Old Aug 24, 2011, 08:07 PM
cayars is offline
Find More Posts by cayars
cayars's Avatar
Bridgeton, NJ
Joined Mar 2009
Ouch
cayars is offline Find More Posts by cayars
Old Aug 24, 2011, 08:10 PM
natss is offline
Find More Posts by natss
Registered American Veteran
natss's Avatar
Tulsa, Oklahoma
Joined Aug 2010
Originally Posted by freechip View Post
But do so in the proper thread.
Or if they are good general tips that can be applied in the DX8 or future DX10 transmitter Id like to know here.
natss is offline Find More Posts by natss
Old Aug 24, 2011, 09:02 PM
mikeruth is offline
Find More Posts by mikeruth
The "Foaminator"
mikeruth's Avatar
Joined Mar 2007
+1 on Cayars trimming thread above.
Mike R
mikeruth is offline Find More Posts by mikeruth
Old Aug 24, 2011, 10:20 PM
pkquat is offline
Find More Posts by pkquat
Joined Jun 2008
Originally Posted by maddog7 View Post
I know this is a little off topic, but I've searched RCG for comprehensive how to's on trimming. I met a old boy on holiday who was really cool and an ex F3A champion. He maintained that trimming was KING for a viceless model.
Perhaps if I've missed the "definitive trimming guide" you guys could point me toward it or failing that perhaps someone would care to elaborate as to what they do? The more detail the better.
Obviously it might be better in a new thread to restrict the chaff in this thread.
I'm intrigued at Cayars wing straightening technique (assuming strategic tightening of the covering?)
Cheers D
Turboparkers blog, about half way - 2/3 down, has some very good trimming information.
http://www.rcgroups.com/forums/member.php?u=271944
pkquat is offline Find More Posts by pkquat
Old Aug 25, 2011, 03:23 AM
aV8erUK is offline
Find More Posts by aV8erUK
United Kingdom, England, Birmingham
Joined Dec 2010
Originally Posted by AndyKunz View Post
Hey, I got my first turbine airframe the other day, a DV8R!! Now I need to start buying servos, retracts, etc. And a new car to carry it all!
Andy
Sounds great Andy you lucky *^%$ That will always be out of my league.
I do admire anyone who has the bottle to put that sort of moneys worth into the air, and I love watching them. The very best of luck, keep us posted.
Now: Could you explain more about this second binding? It doesn't seem an intuitive thing to need to do. Is it purely for failsafe? i.e. if you bind (setting failsafe) then change throttle direction, you end up with throttle failsafe at full throttle? So bind again to set it where you really want it?
aV8erUK is offline Find More Posts by aV8erUK
Old Aug 25, 2011, 04:01 AM
topgearuk is offline
Find More Posts by topgearuk
topgearuk's Avatar
United Kingdom, London
Joined Dec 2003
Yep that's what it is for!
topgearuk is offline Find More Posts by topgearuk
Old Aug 25, 2011, 08:00 AM
cayars is offline
cayars's Avatar
Bridgeton, NJ
Joined Mar 2009
Andy did you pick it up new or used? Which color scheme is it? I always like the "sport" on that jet.
You made a pretty good choice with it as that plane has a pretty large flight envelope. It's moderately fast at about 180 and slows down and flys around 30. It's also one of the better grass planes.
Any idea which turbine you are going to go with? Is it a Pat McCurry kit or the newer TBM ARF kit (1 or 3 piece wing)?
Is this going to be a winter project/build for you?
Do you have an inspector near you? If not and your going to be in Jersey give me a heads up and I'll help you get your inspection and turbine waiver.
Ever flown anything that fast before?
Carlo
Old Aug 25, 2011, 08:24 AM
Rickn816 is offline
Find More Posts by Rickn816
RCHN #150
Rickn816's Avatar
Lawrenceville, GA
Joined Nov 2007
Originally Posted by cayars View Post
Why don't you just fix this mechanically like it should be fixed so the speed of the motor (prop blast/wash) doesn't effect the model. You'll never be able to setup trims or mixes to compensate this properly.
When your aircraft has elevons (like the Stryker), the speed of the motor and speed of the aircraft make a mechanical adjustment impossible. In trim at low speed will not be in trim at max speed.
Similarly, if you have a powered glider (Radian Pro, for example), it will tend to loop under power. So, set the mix to increase down elevator as you increase throttle.
Two cents.
Rick
Rickn816 is offline Find More Posts by Rickn816
Old Aug 25, 2011, 08:57 AM
AndyKunz is offline
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
Thunderbirds. #6
We already have one at the field, and I've seen it fly a number of times. This weekend is our Illini SuperJets http://elifield.com/flyers/2011_SuperJets.pdf meet and his dad said they plan to pump 35 gallons through the engine.
Definitely JetCat. One of their service guys works here. TBM.
