Old Nov 04, 2011, 08:54 AM
pavcon is offline
Find More Posts by pavcon
Κύπρος, Λευκωσία, Πέρα Χωριό
Joined Jan 2010
Originally Posted by Victory Pete View Post
Please post pictures of your installation.
VP
I just binded the telemetry..
it's easy to put the wires.. Just from the pictures it's rather obvious what you need to do.
now I will need to install the Tube which will get the readings.. I will install it in my Flyfly MB339.
will not try it though soon as I'm waiting for RClander retracts to arrive.
the stock struts won' thandle the 3.2 kg weigh tof the plane well.. they are bending all the time..
the weird thing is that the receiver now binded at 22ms :/ is that normal?
oh I will post pictures as soon as it's ready. most probably I will have it sticking out from the nose of the plane
pavcon is offline Find More Posts by pavcon
Old Nov 04, 2011, 09:14 AM
DenverJayhawk is online now
Find More Posts by DenverJayhawk
United States, CO, Denver
Joined May 2010
I don't see a menu item for EPA (end point adjust). I'm assuming this is simply done in the TRAVEL setting under Servo Setup?
I'm trying to set end points for my castle ESC and the instructions say to initially set low and high EPA to 30% and then gradually increase it until you hear the beap.
DenverJayhawk is online now Find More Posts by DenverJayhawk
Old Nov 04, 2011, 09:19 AM
stgdz is offline
Find More Posts by stgdz
Volts>amps
stgdz's Avatar
United States, MN, Buffalo
Joined Jul 2011
Originally Posted by AndyKunz View Post
The sensor would have to be modified to provide that information. The cells don't always discharge evenly.
Thanks for the suggestions.
Andy
Thanks andy, I should have been a bit more clear though. A simple divider of totalvoltage by number of cells is what I was asking for. I wasn't seeing an advantage to monitoring all cells to determine if unbalancing was found, those get checked by the watt meter or charger after flying.
stgdz is offline Find More Posts by stgdz
pavcon is offline
Joined Jan 2010
lol.. along with my Airspeed sensor.. in the same packages I got my CC field link portable programmer
set your throttle end points to autocalibration..
just leave the throttle stick in the middle.. connecte the power of your plane then throttle back .. it will set them automatically.
Old Nov 04, 2011, 09:33 AM
Joined May 2010
ok, i can do that. But should the throttle travel be set to 100 and 100?
Old Nov 04, 2011, 10:14 AM
CiprianGugu is online now
Find More Posts by CiprianGugu
Look Up
CiprianGugu's Avatar
United States, TN, Jamestown
Joined Nov 2003
Originally Posted by grumpy42 View Post
Personally, I really would like a current sensor. This seems like on odd oversight.
I bought the DX8 because of the telemetry, I didn't look at the options for it until I bought it. I was surprised that there was no current sensor available.
Waiting patiently for one, with the hope that they will add the display of mAh along with current. Am I just wasting my time? Is Quanum the only other option?
CiprianGugu is online now Find More Posts by CiprianGugu
Old Nov 04, 2011, 10:36 AM
Mukenukem is offline
Find More Posts by Mukenukem
Vienna, Austria
Joined Oct 2010
The Power Box menu has also mAh display, so I think it is just a matter of time. But when looking at the competition (like Graupner HOTT), the guys at Spek should do something....
Mukenukem is offline Find More Posts by Mukenukem
Old Nov 04, 2011, 10:50 AM
ivanc is offline
Find More Posts by ivanc
S.A.D. member
ivanc's Avatar
United States, TX, Round Rock
Joined Dec 2004
It can be done relatively easy. This one plugs into the balancing connector measures the voltage of each individual cell and sounds the alarm if any cell drops below a predetermined value. For telemetry we don't need LED and audible alarm - replace that with opto isolated serial output to the telemetry module.
ivanc is offline Find More Posts by ivanc
Old Nov 04, 2011, 01:23 PM
pavcon is offline
Joined Jan 2010
actually the competition is Futaba. so Futaba is just adding telemetry now. ..
At my Field most of the pilots are futaba oriented. Till now I had nothing more than they had appart from that vibration now Igot telemetry .. now one does on his Tx display so far.
Telemetry with that data port has so many potential so I expect that it's a matter of time that we will see more sensors and more otpions . since this sesor I got (if you take a look at it) has Xbus so it can take more sensors in series. This is mentioned in the airspeed sensor manual too
Old Nov 04, 2011, 01:48 PM
AndyKunz is offline
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
EPA is different than Travel adjust. EPA sets limits on the amounts of travel, while Travel is a scaling factor. If you are using it for the throttle and do not fiddle with the sub trim, it will achieve what you want.
FWIW, all my Castle ESCs work with the default 100% settings and with the throttle trim pulled all the way down.
Andy
AndyKunz is offline Find More Posts by AndyKunz
Site Sponsor
Old Nov 04, 2011, 03:44 PM
grumpy42 is offline
Find More Posts by grumpy42
grumpy42's Avatar
Canada
Joined Aug 2004
Hitec and Graupner both have current monitoring (Graupner even has individual cell monitoring). If you want a stand alone option, there is the EagleTree/Seagull stuff, but that costs almost as much as the DX8.
I also wish that TX based telemetry systems would support data logging. I suppose I can't fault the DX8 for not including data logging since none of the competitors seem to have that feature either (Hitec has the HTS-Navi, but that requires a laptop). It is strange since data logging seems like a natural extension of telemetry.
grumpy42 is offline Find More Posts by grumpy42
Old Nov 04, 2011, 04:15 PM
Arcteryxxx is offline
Find More Posts by Arcteryxxx
Livin it UP when Im goin DOWN
Arcteryxxx's Avatar
Norway, Telemark, Skien
Joined Feb 2010
it is strange since data logging seems like a natural extension of telemetry.
^+1
Arcteryxxx is offline Find More Posts by Arcteryxxx
Old Nov 04, 2011, 04:18 PM
Victory Pete is offline
Find More Posts by Victory Pete
Rhode Island USA
Joined Aug 2010
I read all the E-mails I get from Futaba very eagerly, I am waiting for their masterpiece to arrive!
VP
Victory Pete is offline Find More Posts by Victory Pete
Reply With Quote  (Disabled)
Old Nov 04, 2011, 07:18 PM
Gerula is offline
Find More Posts by Gerula
Bucharest, ROMANIA
Joined Mar 2010
How many recalls on the famous Dx8 so far? Just curioous, wondering if the enthusiasm of the fanboys is now reduced by a few notches .
Gerula is offline Find More Posts by Gerula
Old Nov 04, 2011, 07:22 PM
cayars is offline
Find More Posts by cayars
cayars's Avatar
Bridgeton, NJ
Joined Mar 2009
ZERO, couple of service bulletins that could affect some people (gimbles and legacy receivers) is all.
cayars is offline Find More Posts by cayars
Question Receivers that work with Spektrum Radios that are not made by Spektrum BD Flyer Radios 29 Sep 26, 2010 04:09 AM
Discussion Spektrum AR6100E or Spektrum AR6100? LaurenceGough Off-road Cars 23 Aug 06, 2009 05:33 AM
For Sale Parkzone 5ch DX10 w/Receiver ch54 CarlHill Aircraft - General - Radio Equipment (FS/W) 7 Jul 10, 2009 12:07 PM
Discussion Can I use a Spektrum Air RX with a Spektrum Surface TX? Bigmaxy Radios 1 Jan 19, 2008 07:57 PM
Sold GeForce 8400Gs PCIx DX10 video card GFBurke Non R/C Items (FS/W) 6 Sep 05, 2007 10:43 PM
