. Perhaps a external receiver that records telemetry data (not the STi since not everyone owns a compatible product).
You won't be content, then you couldn't be "grumpy" any more! You'd have to change your screen name
There are people who have figured out how to add their own module into their DX8 to record the telemetry data to a card in the similar manner as others did for Hitec.
So, if the DX10t gets logging then there is no "technical" reason that the DX8 can't support logging.
There is, as noted above.
Andy
AndyKunz is online now Find More Posts by AndyKunz
Site Sponsor
Old Nov 10, 2011, 03:43 PM
jhroof is offline
Find More Posts by jhroof
Orlando, Fl
Andy, OK logging is not a viable option for the DX8. But there are other features that people are willing to pay extra for. What did you think about my idea?
jhroof is offline Find More Posts by jhroof
Old Nov 10, 2011, 03:53 PM
pavcon is offline
Find More Posts by pavcon
Κύπρος, Λευκωσία, Πέρα Χωριό
Joined Jan 2010
+1 here
pavcon is offline Find More Posts by pavcon
FlyHighSelllow is offline
Find More Posts by FlyHighSelllow
Champagne Supernova
FlyHighSelllow's Avatar
United States, FL, Orlando
Joined Jul 2010
Andy
What if the data was written to a DB instead of a text file ? Access or SQL Theres gotta be a way to get around the write, dump, re write, allocate, truncate etc.
FlyHighSelllow is offline Find More Posts by FlyHighSelllow
Old Nov 10, 2011, 04:18 PM
AndyKunz's Avatar
Illinois
Joined Sep 2001
Sorry, I saw it and forgot to reply earlier. It's a technically-possible idea, and I designed that into the radio from day 1. A decision to think about going that route is way above my pay grade.
Databases are far more expensive in time and memory!!! You have to add the duration of the normal write stuff (that already takes too long) to the database system's overhead.
It's not even being written to a text file, it's the pure binary data off the air. There's no write, dump, ... sequence - it's a matter of write, write, write... to buffer until sector full then flush to disk, write...to buffer until sector full then flush to disk, ... until allocation unit full then read directory sectors, allocate more AU's to the file and flush the updated directory sectors to disk, then start to write, write, write... data again.
The thing that takes most time, especially with a card that has files on it already, is what happens when an allocation unit needs to be added to the file. Sometimes the file system needs to read (and write) multiple directory sectors, and those take time.
Believe me, there's nobody who wants data logging in the DX8 more than me. If I could have slipped it in unnoticed, I probably would have!
Andy
Site Sponsor
grumpy42 is offline
Find More Posts by grumpy42
grumpy42's Avatar
Canada
Joined Aug 2004
I believe that writing sequentially to a file is really the simplest/fastest way to go.
I was afraid that it was a processor limitation. Is it feasible to have logging on the DX8 but only have it work with a 22ms frame rate?
I am assuming that everything is executed within a control loop, so all stick/switch reading, applying mixes, updating UI, etc. must be completed within the "frame rate window". So, if the frame rate is limited then there may be sufficient time to complete the necessary file system operations.
Just a thought (and perhaps not a good one).
NEVER! There is always something to complain about!
grumpy42 is offline Find More Posts by grumpy42
Old Nov 10, 2011, 04:59 PM
AndyKunz's Avatar
Illinois
Joined Sep 2001
Telemetry is only 22ms even in an 11ms system.
Andy
Site Sponsor
Old Nov 10, 2011, 05:25 PM
grumpy42 is offline
grumpy42's Avatar
Canada
Joined Aug 2004
Telemetry may be 22ms but in an 11ms system, the control loop must execute within that time frame. Limiting the frame rate would free up compute cycles.
Old Nov 10, 2011, 05:42 PM
Mukenukem is offline
Find More Posts by Mukenukem
Vienna, Austria
Joined Oct 2010
It is fine to get some insight on the things, thanks, Andy ! It is easier to understand why some features are not possible when you tell us the reasons.
We need more power . Let's overclock the CPU !
Mukenukem is offline Find More Posts by Mukenukem
Old Nov 10, 2011, 05:51 PM
Champagne Supernova
Joined Jul 2010
Andy
Write to onboard memory instead of disk ? Or some other media that would be faster and could handle it better. Then download to disk later.
Just thinkin out loud man. Gotta be a way with fewer man days.
Old Nov 10, 2011, 06:29 PM
Fstauble is offline
Find More Posts by Fstauble
Beavercreek Ohio
Joined Oct 2009
I have no understanding of the limitations. But,
What about only recording data every 5 seconds (to pick a radom number).
Or
only recording a couple of sensors that are user selected.
Or
record one or two at a time and cycle through all
Or
how about just recording the top 20 max/mins.
You get the idea, limit the amount of data, the data rate.....
Just throwing it out there, I don't even use the telemtry at this point.
I have never had any issues with the radio and it does everything that I thought it would when I bought it.
Fstauble is offline Find More Posts by Fstauble
Old Nov 10, 2011, 07:24 PM
stgdz is offline
Find More Posts by stgdz
Volts>amps
stgdz's Avatar
United States, MN, Buffalo
Joined Jul 2011
At this point I am reading between the lines and if telemetry logging has been in since day one and we still don't have it I would highly doubt we are ever going to get it, no matter how hard Andy tries due to the CPU limitation that the 10t apparently fixes. Thanks for the info that you have given.
I am really dissapointed at this point.
stgdz is offline Find More Posts by stgdz
Old Nov 10, 2011, 07:48 PM
pavcon is offline
Joined Jan 2010
maybe jumping to DB access might solve the prob.
I was doing Computer programming some years ago and I understand Andy completely.. Sometimes computers act weird.. and sometimes you need to ho a whole other way to achieve the same thing.
Give the guy a brake. I'm sure he will figure it out at somepoint
Old Nov 10, 2011, 08:06 PM
teryn1 is offline
Find More Posts by teryn1
teryn1's Avatar
Tucson, AZ
Joined Aug 2004
That's why I am waiting for the next JR radio - it will be done right.
teryn1 is offline Find More Posts by teryn1
Old Nov 10, 2011, 08:07 PM
teryn1 is offline
teryn1's Avatar
Tucson, AZ
Joined Aug 2004
Andy, thanks for giving us some insight into the limitations of the radio and why logging hasn't been done. Your latest string of messages has added a lot of value to this thread.
Question Receivers that work with Spektrum Radios that are not made by Spektrum BD Flyer Radios 29 Sep 26, 2010 04:09 AM
Discussion Spektrum AR6100E or Spektrum AR6100? LaurenceGough Off-road Cars 23 Aug 06, 2009 05:33 AM
For Sale Parkzone 5ch DX10 w/Receiver ch54 CarlHill Aircraft - General - Radio Equipment (FS/W) 7 Jul 10, 2009 12:07 PM
Discussion Can I use a Spektrum Air RX with a Spektrum Surface TX? Bigmaxy Radios 1 Jan 19, 2008 07:57 PM
Sold GeForce 8400Gs PCIx DX10 video card GFBurke Non R/C Items (FS/W) 6 Sep 05, 2007 10:43 PM