I certainly hope so!
Yup, several of the guys here. Our club has about 20 turbines in it that I can think of, including guys who helped the AMA set up the waiver program. The guy I got it from can sign off everything.
150 in a 4' hotliner is my tops so far. I have a small Habu32-powered plane I'm working on right now. By the time the DV8R is ready, I will have quite a bit of 150+ airtime.
Andy
AndyKunz is offline Find More Posts by AndyKunz
Site Sponsor
Old Aug 25, 2011, 09:12 AM
GMRO is offline
Find More Posts by GMRO
Russellton, PA
Joined Oct 2002
GOOD FOR YOU ANDY ON THE JET!!! And I hope the Illi-Jet Event goes well for you guys!
I've just finished up the new JR GSRZ260 heli. Currently I've got the 12X guiding it on DSMX. I am using 2 sats and the new base 7110R RX on 2S LI-PO. I also added the TM1000 as the iDevice STi thingy will be coming soon. OR if I decide to use my DX8. I have the RX voltage; LI-PO voltage and altimeter and the temperature thermocouple from Spektrum planned for this heli too. All are onboard…but waiting the last piece, the STi thingy!!!
All that said, my question is I want to use the RevLimiter on the RX. I spoke with Jeff H. on the placement on it so the gas engine will work with it. But the RX needs the sensor plugged into it so the rev limiter works. AND the TM1000 also needs the sensor in it so the telemetry sends the RPMS to the iDevice/DX8. What do you suggest I do to get the sensor output to BOTH the RX and TM1000? Y-harness? But they use different plug sizes. Does the TM1000 only need the signal wire from the RPM sensor or does it need the black wire too? OR all 3 wires? I want to make sure to NOT hurt or burn anything gout by feeding both RX and TM unit with the same sensor if possible.
Any tips would be appreciated.
THANKS!
GMRO
GMRO is offline Find More Posts by GMRO
Old Aug 25, 2011, 09:25 AM
AndyKunz is offline
AndyKunz's Avatar
Illinois
Joined Sep 2001
Ron,
You need to e-mail John on that.
Andy
Site Sponsor
Old Aug 25, 2011, 09:40 AM
Zeeb is online now
Find More Posts by Zeeb
Zeeb's Avatar
United States, UT, Highland
Joined Jun 2006
Do a Google search for Peter Goldsmith's trimming series, about 14 parts IIRC?
OR.... Andy MAY have some sort of direct link he can post.....
Zeeb is online now Find More Posts by Zeeb
Old Aug 25, 2011, 12:15 PM
maddog7 is offline
Find More Posts by maddog7
maddog7's Avatar
Joined Jan 2004
Thanks all.
Cayars,
Somehow I missed your reply to my original qtn and answered that of GBRellic???
Dunno what happened there, anyways thanks for that work through. I'll wait for a windless day to attempt it.
Thanks also to Pkquat and Zeeb for their links and I'll get a look at them as soon as I get a moment.
D
maddog7 is offline Find More Posts by maddog7
Old Aug 25, 2011, 02:24 PM
maddog7 is offline
maddog7's Avatar
Joined Jan 2004
Cayars,
Sorry for missing this out of my last post, Yes a thread to which peeps could all contribute would be awesome if you'd care to kick it off.
It could be refined into the collective definitive way to make a bird fly well!
I've been all over the place recently and not read stuff as thoroughly as I should have
Cheers all.
Old Aug 25, 2011, 06:26 PM
Victory Pete is offline
Find More Posts by Victory Pete
Rhode Island USA
Joined Aug 2010
Model Select Shortcut
I saw in a video where the guy was pressing both "clear" and "back" buttons simultaneously to get into the "Model Select" screen, and by God it works. I have found this very useful, turning off the Tx everytime to change models was somewhat inconvenient. Is this a surprise to some of you guys? It was to me.
VP
PS I found this in the manual, PDF version is legible. What a great feature this will be from now on!
Victory Pete is offline Find More Posts by Victory Pete
Reply With Quote  (Disabled)
Question Receivers that work with Spektrum Radios that are not made by Spektrum BD Flyer Radios 29 Sep 26, 2010 05:09 AM
Discussion Spektrum AR6100E or Spektrum AR6100? LaurenceGough Off-road Cars 23 Aug 06, 2009 06:33 AM
For Sale Parkzone 5ch DX10 w/Receiver ch54 CarlHill Aircraft - General - Radio Equipment (FS/W) 7 Jul 10, 2009 01:07 PM
Discussion Can I use a Spektrum Air RX with a Spektrum Surface TX? Bigmaxy Radios 1 Jan 19, 2008 08:57 PM
Sold GeForce 8400Gs PCIx DX10 video card GFBurke Non R/C Items (FS/W) 6 Sep 05, 2007 11:43 PM
